[Ovmsdev] version 3.2.007: Crash on boot
Tamás Kovács kommykt at gmail.com
Tue Dec 17 02:57:59 HKT 2019
Yes I merged the fix.
I don't understand why my version is 3.2.005.
Now I try to new clone I think.
I don't know what's this: "or are you on a local spin-off branch of
3.2.005". I always create modification on my code then I upload it to my
git repo and then create a compare with the main open vehicles repo then I
update my local code in atom with a fetch.
Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2019. dec. 16., H,
18:54):
> Tamás,
> I'm confused, and your dropbox files don't help… did you merge the fix and
> still get the crash?
> Is your version just off because your repository lacks tags (if so: why?),
> or are you on a local spin-off branch of 3.2.005?
> I've got the impression your git repository is messed up. Maybe you should
> try a new clone?
> Am 15.12.19 um 20:13 schrieb Tamás Kovács:
> My code crashed with same error as it described.
> plus one error: in esp32can.cpp:448
> The files can access my dropbox folder:
> https://www.dropbox.com/sh/mowc7hc7zrzszmm/AACO4MAmM1yF3yoXsGoZO6R_a?dl=0
> Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2019. dec. 13., P,
> 10:16):
>> Greg, Mark,
>> the new crash happened here:
>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l
>> 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0
>> 0x400da901:0x3ffc8810
>> Using elf file:
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>> 0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866).
>> 861      {
>> 862      if (tx)
>> 863        {
>> 864        if (frame->callback)
>> 865          {
>> 866          (*(frame->callback))(frame, success); // invoke
>> frame-specific callback function
>> 867          }
>> 868        for (auto entry : m_txcallbacks) {      // invoke generic tx
>> callbacks
>> 869          entry->m_callback(frame, success);
>> 870          }
>> 0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018).
>> 1013        }
>> 1014      else
>> 1015        {
>> 1016        LogFrame(CAN_LogFrame_TX_Fail, p_frame);
>> 1017        }
>> 1018      MyCan.ExecuteCallbacks(p_frame, true, success);
>> 1019      }
>> 1020
>> 1021    /**
>> 1022     * canbus::Write -- main TX API
>> 0x400da901 is in CAN_rxtask(void*)
>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>> 725                  me->IncomingFrame(&msg.body.frame);
>> 726                } while (loop);
>> 727              break;
>> 728              }
>> 729            case CAN_txcallback:
>> 730              msg.body.bus->TxCallback(&msg.body.frame, true);
>> 731              break;
>> 732            case CAN_txfailedcallback:
>> 733              msg.body.bus->TxCallback(&msg.body.frame, false);
>> 734              msg.body.bus->LogStatus(CAN_LogStatus_Error);
>> As the frame callback invocation is secured against null, it must have
>> been a missing initialization of frame.callback. So I checked our source
>> tree for uses of CAN_frame_t without memset or zero initialization and
>> found one in obd2ecu::IncomingFrame() -- causing this crash I assume -- and
>> two more in the can rx/tx shell commands.
>> Fix is in commit
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/34302254567b15a8c0f9dfb730b5cf24703ac700
>> …and build in https://ovms.dexters-web.de/firmware/ota/v3.1/edge/
>> Greg, please test again.
>> Am 13.12.19 um 07:09 schrieb Greg D.:
>> Hi Michael,
>> Ok, so I believe I loaded your Edge build, and the issue remains.  To
>> verify, this is the string reported by the web Status page:
>> 3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec
>> 12 2019 11:59:14)
>> Following my earlier email, I left the configuration as-is, including
>> launching the obd2ecu task, but with the attached OBDII module removed, and
>> the crash was resolved.  Rebooting the module had it come up running
>> normally.  I then plugged in the OBDII module into the OVMSv3, and OVMS
>> crashed the instant the first it started polling.  The device is a SyncUp
>> Drive, which is a telematics and WiFi hotspot.  Connecting the OBDII device
>> with 12v power off, as expected, did nothing.  Power it on, wait a few
>> seconds to boot, and OVMS crashes immediately.
>> New console log, attached.  It shows the module booting normally (OBDII
>> device not present), followed by the device being attached (indicated in
>> the log), and the subsequent crash.  I removed the device right after the
>> boot started, so as to let the OVMS boot normally.
>> So, clearly the obd2ecu task it is receiving frames on CAN3 just fine,
>> but transmits back out on that same bus aren't working.  Is this something
>> I need to address within obd2ecu, or is it in the core code?  I've not
>> changed obd2ecu in quite some time.
>> Greg
>> Michael Balzer wrote:
>> Fix commit is
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/8fef3f5fb6eec9fca26997e01d9c7d08080cdc06
>> Greg, please test.
>> New build with SPIRAM fix:
>> Am 12.12.19 um 11:17 schrieb Michael Balzer:
>> Last line of a2l was missing:
>> #!/bin/bash
>> elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>> for adr in $* ; do
>>   if [[ "$adr" =~ "elf" ]] ; then
>>     elf="$adr"
>>   else
>>     cmd+=" -ex 'l *${adr/:*/}'"
>>   fi
>> done
>> cmd+=" -ex 'q'"
>> echo "Using elf file: $elf"
>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null
>> Am 12.12.19 um 11:12 schrieb Michael Balzer:
>> Mark,
>> 1) maybe I missed posting my later version of a2l, which automatically
>> strips the stack pointers from the ":" address syntax so you can copy&paste
>> the USB output. Here it is:
>> #!/bin/bash
>> for adr in $* ; do
>>     elf="$adr"
>>   else
>>   fi
>> done
>> cmd+=" -ex 'q'"
>> 2) You're right, the bug is tx_frame with null origin overwriting
>> body.bus in the union. I didn't notice that when checking Marko's
>> submission.
