[Ovmsdev] version 3.2.007: Crash on boot
Greg D.
gregd2350 at gmail.com
Fri Dec 13 14:09:08 HKT 2019
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191212/c31c3354/attachment.htm>
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.12.12 21:49:33 =~=~=~=~=~=~=~=~=~=~=~=
OVMS#
OVMS# module reset
[K[0;32mI (480636) script: Duktape: Compacting DukTape memory[0m
OVMS# module reset[K
Resetting system...
OVMS#
[K[0;32mI (481876) boot: Shutting down for restart...[0m
[0;32mI (481886) esp32wifi: Stopping WIFI station[0m
I (481886) wifi: state: run -> init (0)
I (481886) wifi: pm stop, total sleep time: 435723370 us / 476801654 us
I (481886) wifi: new:<6,0>, old:<6,0>, ap:<6,2>, sta:<6,0>, prof:6
[0;32mI (481896) ovms-server-v2: Status: Disconnected[0m
[0;31mE (481896) event: system_event_ap_stop_handle_default 223 esp_wifi_internal_reg_rxcb ret=0x3014[0m
I (481906) wifi: flush txq
I (481906) wifi: stop sw txq
I (481906) wifi: lmac stop hw txq
[0;32mI (481916) esp32wifi: Powering down WIFI driver[0m
I (481916) wifi: Deinit lldesc rx mblock:16
[0;32mI (481936) sdcard: Unmounting SDCARD for reset[0m
[0;32mI (481936) simcom: State: Enter PoweringOff state[0m
[0;32mI (481936) gsm-ppp: Shutting down (soft)...[0m
[0;32mI (481946) gsm-ppp: PPP is shutdown[0m
[0;32mI (481946) gsm-nmea: Shutdown (direct)[0m
[0;32mI (481956) simcom: Power Cycle[0m
OVMS# [K
[K[0;32mI (482966) netmanager: WIFI client stop[0m
[0;32mI (482966) netmanager: Interface priority is pp3 (0.0.0.0/255.255.255.255 gateway 0.0.0.0)[0m
[0;32mI (482966) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (482966) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (482966) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority[0m
[0;32mI (482986) esp32wifi: STA disconnected with reason 8 = ASSOC_LEAVE[0m
[0;32mI (483016) netmanager: WIFI access point is down[0m
[0;32mI (483016) esp32wifi: AP stopped[0m
[0;32mI (483026) sdcard: unmount done[0m
[0;32mI (483026) netmanager: MODEM down (with WIFI client down): network connectivity has been lost[0m
[0;32mI (483036) ovms-server-v2: Status: Server is ready to start[0m
[0;32mI (483056) time: Network was reconfigured: restarting SNTP client[0m
[0;32mI (483056) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (483056) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds[0m
[0;32mI (483086) time: Stopping SNTP client[0m
[0;32mI (483146) webserver: Stopping Web Server[0m
[0;32mI (483146) ssh: Stopping SSH Server[0m
OVMS# [K
[K[0;32mI (483626) ovms-server-v2: Status: Server is ready to start[0m
OVMS# [K
[K[0;32mI (486626) boot: Restart in 55 seconds (1 pending)...[0m
OVMS# [K
[K[0;32mI (491626) simcom: State timeout, transition to 1[0m
[0;32mI (491626) simcom: State: Enter CheckPowerOff state[0m
[0;32mI (491626) boot: Restart in 50 seconds (1 pending)...[0m
OVMS# [K
[K[0;32mI (493946) gsm-ppp: StatusCallBack: User Interrupt[0m
[0;32mI (493946) gsm-ppp: PPP connection has been closed[0m
OVMS# [K
[K[0;32mI (496626) boot: Restart in 45 seconds (1 pending)...[0m
OVMS# [K
[K[0;32mI (501626) boot: Restart in 40 seconds (1 pending)...[0m
OVMS# [K
[K[0;32mI (506626) simcom: State timeout, transition to 13[0m
[0;32mI (506626) simcom: State: Enter PoweredOff state[0m
[0;32mI (506626) gsm-mux: Stop MUX[0m
[0;32mI (506626) boot: Restart now[0m
OVMS# [Kets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4796
load:0x40078000,len:0
load:0x40078000,len:14896
entry 0x40078d74
