[Ovmsdev] DBC and Endian-ness
Robert Cotran
robert at cotran.ca
Mon Feb 11 22:09:37 HKT 2019
Hi Mark,
I don't know if you know about the openpilot project. It's basically an
open-source driving agent (autopilot). I've done a lot of work on it
including developing the original port to making it work on Classic
Tesla Model S with a friend of mine.
Part of what we needed to do was unpack and repack the Tesla DBC which
has a mix of big and little-endian (Motorola and Intel) encoding.
Here is the github repo for the parser and packer (decoding/encoding)
that we wrote in c++ to do it:
https://github.com/jeankalud/openpilot
It's actually a branch from the real openpilot which now incorporates
our packer/parser changes.
The secret sauce is here:
https://github.com/jeankalud/openpilot/tree/tesla/selfdrive/can
In parser.cc and packer.cc. It should be relatively self-explanatory.
Let me know if you have any questions!
Rob
On 2019-02-10 9:55 PM, Mark Webb-Johnson wrote:
> I’ve been going round and round in circles on this, most of the
> weekend, but not getting anywhere. I’ve rewritten the Decoder code
> four times so far, but just can’t get it to work. So calling for help
> here.
> I attach the DBC specification. You can also find an extensive python
> library here:
> https://github.com/eerimoq/cantools.git
> (for anyone playing with DBC, that seems an excellent library and set
> of command line tools)
> The seemingly simple problem that I am trying to solve is:
> Given a CAN frame, we need to decode a particular signal. We want
> the integer value (signed or unsigned) out of it.
> The signal species the start bit, size (number of bits), endian-ness
> (big or little), and value type (signed or unsigned). The DBC
> specification says:
> /The start_bit value specifies the position of the signal within
> the data field of the frame. For signals with byte order
> Intel (little endian) the position of the least-significant bit
> is given. For signals with byte order Motorola (big endian) the
> position of the most significant bit is given. The bits are
> counted in a saw-tooth manner./
> /byte_order = '0' | '1' (* 0=little endian, 1=big endian *)
> The byte_format is 0 if the signal's byte order is Intel (little
> endian) or 1 if the byte order is Motorola (big endian)./
> There are also factor and offset values for signals, but that is
> irrelevant for the moment (trivial to apply once we have the actual
> integer raw signal value extracted) and can be ignored for the moment.
> Wikipedia explains endian-ness:
> In big-endian format, whenever addressing memory or
> sending/storing words bytewise, the most significant byte—the byte
> containing the most significant bit—is stored first (has the
> lowest address) or sent first, then the following bytes are stored
> or sent in decreasing significance order, with the
> least significant byte—the one containing the least significant
> bit—stored last (having the highest address) or sent last.
> Little-endian format reverses this order: the sequence
> addresses/sends/stores the least significant byte first (lowest
> address) and the most significant byte last (highest address).
> So, we have two strange things in the DBC specification: (1) the start
> bit is not always the first bit in the stream, and (2) this ’saw-tooth
> manner’ comment. So, I create a very simple DBC, and run it through
> the cantools dump to visualise it:
> $ cat mark.dbc
> BU_: WS200 MCN_Powertrain
> BO_ 1 LittleEnd: 8 WS200
> SG_ OneByte : 7|8 at 0+ (1,0) [0|0] "" Vector__XXX
> SG_ TwoByte : 15|16 at 0+ (1,0) [0|0] "" Vector__XXX
> SG_ TwelveBit : 39|12 at 0+ (1,0) [0|0] "" Vector__XXX
> $ cantools dump mark.dbc
> ================================= Messages
> Length: 8 bytes
> Cycle time: - ms
> Senders: WS200
> Layout:
> Bit
> 7 6 5 4 3 2 1 0
> 0 |<-----------------------------x|
> +-- OneByte
> 1 |<------------------------------|
> 2 |------------------------------x|
> B +-- TwoByte
> y +---+---+---+---+---+---+---+---+
> t 3 | | | | | | | | |
> e +---+---+---+---+---+---+---+---+
> 4 |<------------------------------|
> 5 |--------------x| | | | |
> +-- TwelveBit
> 6 | | | | | | | | |
> 7 | | | | | | | | |
> Signal tree:
> -- {root}
> +-- OneByte
> +-- TwoByte
> +-- TwelveBit
> I also used 'cantools generate_c_source mark.dbc’ to generate a C
> decoder for this, and this is what it looks like:
> int mark_little_end_unpack(
> struct mark_little_end_t *dst_p,
> const uint8_t *src_p,
> size_t size)
> if (size < 8u) {
> return (-EINVAL);
> memset(dst_p, 0, sizeof(*dst_p));
> dst_p->one_byte |= unpack_right_shift_u8(src_p[0], 0u, 0xffu);
> dst_p->two_byte |= unpack_left_shift_u16(src_p[1], 8u, 0xffu);
> dst_p->two_byte |= unpack_right_shift_u16(src_p[2], 0u, 0xffu);
> dst_p->twelve_bit |= unpack_left_shift_u16(src_p[4], 4u, 0xffu);
> dst_p->twelve_bit |= unpack_right_shift_u16(src_p[5], 4u, 0xf0u);
> return (0);
> Let’s look at that TwoByte value. This is little endian, so the least
> significant byte should come first in p[1] followed by the most
> significant in p[2]. So, why does the generator produce:
> From what I can see, that means take p[1] and shift it left 8, then
> add on p[2]. That seems big endian, not little endian?
