[Ovmsdev] Collecting information on the Fiat 500e
Tue Feb 12 13:12:09 HKT 2019
Guenther,
With the latest code (3.2.001-80-g731c916e or later), you should be able to try this. Instructions are pretty much the same as previously given:
Put your DBC file in /store/dbc/<vehicletype>.dbc
Load the DBC:
ovms# dbc load <vehicletype> /store/dbc/<vehicletype>.dbc
(or ‘dbc autoload’ to load all DBC files in that directory)
Note: It should be automatically loaded on boot, and you can use ‘dbc list’ to confirm.
Configure your vehicle type and assign the DBC to CAN bus #1 for it:
config set auto vehicle.type DBC
config set vehicle dbc.can1 <vehicletype>
Within the DBC, set the signal name the same as the OVMS metric name (you can use periods ‘.’ as separators, or ‘_’ will be converted automatically for you). Connect to the car, and the CAN bus data should start to be processed and metrics updated based on your DBC file. Only integer DBC signals are supported (either signed or unsigned should be ok), but factors and/or offsets can convert these automatically to floats.
At the moment, you can only change the DBC on disk (/store/dbc/*.dbc) then reload it. However, it will be locked (as it is used by your OvmsVehicleDBC vehicle) . So you will have to either clear the vehicle module (‘vehicle module’), reload the DBC, then reload the vehicle module (‘vehicle module DBC’). Alternatively, you can simply reboot the OVMS. Later on I will improve on this to support hot-reloading and in-memory modification of live DBC files (via retool).
Remember that extended CAN IDs need to have the high bit set in DBC format. So, extended ID 100 is 2147483748 (2^31 + 100).
> On 11 Feb 2019, at 11:35 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Guenther,
> The code is not finished yet, so no documentation at the moment. I will document it when it is working.
> The overall plan (for a single CAN bus, single DBC, for example) is:
> Put your DBC file in /store/dbc/<vehicletype>.dbc.
> You should now find it automatically loaded on boot. You can use ‘dbc list’ to confirm.
> Configure your vehicle type as “DBC”.
> The above is close to completion - just waiting for the decode function which I am struggling with (eMail sent to ovmsdev mailing list earlier today).
> The retools system will have facilities to maintain DBC files (in memory) and save them back to disk. It will also use DBC files as its main way of working with messages.
>> On 11 Feb 2019, at 12:38 AM, Guenther Huck <privat at guentherhuck.at <mailto:privat at guentherhuck.at>> wrote:
>> Thank you Mark!
>> But my question was if there is a manual how I can use the dbc file in OVMS 3.
>> I cannot find a description.
>> Guenther
>> From: Mark Webb-Johnson <mailto:mark at webb-johnson.net>
>> Sent: Friday, February 08, 2019 12:57 AM
>> To: OVMS Developers <mailto:ovmsdev at lists.openvehicles.com>
>> Subject: Re: [Ovmsdev] Collecting information on the Fiat 500e
>> This is quite good:
>>> http://socialledge.com/sjsu/index.php/DBC_Format <http://socialledge.com/sjsu/index.php/DBC_Format>
>> There are a large number of examples here:
>>> https://github.com/commaai/opendbc <https://github.com/commaai/opendbc>
>> (although many are not 100% standards conformant, so will not parse correctly)
>> Attached is the formal specification.
>>> On 8 Feb 2019, at 12:35 AM, Guenther Huck <privat at guentherhuck.at <mailto:privat at guentherhuck.at>> wrote:
>>> Is there somewhere in the net a manual how to make a dbc-file impemention?
>>> Thx Guenther
>>> Sent: Thursday, February 07, 2019 2:44 PM
>>> This also looks to be a good candidate for a DBC implementation. That way, no coding required, and Gunther can tune and add metrics himself.
>>> With the iOS App done, and now in testing, I am back working on DBC and RE tools. Made some progress these last two days (Chinese new year holidays here), and hoping to have something usable this weekend.
>>> But, need those crtd can bus dumps to validate it.