[0;32mI (920) psram: This chip is ESP32-D0WD[0m
[0;32mI (920) spiram: Found 32MBit SPI RAM device[0m
[0;32mI (920) spiram: SPI RAM mode: flash 40m sram 40m[0m
[0;32mI (923) spiram: PSRAM initialized, cache is in low/high (2-core) mode.[0m
[0;32mI (930) cpu_start: Pro cpu up.[0m
[0;32mI (934) cpu_start: Application information:[0m
[0;32mI (939) cpu_start: Project name: ovms3[0m
[0;32mI (943) cpu_start: App version: 3.2.007-102-g07440970[0m
[0;32mI (950) cpu_start: Compile time: Dec 12 2019 11:58:47[0m
[0;32mI (956) cpu_start: ELF file SHA256: d151e36378c6be55...[0m
[0;32mI (962) cpu_start: ESP-IDF: v3.3-beta3-774-g6652269e1[0m
[0;32mI (968) cpu_start: Starting app cpu, entry point is 0x40081820[0m
[0;32mI (960) cpu_start: App cpu up.[0m
[0;32mI (1853) spiram: SPI SRAM memory test OK[0m
[0;32mI (1854) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1854) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (1861) heap_init: At 3FFBED50 len 000212B0 (132 KiB): DRAM[0m
[0;32mI (1866) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (1873) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (1880) heap_init: At 4009918C len 00006E74 (27 KiB): IRAM[0m
[0;32mI (1886) cpu_start: Pro cpu start user code[0m
[0;32mI (1890) spiram: Adding pool of 4096K of external SPI memory to heap allocator[0m
[0;32mI (19) ovms_main: Set default logging level for * to INFO[0m
[0;32mI (20) command: Initialising COMMAND (1000)[0m
[0;32mI (21) boot: Initialising BOOT (1100)[0m
[0;32mI (24) boot: Boot #50 reasons for CPU0=12 and CPU1=12[0m
[0;32mI (29) boot: Reset reason Exception/panic (4)[0m
[0;32mI (35) boot: Soft reset by user[0m
[0;32mI (38) events: Initialising EVENTS (1200)[0m
[0;32mI (43) config: Initialising CONFIG (1400)[0m
[0;32mI (48) time: Initialising TIME (1500)[0m
[0;32mI (53) script: Initialising SCRIPTS (1600)[0m
[0;32mI (57) script: Using DUKTAPE javascript engine[0m
[0;32mI (63) metrics: Initialising METRICS (1810)[0m
[0;32mI (67) metrics: Expanding DUKTAPE javascript engine[0m
[0;32mI (77) notify: Initialising NOTIFICATIONS (1820)[0m
[0;32mI (79) notify: Registered notification type info[0m
[0;32mI (83) notify: Registered notification type error[0m
[0;32mI (88) notify: Registered notification type alert[0m
[0;32mI (94) notify: Registered notification type data[0m
[0;32mI (99) notify: Registered notification type stream[0m
[0;32mI (104) notify: Expanding DUKTAPE javascript engine[0m
[0;32mI (110) location: Initialising LOCATIONS (1900)[0m
[0;32mI (117) location: Expanding DUKTAPE javascript engine[0m
[0;32mI (121) vehicle: Initialising VEHICLE Factory (2000)[0m
[0;32mI (128) pcp: Initialising POWER (4000)[0m
[0;32mI (131) max7317: Initialising MAX7317 EGPIO (4200)[0m
[0;32mI (137) sdcard: Initialising SD CARD (4400)[0m
[0;32mI (142) ota: Initialising OTA (4400)[0m
[0;32mI (146) canformat: Initialising CAN Format Factory (4500)[0m
[0;32mI (152) canformat-crtd: Registering CAN Format: CRTD (4505)[0m
[0;32mI (158) canformat-gvret: Registering CAN Format: GVRET (4505)[0m
[0;32mI (164) canformat-lawricel: Registering CAN Format: LAWRICEL (4505)[0m
[0;32mI (171) canformat-pcap: Registering CAN Format: PCAP (4505)[0m
[0;32mI (178) canformat-raw: Registering CAN Format: RAW (4505)[0m
[0;32mI (184) can: Initialising CAN (4510)[0m
[0;32mI (191) dbc-app: Initialising DBC (4520)[0m
[0;32mI (194) canlog: Initialising CAN logging (4550)[0m
[0;32mI (198) canlog-monitor: Initialising CAN logging to MONITOR (4560)[0m
