[Ovmsdev] new OVMSv3 rec'd today updated OTA with .008
Wed Dec 18 15:01:18 HKT 2019
It does have 8MB PSRAM:
I (882) spiram: Found 64MBit SPI RAM device
Should be the latest batch of WiFi only devices from Fasttech have the new WROVER module with 8MB PSRAM. The kits with modems are still 4MB.
Regards,  Mark
> On 18 Dec 2019, at 2:58 PM, Dale <dalklein at gmail.com> wrote:
> Hello all,
>        Thank you all for the great work developing OVMS, This is really neat!!
>         I'm not sure if my new v3 hw that arrived today has the larger PSRAM. Maybe this one still has 4Mb, see below?
>         In any case, .008 updated OTA successfully.  Factory image was .002   Just connected it to home wifi.  Nice job everyone!  Thanks!!
> Dale
> From USB connected simple_monitor:
> rst:0x1 (POWERON_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
> configsip: 0, SPIWP:0xee
> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
> mode:DIO, clock div:2
> load:0x3fff0018,len:4
> load:0x3fff001c,len:4796
> load:0x40078000,len:0
> load:0x40078000,len:14896
> entry 0x40078d74
> I (882) psram: This chip is ESP32-D0WD
> I (883) spiram: SPI RAM mode: flash 40m sram 40m
> I (886) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
> I (893) cpu_start: Pro cpu up.
> I (896) cpu_start: Application information:
> I (901) cpu_start: Project name:     ovms3
> I (906) cpu_start: App version:      3.2.008
> I (911) cpu_start: Compile time:     Dec 13 2019 13:04:20
> I (917) cpu_start: ELF file SHA256:  900f0db86fbf6ce9...
> I (923) cpu_start: ESP-IDF:          v3.3-beta3-772-gc3465e0
> I (929) cpu_start: Starting app cpu, entry point is 0x40081668
> I (0) cpu_start: App cpu up.
> I (1804) spiram: SPI SRAM memory test OK
> I (1805) heap_init: Initializing. RAM available for dynamic allocation:
> I (1805) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
> I (1812) heap_init: At 3FFBC540 len 00023AC0 (142 KiB): DRAM
> I (1818) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
> I (1824) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
> I (1831) heap_init: At 40099C2C len 000063D4 (24 KiB): IRAM
> I (1837) cpu_start: Pro cpu start user code
> I (1842) spiram: Adding pool of 4096K of external SPI memory to heap allocator
> I (187) ovms_main: Set default logging level for * to INFO
> I (188) ovms_main: Pre-allocated 2MB of SPIRAM at 0x3f800028 (workaround ESP32 bug)
> I (192) command: Initialising COMMAND (1000)
> I (197) boot: Initialising BOOT (1100)
> I (201) boot: Power cycle reset detected
> I (205) events: Initialising EVENTS (1200)
> I (211) config: Initialising CONFIG (1400)