> Let’s try a big endian example:
> BO_ 3 BigEnd2: 8 WS200
> SG_ EightBit2 : 5|8 at 1+ (1,0) [0|0] "" Vector__XXX
> SG_ OneByte2 : 16|8 at 1+ (1,0) [0|0] "" Vector__XXX
> SG_ TwelveBit2 : 48|11 at 1+ (1,0) [0|0] "” Vector__XXX
> Bit
> 7 6 5 4 3 2 1 0
> 0 |----------x| | | | | |
> 1 | | | |<------------------|
> +-- EightBit2
> 2 |<-----------------------------x|
> B +-- OneByte2
> 4 | | | | | | | | |
> 5 | | | | | | | | |
> 6 |------------------------------x|
> 7 | | | | | |<----------|
> +-- TwelveBit2
> Notice the weird alignment of EightBit2 and TwelveBit2? I presume that
> is the ’saw-tooth’ pattern talked about in the DBC specification.
> A Tesla Model S encodes values like the battery temperature in CAN ID
> 0x102, and we decode this in C like this:
> StandardMetrics.ms_v_bat_temp->SetValue((float)((((int)d[7]&0x07)<<8)+d[6])/10);
> So that is little endian (d[7] is shifted right, followed by d[6]
> normally - so d[7] is the MSB and d[6] the LSB). But how to represent
> that in DBC?
> BO_ 1 LittleEnd2: 8 WS200
> SG_ TwoByte : 47|11 at 0+ (1,0) [0|0] "” Vector__XXX
> Bit
> 7 6 5 4 3 2 1 0
> 0 | | | | | | | | |
> 1 | | | | | | | | |
> 2 | | | | | | | | |
> B 3 | | | | | | | | |
> t 4 | | | | | | | | |
> 5 |<------------------------------|
> 6 |----------x| | | | | |
> +-- TwoByte
> 7 | | | | | | | | |
> dst_p->two_byte |= unpack_left_shift_u16(src_p[5], 3u, 0xffu);
> dst_p->two_byte |= unpack_right_shift_u16(src_p[6], 5u, 0xe0u);
> That doesn’t work. How about big endian?
> BO_ 1 BigEnd2: 8 WS200
> SG_ TwoByte : 48|11 at 1+ (1,0) [0|0] "” Vector__XXX
> Bit
> 7 6 5 4 3 2 1 0
> 0 | | | | | | | | |
> 1 | | | | | | | | |
> 2 | | | | | | | | |
> 5 | | | | | | | | |
> +— TwoByte
> dst_p->two_byte |= unpack_right_shift_u16(src_p[6], 0u, 0xffu);
> dst_p->two_byte |= unpack_left_shift_u16(src_p[7], 8u, 0x07u);
> That seems correct.
> Looking in the source for cantools dbc
> (cantools/cantools/database/can/formats/dbc.py), I see:
> byte_order=(0 if signal.byte_order == 'big_endian' else 1),
> This code also says the same thing (0 = big endian):
> https://github.com/julietkilo/CANBabel/blob/master/src/main/java/com/github/canbabel/canio/dbc/DbcReader.java
> booleanisBigEndian ="0".equals(splitted[2]);
> WTF?
> There is this (from googling), which makes things clear as mud:
> https://github.com/ebroecker/canmatrix/wiki/signal-Byteorder
> https://se.mathworks.com/help/vnt/ug/canpack.html
> https://github.com/ebroecker/SocketCandecodeSignals/blob/master/datenbasis.c#L112-L122
> My conclusions are that:
> 1. The DBC specification is incorrect, in that 0 is big endian, and 1
> is little endian in the public code we see.
> and/or
> 2. The DBC specification is incorrect, in that all CAN bus byte
> ordering is little endian, and the byte_order setting only affects
> the interpretation of the bit_ordering, and saw-tooth decode/encode.
> But that really makes no sense to me. This is supposed to be the
> defacto standard for automotive CAN bus signal definition - how can it
> be such a mess?
> Help?
> Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190211/5e257482/attachment-0001.html>