[0;32mI (205) canlog-tcpclient: Initialising CAN logging as TCP client (4560)[0m
[0;32mI (213) canlog-tcpserver: Initialising CAN logging as TCP server (4560)[0m
[0;32mI (220) canlog-vfs: Initialising CAN logging to VFS (4560)[0m
[0;32mI (226) canplay: Initialising CAN play framework (4570)[0m
[0;32mI (231) canplay-vfs: Initialising CAN playing from VFS (4580)[0m
[0;32mI (238) simcom: Initialising SIMCOM (4600)[0m
[0;32mI (243) test: Initialising TEST (5000)[0m
[0;32mI (247) module: Initialising MODULE (5100)[0m
[0;32mI (252) vfs: Initialising VFS (5200)[0m
[0;32mI (256) ovms-server: Initialising OVMS Server (6000)[0m
[0;32mI (262) ovms-server-v2: Initialising OVMS V2 Server (6100)[0m
[0;32mI (268) ovms-server-v3: Initialising OVMS V3 Server (6200)[0m
[0;32mI (274) obd2ecu: Initialising OBD2ECU (7000)[0m
[0;32mI (279) canopen: Initialising CANopen (7000)[0m
[0;32mI (285) esp32wifi: Initialising ESP32WIFI (8000)[0m
[0;32mI (289) ovms-mdns: Initialising MDNS (8100)[0m
[0;32mI (294) webserver: Initialising WEBSERVER (8200)[0m
[0;32mI (302) ssh: Initialising SSH (8300)[0m
[0;32mI (304) powermgmt: Initialising POWERMGMT (8500)[0m
[0;32mI (309) re: Initialising RE Tools (8800)[0m
[0;32mI (315) pushover: Initialising Pushover client (8800)[0m
[0;32mI (320) netmanager: Initialising NETMANAGER (8999)[0m
[0;32mI (328) v-zeva: Registering Vehicle: ZEVA (9000)[0m
[0;32mI (330) v-voltampera: Registering Vehicle: Volt/Ampera (9000)[0m
[0;32mI (336) v-track: Registering Vehicle: TRACK (9000)[0m
[0;32mI (342) v-thinkcity: Registering Vehicle: THINK CITY (9000)[0m
[0;32mI (348) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)[0m
[0;32mI (355) v-teslamodels: Registering Vehicle: Tesla Model S (9000)[0m
[0;32mI (362) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)[0m
[0;32mI (368) v-smarteq: Registering Vehicle: SMART EQ (9000)[0m
[0;32mI (374) v-smarted: Registering Vehicle: SMART ED (9000)[0m
[0;32mI (380) v-zoe: Registering Vehicle: Renault Zoe (9000)[0m
[0;32mI (386) v-twizy: Registering Vehicle: Renault Twizy (9000)[0m
[0;32mI (392) v-obdii: Registering Vehicle: OBDII (9000)[0m
[0;32mI (398) v-none: Registering Vehicle: NONE (9000)[0m
[0;32mI (403) v-nissanleaf: Registering Vehicle: Nissan Leaf (9000)[0m
[0;32mI (409) v-mitsubishi: Registering Vehicle: Mitsubishi iMiEV, Citroen C-Zero, Peugeot iOn (9000)[0m
[0;32mI (419) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)[0m
[0;32mI (425) v-kianiroev: Registering Vehicle: Kia Niro / Hyundai Kona EV (9000)[0m
[0;32mI (433) v-fiat500e: Registering Vehicle: FIAT 500e (9000)[0m
[0;32mI (439) v-demo: Registering Vehicle: DEMO (9000)[0m
[0;32mI (444) vehicle_dbc: Registering Vehicle: DBC based vehicle (9000)[0m
[0;32mI (451) version: Initialising Versioning (9900)[0m
[0;32mI (460) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (0) script: Duktape: Scripting task is running[0m
[0;32mI (546) ovms_main: Executing on CPU core 0[0m
[0;32mI (546) ovms_main: Mounting CONFIG...[0m
[0;32mI (596) ovms_main: Configure logging...[0m
[0;33mW (606) webserver: UpdateGlobalAuthFile: no password set => no auth for web console[0m
[0;32mI (606) ovms_main: Registering default configs...[0m
[0;32mI (606) ovms_main: Starting HOUSEKEEPING...[0m
[0;32mI (616) housekeeping: Initialising HOUSEKEEPING Framework...[0m
[0;32mI (616) housekeeping: Executing on CPU core 1[0m
[0;32mI (626) housekeeping: reset_reason: cpu0=12, cpu1=12[0m
[0;32mI (626) housekeeping: Initialising WATCHDOG...[0m
