[Ovmsdev] 3.2.006 Release to Early Access Program
Mon Dec 9 20:51:52 HKT 2019
Dito.
Am 09.12.19 um 13:43 schrieb Mark Webb-Johnson:
> OK. I tagged it 3.2.007 and released to both EAP and MAIN.
> Regards, Mark
>> On 9 Dec 2019, at 4:04 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> OK, and we should include my two minor commits from saturday. I've already done so on my "eap" release.
>> The web shell commit is just convenience, but the missing duktape garbage collection had led to out of memory crashes before. With the gc running once per
>> minute, memory usage is stable.
>> Am 09.12.19 um 02:17 schrieb Mark Webb-Johnson:
>>> OK to release this everywhere (to main)? I will release mine at about 12:00 midday UTC today.
>>>> On 30 Nov 2019, at 4:37 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> https://dexters-web.de/firmware-release-3.2.006-text_93.htm
>>>> Regards,
>>>> Michael
>>>> Am 30.11.19 um 04:48 schrieb Mark Webb-Johnson:
>>>>> https://www.openvehicles.com/node/2346
>>>>> Today, we are pleased to release v3.2.006 to Early Access Program. A summary of the major changes is here:
>>>>> 2019-11-30 MWJ 3.2.006 OTA release
>>>>> - Web UI: Calibration and configuration aid for 12v monitor
>>>>> - Log monitoring via web shell
>>>>> - EGPIO/MAX7317: Port input monitoring, metrics, events, documentation
>>>>> - Powermgmt: New automatic power management module
>>>>> - Scripting: OvmsMetrics.AsJSON(), OvmsEvents, and OvmsNotify added
>>>>> - Logging: file logging moved to dedicated task (improved performance)
>>>>> - SWCAN: Support for add-on SWCAN module
>>>>> (see https://github.com/mjuhanne/OVMS-SWCAN)
>>>>> - Pushover: New Pushover notification framework support
>>>>> - SIMCOM: Allow user to set custom SIM PIN code
>>>>> - Metrics: 'metric list -s' shows metric age and staleness
>>>>> - Others: Factory reset from web/remote shell by
>>>>> "module factory reset -noconfirm"
>>>>> - Renault Zoe: Basic Metrics and charging status added, trip notify,
>>>>> web config for battery capacity
>>>>> - Volt/Ampera: Major update (including web config, SWCAN support, etc)
>>>>> - Twizy: Send custom OBD2 requests, output response as hex dump
>>>>> - Immediate tuning metrics updates (was delegated to ticker before)
>>>>> For full detail on all changes, check the GitHub revision history. The v3 modules can be updated over the air (wifi), via SD CARD, or over USB - all
>>>>> without requiring special hardware programmers like the PICKIT used for v2. The simplest way to update the module firmware is to connect it as a client to
>>>>> your wifi network (or phone hotspot), and then use the web interface Config / Firmware / Flash-from-Web; that will show you the version you are running,
>>>>> as well as the latest version available for update. One click on 'Flash now' and the update will be downloaded and installed. Alternatively, you can
>>>>> download the firmware update to a file named ovms3.bin in the root directory of a FAT formatted SD CARD and insert the card into the module's slot - the
>>>>> new firmware will be updated automatically and the file renamed ovms3.done to signify completion. This firmware also includes the feature to check for and
>>>>> automatically update to newly available firmware, every night (so long as the vehicle is connected to WiFi). After updating to 3.1.005 or later, you can
>>>>> enable this for future firmware releases with 'config ota auto yes'.
>>>>> You can choose the release level by setting 'config ota tag edge | eap | main', as one of:
>>>>> * edge: Bleeding edge developer nightly-builds
>>>>> * eap: Early Access Program (full releases, but with little public testing)
>>>>> * main: Publicly tested full releases (the most stable)
>>>>> Thank you to all the open source developers who have contributed to this, and previous, releases, and thank you for your support of the project.
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191209/b30c9600/attachment.htm>