>>> Regards, Mark
>>> On 6 Feb 2019, at 9:12 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>> I think it best to also get a few CAN dumps:
>>>> While car is parked, idle, asleep
>>>> While car is parked, but awake
>>>> While car is driving
>>>> These should be in CRTD format.
>>>> They will allow us to double-check the actual CAN bus traffic to ensure it matches what is shown in the spreadsheet.
>>>> Regards, Mark.
>>>>> On 6 Feb 2019, at 8:55 PM, Guenther Huck <privat at guentherhuck.at <mailto:privat at guentherhuck.at>> wrote:
>>>>> Hello Michael
>>>>> That’s perfect! Ich can send you some more CAN-ID’S. Tell me what is important for the first implementation.
>>>>> <image[3].png>
>>>>> <image[7].png>
>>>>> <image[10].png>
>>>>> <image[13].png>
>>>>> <image[16].png>
>>>>> From: Michael Balzer <mailto:dexter at expeedo.de>
>>>>> Sent: Wednesday, February 06, 2019 12:55 PM
>>>>> To: ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>
>>>>> Günther,
>>>>> yes, that looks sufficient.
>>>>> It's always best if an actual vehicle user does the code, but we can provide a first basic implementation to build upon.
>>>>> Regards,
>>>>> Michael
>>>>> Am 05.02.19 um 18:22 schrieb Guenther Huck:
>>>>>> Is this ok?
>>>>>> <image[2].png>
>>>>>> From: Guenther Huck <mailto:privat at guentherhuck.at>
>>>>>> Sent: Tuesday, February 05, 2019 6:06 PM
>>>>>> Hello Mark
>>>>>> I have a Fiat 500e and asked if there is anybody who is firm with the CAN Id’s.
>>>>>> In the meantime I have some CAN informations for Fiat 500e and can give to you or somebody who is familiar to programm the OVMS for this car.
>>>>>> I don’t have enough experiance to programm this. Sorry!
>>>>>> What informations to you need to insert this car to your project ?
>>>>>> Guenther
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>> This is quite good:
>> http://socialledge.com/sjsu/index.php/DBC_Format <http://socialledge.com/sjsu/index.php/DBC_Format> <http://socialledge.com/sjsu/index.php/DBC_Format <http://socialledge.com/sjsu/index.php/DBC_Format>>
>> https://github.com/commaai/opendbc <https://github.com/commaai/opendbc> <https://github.com/commaai/opendbc <https://github.com/commaai/opendbc>>
>> > Thx Guenther
>> > From: Mark Webb-Johnson <mailto:mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>> > To: OVMS Developers <mailto:ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
>> > Regards, Mark
>> > On 6 Feb 2019, at 9:12 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net <mailto:mark at webb-johnson.net>>> wrote:
>> >> Regards, Mark.
>> >>> On 6 Feb 2019, at 8:55 PM, Guenther Huck <privat at guentherhuck.at <mailto:privat at guentherhuck.at> <mailto:privat at guentherhuck.at <mailto:privat at guentherhuck.at>>> wrote:
>> >>> Hello Michael
>> >>> <image[3].png>
>> >>> <image[7].png>
>> >>> <image[10].png>
>> >>> <image[13].png>
>> >>> <image[16].png>
>> >>> From: Michael Balzer <mailto:dexter at expeedo.de <mailto:dexter at expeedo.de>>
>> >>> To: ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com> <mailto:ovmsdev at lists.openvehicles.com <mailto:ovmsdev at lists.openvehicles.com>>
>> >>> Günther,
>> >>> Regards,
>> >>> Michael
>> >>>> Is this ok?
>> >>>> <image[2].png>
>> >>>> From: Guenther Huck <mailto:privat at guentherhuck.at <mailto:privat at guentherhuck.at>>
>> >>>> Hello Mark
>> >>>> Guenther
>> >>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com> <mailto:OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>>
>> >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev> <http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190212/8dd7e39e/attachment-0001.html>