[0;32mI (636) housekeeping: Starting PERIPHERALS...[0m
[0;32mI (636) peripherals: Initialising OVMS Peripherals...[0m
[0;32mI (646) peripherals: TCP/IP Adaptor[0m
[0;32mI (646) peripherals: ESP32 system[0m
[0;32mI (656) peripherals: SPI bus[0m
[0;32mI (656) peripherals: MAX7317 I/O Expander[0m
[0;32mI (666) peripherals: ESP32 CAN[0m
[0;32mI (666) peripherals: ESP32 WIFI[0m
[0;31mE (666) can: can1: intr=1 rxpkt=0 txpkt=0 errflags=0x40caa rxerr=1 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0[0m
[0;32mI (676) peripherals: ESP32 ADC[0m
[0;32mI (686) peripherals: MCP2515 CAN 1/2[0m
[0;32mI (686) mcp2515: can2: SetPowerMode off[0m
[0;32mI (776) peripherals: MCP2515 CAN 2/2[0m
[0;32mI (776) mcp2515: can3: SetPowerMode off[0m
[0;32mI (856) peripherals: SD CARD[0m
[0;32mI (856) peripherals: SIMCOM MODEM[0m
[0;32mI (856) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (866) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (876) uart: queue free spaces: 50[0m
[0;32mI (876) ext12v: Powering off external 12V devices[0m
[0;32mI (886) housekeeping: Auto init max7317 (free: 182492 bytes)[0m
[0;32mI (886) housekeeping: Auto init ext12v (free: 182492 bytes)[0m
[0;32mI (896) ext12v: Powering on external 12V devices[0m
[0;32mI (896) housekeeping: Auto init dbc (free: 182492 bytes)[0m
[0;32mI (906) housekeeping: Auto init wifi (free: 182492 bytes)[0m
[0;32mI (916) esp32wifi: Powering up WIFI driver[0m
I (946) wifi: wifi driver task: 3ffd44fc, prio:23, stack:3584, core=0
[0;32mI (946) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
[0;32mI (956) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (976) wifi: wifi firmware version: aeed694
I (976) wifi: config NVS flash: enabled
I (976) wifi: config nano formating: disabled
I (976) wifi: Init dynamic tx buffer num: 16
I (986) wifi: Init data frame dynamic rx buffer num: 16
I (986) wifi: Init management frame dynamic rx buffer num: 16
I (996) wifi: Init management short buffer num: 32
I (996) wifi: Init static rx buffer size: 2212
I (1006) wifi: Init static rx buffer num: 16
I (1006) wifi: Init dynamic rx buffer num: 16
[0;32mI (1816) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0[0m
I (1816) wifi: mode : sta (30:ae:a4:43:92:88) + softAP (30:ae:a4:43:92:89)
I (1826) wifi: Total power save buffer number: 8
I (1826) wifi: Init max length of beacon: 752/752
I (1836) wifi: Init max length of beacon: 752/752
[0;32mI (1836) housekeeping: Auto init modem (free: 131860 bytes)[0m
[0;32mI (1846) simcom: State: Enter PoweringOn state[0m
[0;32mI (1846) simcom: Power Cycle[0m
[0;32mI (2846) housekeeping: Auto init vehicle (free: 131068 bytes)[0m
[0;32mI (2846) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module[0m
[0;32mI (2856) housekeeping: Auto init obd2ecu (free: 120368 bytes)[0m
[0;32mI (2956) mcp2515: can3: SetPowerMode on[0m
[0;31mE (2966) can: can1: intr=7 rxpkt=6 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0[0m
[0;32mI (3056) housekeeping: Auto init server v2 (free: 113148 bytes)[0m
[0;32mI (3056) ovms-server-v2: OVMS Server V2 registered metric modifier is #1[0m
[0;32mI (3066) ovms-server-v2: Status: Server has been started[0m
[0;32mI (3066) ovms-server-v2: OVMS Server v2 running[0m
[0;32mI (3076) housekeeping: Auto init server v3 (free: 113040 bytes)[0m
[0;32mI (3076) housekeeping: Auto init javascript (free: 113040 bytes)[0m
[0;32mI (3086) housekeeping: Auto init done (free: 113040 bytes)[0m
