[Ovmsdev] 3.2.008
Fri Dec 13 16:35:04 HKT 2019
Mark,
having a look at Greg's new report now, which differs from the first. Please wait for my results.
Am 13.12.19 um 06:05 schrieb Mark Webb-Johnson:
> Michael,
> It all looks good.
> I have tagged this as 3.2.008, and sent it to EAP. Plan is to send to MAIN this weekend.
> The rush is to avoid another of the new 8MB PSRAM users updating OTA and messed up their module. Any objections?
>> On 12 Dec 2019, at 6:12 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> 2) You're right, the bug is tx_frame with null origin overwriting body.bus in the union. I didn't notice that when checking Marko's submission.
>> tx_frame is a copy of the last frame given to the bus for transmission. The queue msg is gone when the TX done IRQ comes in, and Marko needed a copy of the
>> frame the TX IRQ relates to. I asked him (see PR discussion), he checked and confirmed that all TX is done sequentially, so a single buffer is sufficient.
>> Swapping the lines would work. The frame.origin also shouldn't be null, but the handler should tolerate that. …oops, tx_frame also doesn't get initialized in
>> the canbus constructor, so there's also potentially garbage in tx_frame if due to some bug a TX IRQ is generated or processed without a previous tx.
>> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
>> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>>> Two issues:
>>> _*1] A2L*_
>>> My a2l is this:
>>>     #!/bin/bash
>>>     elf=3.2.007.ovms3.elf
>>>     for adr in $* ; do
>>>       if [[ "$adr" =~ "elf" ]] ; then
>>>         elf="$adr"
>>>       else
>>>         cmd+=" -ex 'l *$adr'"
>>>       fi
>>>     done
>>>     cmd+=" -ex 'q'"
>>>     echo "Using elf file: $elf"
>>>     echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>>>     eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
>>> When I run it, I get:
>>>     $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>     Using elf file: 3.2.007.ovms3.elf
>>>     xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf  -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>>> And a manual run gives:
>>>     $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf  -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>>>     Junk at end of line specification.
>>>     $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>>>     GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>>>     (gdb) l *0x400d5e4c:0x3ffc5c40
>>>     (gdb) l *0x7ffffffd:0x3ffc5c90
>>>     (gdb) quit
>>> _*2] Frame origin*_
>>> Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is
>>> either a memory corruption, or somewhere else sending a frame with garbage data.
>>> I do see this technique used in both the mcp2515 and esp32can drivers:
>>>     msg.body.bus = me;
>>>     msg.body.frame = me->tx_frame;
>>> I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t
>>> (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten with
>>> whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk.
>>> Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps
>>> related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just not
>>> passed on the queue.
>>>     // CAN Frame
>>>     // Note: Take care changing this structure, as it is a union with
>>>     // CAN_log_message_t and position of 'origin' is fixed.
>>>     struct CAN_frame_t
>>>       canbus*     origin;                   // Origin of the frame
>>>       CanFrameCallback * callback;          // Frame-specific callback. Is called when this frame is successfully sent (or sending failed)
>>>       CAN_FIR_t   FIR;                      // Frame information record
>>>       uint32_t    MsgID;                    // Message ID
>>>       union
>>>         uint8_t   u8[8];                    // Payload byte access
>>>         uint32_t  u32[2];                   // Payload u32 access (Att: little endian!)
>>>         uint64_t  u64;                      // Payload u64 access (Att: little endian!)
>>>         } data;
>>>       esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0);  // bus: NULL=origin
>>>     // CAN message
>>>     typedef struct
>>>       CAN_queue_type_t type;
>>>       union
>>>         CAN_frame_t frame;  // CAN_frame
>>>         canbus* bus;
>>>         } body;
>>>       } CAN_queue_msg_t;
>>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something…
>>>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> Mark,
>>>> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives:
>>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>> Using elf file: tmp/3.2.007.ovms3.elf
>>>> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>>> 725                  me->IncomingFrame(&msg.body.frame);
>>>> 726                } while (loop);
>>>> 727              break;
>>>> 728              }
>>>> 729            case CAN_txcallback:
>>>> 730              msg.body.bus->TxCallback(&msg.body.frame, true);
>>>> 731              break;
>>>> 732            case CAN_txfailedcallback:
>>>> 733              msg.body.bus->TxCallback(&msg.body.frame, false);
>>>> 734              msg.body.bus->LogStatus(CAN_LogStatus_Error);
>>>> …and that actually makes sense and matches the register dump.
>>>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus.
>>>> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible.
>>>> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null.
>>>> Regards,
>>>> Michael
>>>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>>>>> Can’t get a2l working at the moment. The addr2line gives:
>>>>>     addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>>     /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>>>>> That is:
>>>>>     void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>>>>       MyCan.LogInfo(this, type, text);    <—— HERE
>>>>> ELF is at:
>>>>>     http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
>>>>> Regards, Mark.
>>>>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>> Mark,
>>>>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
>>>>>> Regards,
>>>>>> Michael
>>>>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>>>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>>>>>> Hi folks,
>>>>>>> Well, the module updated to 3.2.007 last night.  I just checked on it,
>>>>>>> and it appears that it didn't exactly survive.  Crashed while running
>>>>>>> the autoconfig script.  Log with two cycles attached.
>>>>>>> I tried renaming the /store/events directory to /store/was_events since
>>>>>>> it seems like Duktape was getting in the way, but that didn't resolve
>>>>>>> the crash.  I manually enabled wifi so I could manage the module, and
>>>>>>> moved it back to 3.2.005 from the other partition.  Seems stable again.
>>>>>>> The car is going into the Service Center tomorrow (the perennial issue
>>>>>>> with 1146 alerts), so I need to have the module stable so that I can
>>>>>>> keep an eye on it.  Going to leave it on 3.2.005 for now, unless someone
>>>>>>> has a quick fix in the next few hours...
>>>>>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>>>>>> (hopefully end of day)?
>>>>>>> Greg
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191213/4bd54eee/attachment.htm>