>> tx_frame is a copy of the last frame given to the bus for transmission.
>> The queue msg is gone when the TX done IRQ comes in, and Marko needed a
>> copy of the frame the TX IRQ relates to. I asked him (see PR discussion),
>> he checked and confirmed that all TX is done sequentially, so a single
>> buffer is sufficient.
>> Swapping the lines would work. The frame.origin also shouldn't be null,
>> but the handler should tolerate that. …oops, tx_frame also doesn't get
>> initialized in the canbus constructor, so there's also potentially garbage
>> in tx_frame if due to some bug a TX IRQ is generated or processed without a
>> previous tx.
>> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
>> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>> Two issues:
>> *1] A2L*
>> My a2l is this:
>> #!/bin/bash
>> elf=3.2.007.ovms3.elf
>> for adr in $* ; do
>>     elf="$adr"
>>   else
>>     cmd+=" -ex 'l *$adr'"
>>   fi
>> done
>> cmd+=" -ex 'q'"
>> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is
>> in "
>> When I run it, I get:
>> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>> Using elf file: 3.2.007.ovms3.elf
>> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf  -ex 'l
>> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>> And a manual run gives:
>> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf  -ex 'l
>> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>> Junk at end of line specification.
>> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>> (gdb) l *0x400d5e4c:0x3ffc5c40
>> (gdb) l *0x7ffffffd:0x3ffc5c90
>> (gdb) quit
>> *2] Frame origin*
>> Regarding the CAN_txcallback, I think you are correct. And both
>> generators of that message set the frame correctly. So my initial thought
>> was that it is either a memory corruption, or somewhere else sending a
>> frame with garbage data.
>> I do see this technique used in both the mcp2515 and esp32can drivers:
>> msg.body.bus = me;
>> msg.body.frame = me->tx_frame;
>> I don’t normally just copy structures over like that. I memcpy() them,
>> but I guess it must work. However, as our CAN_queue_msg_t is a union of
>> CAN_frame_t (frame, with first member of the structure a canbus*) and
>> 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus
>> will get overwritten with whatever is in msg.body.frame.origin. I can’t see
>> anywhere that tx_frame.origin is set - which is scary because that would
>> mean it is always random junk.
>> Maybe it works if tx_frame.origin is set to the bus before anything else,
>> but not in Greg’s circumstances where something else arrives first. Perhaps
>> related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I
>> don’t really understand the tx_frame approach at all, and why the frame is
>> just not passed on the queue.
>> // CAN Frame
>> // Note: Take care changing this structure, as it is a union with
>> // CAN_log_message_t and position of 'origin' is fixed.
>> struct CAN_frame_t
>>   canbus*     origin;                   // Origin of the frame
>>   CanFrameCallback * callback;          // Frame-specific callback. Is
>> called when this frame is successfully sent (or sending failed)
>>   CAN_FIR_t   FIR;                      // Frame information record
>>   uint32_t    MsgID;                    // Message ID
>>   union
>>     uint8_t   u8[8];                    // Payload byte access
>>     uint32_t  u32[2];                   // Payload u32 access (Att:
>> little endian!)
>>     uint64_t  u64;                      // Payload u64 access (Att:
>> little endian!)
>>     } data;
>>   esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0);  // bus:
>> NULL=origin
>> // CAN message
>> typedef struct
>>   CAN_queue_type_t type;
>>   union
>>     CAN_frame_t frame;  // CAN_frame
>>     canbus* bus;
>>     } body;
>>   } CAN_queue_msg_t;
>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or
>> am I missing something…
>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> Mark,
>> good example why not to use addr2line: I think that result is wrong. a2l
>> uses gdb which gives:
>> tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>> Using elf file: tmp/3.2.007.ovms3.elf
>> 0x400d5e4c is in CAN_rxtask(void*)
>> (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>> 726                } while (loop);
>> 727              break;
>> 728              }
>> 731              break;
>> …and that actually makes sense and matches the register dump.
>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's
>> got a CAN_txcallback msg without a bus.
>> Hardening the rxtask against null here would probably avoid the crash,
>> but I don't see yet how that could be possible.
>> Both esp32can and mcp2515 set the bus field to their object addresses,
>> which cannot be null.
>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>> Can’t get a2l working at the moment. The addr2line gives:
>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>> That is:
>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>   MyCan.LogInfo(this, type, text);    <—— HERE
>> ELF is at:
>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de> wrote:
>> Mark,
>> Greg uses your build, the crash point seems to be consistent, can you
>> post the a2l on this?
>> PS: Greg, would you mind switching to EAP to beta test future releases?
>> Am 11.12.19 um 04:33 schrieb Greg D.:
>> Hi folks,
>> Well, the module updated to 3.2.007 last night.  I just checked on it,
>> and it appears that it didn't exactly survive.  Crashed while running
>> the autoconfig script.  Log with two cycles attached.
>> I tried renaming the /store/events directory to /store/was_events since
>> it seems like Duktape was getting in the way, but that didn't resolve
>> the crash.  I manually enabled wifi so I could manage the module, and
>> moved it back to 3.2.005 from the other partition.  Seems stable again.
>> The car is going into the Service Center tomorrow (the perennial issue
>> with 1146 alerts), so I need to have the module stable so that I can
>> keep an eye on it.  Going to leave it on 3.2.005 for now, unless someone
>> has a quick fix in the next few hours...
>> Otherwise, any ideas for troubleshooting after I get the car back back
>> (hopefully end of day)?
>> Greg
>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Üdvözlettel:
> Kovács Tamás
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191216/357a9431/attachment.htm>