[0;32mI (3096) housekeeping: Starting USB console...[0m
[0;32mI (3096) uart: queue free spaces: 100[0m
Firmware: 3.2.007-102-g07440970/ota_1/main
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
OVMS#
[K[0;32mI (3116) script: Duktape: Creating heap[0m
[0;32mI (3116) script: Duktape: Initialising module system[0m
[0;31mE (3206) events: SignalEvent: queue overflow, event 'notify.info.charge.done' dropped[0m
[0;31mE (3206) events: SignalEvent: queue overflow, event 'vehicle.charge.mode' dropped[0m
[0;31mE (3236) events: SignalEvent: queue overflow, event 'vehicle.charge.prepare' dropped[0m
[0;31mE (3236) events: SignalEvent: queue overflow, event 'vehicle.charge.pilot.on' dropped[0m
OVMS# [K
[K[0;32mI (3436) netmanager: WIFI access point is up[0m
[0;32mI (3436) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1[0m
[0;32mI (3496) ovms-mdns: Starting MDNS[0m
[0;32mI (3526) webserver: Launching Web Server[0m
[0;32mI (3526) ssh: Launching SSH Server[0m
OVMS# [K
[KI (4286) wifi: ap channel adjust o:1,1 n:6,2
I (4286) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1
OVMS# [K
[KI (5006) wifi: state: init -> auth (b0)
I (5006) wifi: state: auth -> assoc (0)
I (5016) wifi: state: assoc -> run (10)
I (5046) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70
I (5046) wifi: pm start, type: 1
[0;32mI (5056) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2[0m
[0;32mI (5056) event: sta ip: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
[0;32mI (5066) netmanager: WIFI client got IP[0m
[0;32mI (5076) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
OVMS# [K
[K[0;32mI (5626) sdcard: SD CARD has been inserted[0m
[0;32mI (5716) sdcard: mount done[0m
OVMS# [K
[K[0;32mI (8626) netmanager: WIFI client has good signal quality (-85.0 dBm); connect[0m
[0;32mI (8626) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)[0m
[0;32mI (8626) simcom: State: Enter PoweredOn state[0m
[0;32mI (8636) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (8636) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (8636) netmanager: WIFI client up (with MODEM down): starting network with WIFI client[0m
[0;32mI (8666) time: Starting SNTP client[0m
[0;32mI (8676) ovms-server-v2: Status: Network is up, so attempt network connection[0m
OVMS# [K
[K[0;32mI (10626) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B[0m
[0;32mI (10626) ovms-server-v2: Status: Connecting...[0m
OVMS# [K
[K[0;32mI (10976) housekeeping: System considered stable (RAM: 8b=71304-71432 32b=27560)[0m
OVMS# [K
[K[0;32mI (11276) ovms-server-v2: Connection successful[0m
[0;32mI (11276) ovms-server-v2: Status: Logging in...[0m
[0;32mI (11276) ovms-server-v2: Sending server login: MP-C 0 v1t3wM96P8dMQuxap8ztnc HryerO1CXBZ9fRTgydB05w== ROADSTER834B[0m
OVMS# [K
[K[0;32mI (11586) ovms-server-v2: Got server response: MP-S 0 2ljIfUTLHiFXAfCMeaDRB+ KPfCHSPZqweGw3SGo1AqFQ==[0m
[0;32mI (11586) ovms-server-v2: Server token is 2ljIfUTLHiFXAfCMeaDRB+ and digest is KPfCHSPZqweGw3SGo1AqFQ==[0m
[0;32mI (11586) ovms-server-v2: Status: Server authentication ok. Now priming crypto.[0m
[0;32mI (11586) ovms-server-v2: Shared secret key is 2ljIfUTLHiFXAfCMeaDRB+v1t3wM96P8dMQuxap8ztnc (44 bytes)[0m
[0;32mI (11586) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established[0m
[0;32mI (11606) ovms-server-v2: Incoming Msg: MP-0 Z0[0m
[0;32mI (11636) ovms-server-v2: Send MP-0 S93.0,M,1,0,done,standard,157,139,24,0,0,180,0,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0[0m
[0;32mI (11636) ovms-server-v2: Send MP-0 D78,0,5,27,23,24,8067,529655,0,11,18,2,0,0,12.97,0,12.6,0,27,0,0[0m
[0;32mI (11646) ovms-server-v2: Send MP-0 L28.538242,-130.302567,251,0,0,0,0,8067,0,0.398,0,0[0m
[0;32mI (11646) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0[0m
[0;32mI (11646) ovms-server-v2: Send MP-0 F3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),5YJRE1A16A1000834,17,1,TR2N,gregnet[0m
[0;32mI (11656) ovms-server-v2: Send MP-0 PINot charging|SOC: -|ODO: 52965.5M[0m
OVMS# [K
[K[0;32mI (28626) simcom: State: Enter MuxStart state[0m
[0;32mI (28636) gsm-mux: Start MUX[0m
[0;32mI (28636) gsm-mux: Channel #0 is open[0m
[0;32mI (28646) gsm-mux: Channel #1 is open[0m
[0;32mI (28646) gsm-mux: Channel #2 is open[0m
[0;32mI (28656) gsm-mux: Channel #3 is open[0m
[0;32mI (28656) gsm-mux: Channel #4 is open[0m
OVMS# [K
[K[0;32mI (29626) simcom: State: Enter NetWait state[0m
OVMS# [K
[K[0;32mI (39706) simcom: CREG Network Registration: RegisteredRoaming[0m
OVMS# [K
[K[0;32mI (40626) simcom: State: Enter NetStart state[0m
OVMS# [K
[K[0;32mI (41656) simcom: PPP Connection is ready to start[0m
OVMS# [K
[K[0;32mI (42626) simcom: State: Enter NetMode state[0m
[0;32mI (42626) gsm-ppp: Initialising...[0m
OVMS# [K
[K[0;32mI (45186) gsm-ppp: StatusCallBack: None[0m
[0;32mI (45186) gsm-ppp: status_cb: Connected[0m
[0;32mI (45186) gsm-ppp: our_ipaddr = 10.52.33.103[0m
[0;32mI (45186) gsm-ppp: his_ipaddr = 10.64.64.64[0m
[0;32mI (45186) gsm-ppp: netmask = 255.255.255.255[0m
[0;32mI (45186) gsm-ppp: DNS#0 = 212.9.0.135[0m
[0;32mI (45186) gsm-ppp: DNS#1 = 212.9.0.136[0m
[0;32mI (45186) gsm-ppp: our6_ipaddr = ::[0m
[0;32mI (45226) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority[0m
OVMS# [K
[K[0;32mI (60636) script: Duktape: Compacting DukTape memory[0m
OVMS# [K
OVMS#
OVMS# <----------- OBDII module attached at this time. Removed after crash / Reboot
OVMS#
OVMS#
OVMS# Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x3ffcfda0 PS : 0x00060b30 A0 : 0x800da765 A1 : 0x3ffc87a0
A2 : 0x3ffdf764 A3 : 0x3ffc8818 A4 : 0x00000001 A5 : 0x3ffc8818
A6 : 0x18004106 A7 : 0x55010019 A8 : 0x800da749 A9 : 0x3ffc8780
A10 : 0x3ffdf764 A11 : 0x3ffc87a0 A12 : 0x3ffc87a4 A13 : 0x3f40c391
A14 : 0x18004106 A15 : 0x55010019 SAR : 0x00000003 EXCCAUSE: 0x00000014
EXCVADDR: 0x3ffcfda0 LBEG : 0x400908e0 LEND : 0x4009090e LCOUNT : 0x00000000
ELF file SHA256: d151e36378c6be55a27f666546ffda83f5bb9782230cd43031c731f46d49d0b2
Backtrace: 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0 0x400da901:0x3ffc8810
Rebooting...
entry 0x40078d74
[0;32mI (919) psram: This chip is ESP32-D0WD[0m
[0;32mI (938) cpu_start: Project name: ovms3[0m
[0;32mI (949) cpu_start: Compile time: Dec 12 2019 11:58:47[0m
[0;32mI (961) cpu_start: ESP-IDF: v3.3-beta3-774-g6652269e1[0m
[0;32mI (1853) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1860) heap_init: At 3FFBED50 len 000212B0 (132 KiB): DRAM[0m
[0;32mI (1885) cpu_start: Pro cpu start user code[0m
[0;32mI (24) boot: Boot #51 reasons for CPU0=12 and CPU1=12[0m
[0;31mE (34) boot: Crash #1 detected[0m
[0;32mI (78) notify: Registered notification type info[0m
[0;32mI (93) notify: Registered notification type data[0m
[0;32mI (141) ota: Initialising OTA (4400)[0m
[0;32mI (151) canformat-crtd: Registering CAN Format: CRTD (4505)[0m
[0;32mI (177) canformat-raw: Registering CAN Format: RAW (4505)[0m
[0;32mI (183) can: Initialising CAN (4510)[0m
[0;32mI (190) dbc-app: Initialising DBC (4520)[0m
[0;32mI (225) canplay: Initialising CAN play framework (4570)[0m
[0;32mI (261) ovms-server-v2: Initialising OVMS V2 Server (6100)[0m
[0;32mI (314) pushover: Initialising Pushover client (8800)[0m
[0;32mI (341) v-thinkcity: Registering Vehicle: THINK CITY (9000)[0m
[0;32mI (361) v-teslamodel3: Registering Vehicle: Tesla Model 3 (9000)[0m
[0;32mI (397) v-none: Registering Vehicle: NONE (9000)[0m
[0;32mI (418) v-kiasoulev: Registering Vehicle: Kia Soul EV (9000)[0m
[0;32mI (432) v-fiat500e: Registering Vehicle: FIAT 500e (9000)[0m
[0;32mI (438) v-demo: Registering Vehicle: DEMO (9000)[0m
[0;32mI (676) peripherals: MCP2515 CAN 1/2[0m
[0;32mI (676) mcp2515: can2: SetPowerMode off[0m
[0;32mI (766) peripherals: MCP2515 CAN 2/2[0m
[0;32mI (766) mcp2515: can3: SetPowerMode off[0m
[0;32mI (846) peripherals: SD CARD[0m
[0;32mI (846) peripherals: SIMCOM MODEM[0m
[0;32mI (846) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (856) gpio: GPIO[4]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 [0m
[0;32mI (866) uart: queue free spaces: 50[0m
[0;32mI (866) ext12v: Powering off external 12V devices[0m
[0;32mI (876) housekeeping: Auto init max7317 (free: 182492 bytes)[0m
[0;32mI (876) housekeeping: Auto init ext12v (free: 182492 bytes)[0m
[0;32mI (886) ext12v: Powering on external 12V devices[0m
[0;32mI (886) housekeeping: Auto init dbc (free: 182492 bytes)[0m
[0;32mI (896) housekeeping: Auto init wifi (free: 182492 bytes)[0m
[0;32mI (906) esp32wifi: Powering up WIFI driver[0m
I (936) wifi: wifi driver task: 3ffd44fc, prio:23, stack:3584, core=0
[0;32mI (936) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (966) wifi: wifi firmware version: aeed694
I (966) wifi: config NVS flash: enabled
I (966) wifi: config nano formating: disabled
I (966) wifi: Init dynamic tx buffer num: 16
I (976) wifi: Init data frame dynamic rx buffer num: 16
I (976) wifi: Init management frame dynamic rx buffer num: 16
I (986) wifi: Init management short buffer num: 32
I (986) wifi: Init static rx buffer size: 2212
I (996) wifi: Init static rx buffer num: 16
I (996) wifi: Init dynamic rx buffer num: 16
[0;32mI (1806) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0[0m
I (1816) wifi: Total power save buffer number: 8
I (1816) wifi: Init max length of beacon: 752/752
[0;32mI (1826) housekeeping: Auto init modem (free: 131860 bytes)[0m
[0;32mI (1836) simcom: State: Enter PoweringOn state[0m
[0;32mI (1836) simcom: Power Cycle[0m
[0;32mI (2506) simcom: State: Enter PoweredOn state[0m
[0;31mE (3076) can: can1: intr=6 rxpkt=5 txpkt=0 errflags=0x80c00 rxerr=0 txerr=0 rxovr=0 txovr=0 txdelay=0 wdgreset=0 errreset=0[0m
[0;32mI (3096) housekeeping: Auto init done (free: 113040 bytes)[0m
[0;32mI (3106) housekeeping: Starting USB console...[0m
[0;32mI (3106) uart: queue free spaces: 100[0m
OVMS#
[K[0;32mI (3126) script: Duktape: Creating heap[0m
[0;32mI (3126) script: Duktape: Initialising module system[0m
OVMS# [K
[K[0;32mI (3426) netmanager: WIFI access point is up[0m
[0;32mI (3426) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:43:92:89, IP: 192.168.4.1[0m
[0;32mI (3486) ovms-mdns: Starting MDNS[0m
[0;32mI (3516) webserver: Launching Web Server[0m
[0;32mI (3516) ssh: Launching SSH Server[0m
OVMS# [K
[KI (4276) wifi: ap channel adjust o:1,1 n:6,2
I (4276) wifi: new:<6,0>, old:<1,0>, ap:<6,2>, sta:<6,0>, prof:1
OVMS# [K
[KI (4996) wifi: state: init -> auth (b0)
I (5036) wifi: connected with gregnet, channel 6, HT20, bssid = 40:b0:76:32:ea:70
I (5036) wifi: pm start, type: 1
[0;32mI (5046) esp32wifi: STA connected with SSID: gregnet, BSSID: 40:b0:76:32:ea:70, Channel: 6, Auth: WPA2[0m
[0;32mI (5066) esp32wifi: STA got IP with SSID 'gregnet' AP 40:b0:76:32:ea:70: MAC: 30:ae:a4:43:92:88, IP: 10.30.1.105, mask: 255.255.255.0, gw: 10.30.1.1[0m
OVMS# [K
OVMS# [K
[K[0;32mI (7626) netmanager: WIFI client has good signal quality (-86.4 dBm); connect[0m
[0;32mI (7626) netmanager: Interface priority is st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)[0m
[0;32mI (7636) netmanager: Set DNS#0 9.9.9.9[0m
[0;32mI (7636) netmanager: Set DNS#1 8.8.8.8[0m
[0;32mI (7636) netmanager: WIFI client up (with MODEM down): starting network with WIFI client[0m
[0;32mI (7676) time: Starting SNTP client[0m
[0;32mI (7686) ovms-server-v2: Status: Network is up, so attempt network connection[0m
OVMS# [K
[K[0;32mI (9626) ovms-server-v2: Connection is api.openvehicles.com:6867 ROADSTER834B[0m
[0;32mI (9626) ovms-server-v2: Status: Connecting...[0m
OVMS# [K
[K[0;32mI (10096) ovms-server-v2: Connection successful[0m
[0;32mI (10106) ovms-server-v2: Status: Logging in...[0m
[0;32mI (10106) ovms-server-v2: Sending server login: MP-C 0 GVOcBBICxKcLy+SD4s/fD5 YfmEjLfGzvoXXZGuw01D6Q== ROADSTER834B[0m
OVMS# [K
[K[0;32mI (10406) ovms-server-v2: Got server response: MP-S 0 qWTLyMqCU4TMRzDXBGb24H GWKItB3ws/s2NJAM2v959A==[0m
[0;32mI (10406) ovms-server-v2: Server token is qWTLyMqCU4TMRzDXBGb24H and digest is GWKItB3ws/s2NJAM2v959A==[0m
[0;32mI (10416) ovms-server-v2: Status: Server authentication ok. Now priming crypto.[0m
[0;32mI (10416) ovms-server-v2: Shared secret key is qWTLyMqCU4TMRzDXBGb24HGVOcBBICxKcLy+SD4s/fD5 (44 bytes)[0m
[0;32mI (10416) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established[0m
[0;32mI (10436) ovms-server-v2: Incoming Msg: MP-0 Z0[0m
[0;32mI (10626) ovms-server-v2: Send MP-0 S93.0,M,1,0,done,standard,157,139,24,0,0,180,0,4,0,0,0,0,0.00,0,0,0,0,0,0,0,0,0,0,0,0,0.00,0.00,0[0m
[0;32mI (10636) ovms-server-v2: Send MP-0 D78,0,5,0,0,0,8067,529655,0,10,0,2,0,0,13.01,0,12.6,0,0,0,0[0m
[0;32mI (10636) ovms-server-v2: Send MP-0 L28.538242,-130.302567,251,0,0,0,0,8067,0,0.398,0,0[0m
[0;32mI (10636) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0[0m
[0;32mI (10646) ovms-server-v2: Send MP-0 F3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),5YJRE1A16A1000834,17,1,TR2N,gregnet[0m
[0;32mI (10646) ovms-server-v2: Send MP-0 PINot charging|SOC: -[0m
[0;32mI (10676) housekeeping: System considered stable (RAM: 8b=71432-71868 32b=27560)[0m
OVMS# [K
[K[0;32mI (11626) ovms-server-v2: Send MP-0 h1,0,*-OVM-DebugCrash,0,2592000,3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14),51,Crash,12,12,1,0,InstrFetchProhibited,0,0x3ffcfda0 0x00060b30 0x800da765 0x3ffc87a0 0x3ffdf764 0x3ffc8818 0x00000001 0x3ffc8818 0x18004106 0x55010019 0x800da749 0x3ffc8780 0x3ffdf764 0x3ffc87a0 0x3ffc87a4 0x3f40c391 0x18004106 0x55010019 0x00000003 0x00000014 0x3ffcfda0 0x400908e0 0x4009090e 0x00000000 ,0x3ffcfda0 0x400da762 0x400da95b 0x400da901 ,4,Exception/panic[0m
OVMS# [K
[K[0;32mI (11946) ovms-server-v2: Incoming Msg: MP-0 h1[0m
OVMS# [K
[K[0;32mI (20626) simcom: State timeout, transition to 2[0m
[0;32mI (20626) simcom: State: Enter PoweringOn state[0m
[0;32mI (20626) simcom: Power Cycle[0m
OVMS# [K
[K[0;32mI (27416) simcom: State: Enter PoweredOn state[0m
OVMS# [K
