[Ovmsdev] version 3.2.007: Crash on boot
Tamás Kovács
kommykt at gmail.com
Wed Dec 18 12:56:31 HKT 2019
I deleted my fork from my github repo, create a new fork from
Open-Vehicle-Monitoring-System-3, now version tagging is fixed.
The crash is my fault I think, missing two row from my code.
In ticker60 I added the following row:
CAN_frame_t frame;
memset(&frame,0,sizeof(frame));
now can't get crash about 24 hour, now testing.
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2019. dec. 16., H,
19:57):
> Yes I merged the fix.
> I don't understand why my version is 3.2.005.
> Now I try to new clone I think.
> I don't know what's this: "or are you on a local spin-off branch of
> 3.2.005". I always create modification on my code then I upload it to my
> git repo and then create a compare with the main open vehicles repo then I
> update my local code in atom with a fetch.
> Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2019. dec. 16., H,
> 18:54):
>> Tamás,
>> I'm confused, and your dropbox files don't help… did you merge the fix
>> and still get the crash?
>> Is your version just off because your repository lacks tags (if so:
>> why?), or are you on a local spin-off branch of 3.2.005?
>> I've got the impression your git repository is messed up. Maybe you
>> should try a new clone?
>> Am 15.12.19 um 20:13 schrieb Tamás Kovács:
>> My code crashed with same error as it described.
>> plus one error: in esp32can.cpp:448
>> The files can access my dropbox folder:
>> https://www.dropbox.com/sh/mowc7hc7zrzszmm/AACO4MAmM1yF3yoXsGoZO6R_a?dl=0
>> Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2019. dec. 13., P,
>> 10:16):
>>> Greg, Mark,
>>> the new crash happened here:
>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>
>>> a2l 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0
>>> 0x400da901:0x3ffc8810
>>> Using elf file:
>>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>>> 0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool)
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866).
>>> 861 {
>>> 862 if (tx)
>>> 863 {
>>> 864 if (frame->callback)
>>> 865 {
>>> 866 (*(frame->callback))(frame, success); // invoke
>>> frame-specific callback function
>>> 867 }
>>> 868 for (auto entry : m_txcallbacks) { // invoke generic tx
>>> callbacks
>>> 869 entry->m_callback(frame, success);
>>> 870 }
>>> 0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool)
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018).
>>> 1013 }
>>> 1014 else
>>> 1015 {
>>> 1016 LogFrame(CAN_LogFrame_TX_Fail, p_frame);
>>> 1017 }
>>> 1018 MyCan.ExecuteCallbacks(p_frame, true, success);
>>> 1019 }
>>> 1020
>>> 1021 /**
>>> 1022 * canbus::Write -- main TX API
>>> 0x400da901 is in CAN_rxtask(void*)
>>> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>> 725 me->IncomingFrame(&msg.body.frame);
>>> 726 } while (loop);
>>> 727 break;
>>> 728 }
>>> 729 case CAN_txcallback:
>>> 730 msg.body.bus->TxCallback(&msg.body.frame, true);
>>> 731 break;
>>> 732 case CAN_txfailedcallback:
>>> 733 msg.body.bus->TxCallback(&msg.body.frame, false);
>>> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
>>> As the frame callback invocation is secured against null, it must have
>>> been a missing initialization of frame.callback. So I checked our source
>>> tree for uses of CAN_frame_t without memset or zero initialization and
>>> found one in obd2ecu::IncomingFrame() -- causing this crash I assume -- and
>>> two more in the can rx/tx shell commands.
>>> Fix is in commit
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/34302254567b15a8c0f9dfb730b5cf24703ac700
>>> …and build in https://ovms.dexters-web.de/firmware/ota/v3.1/edge/
>>> Greg, please test again.
>>> Am 13.12.19 um 07:09 schrieb Greg D.:
>>> Hi Michael,
>>> Ok, so I believe I loaded your Edge build, and the issue remains. To
>>> verify, this is the string reported by the web Status page:
>>> 3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1
>>> Dec 12 2019 11:59:14)
>>> Following my earlier email, I left the configuration as-is, including
>>> launching the obd2ecu task, but with the attached OBDII module removed, and
>>> the crash was resolved. Rebooting the module had it come up running
>>> normally. I then plugged in the OBDII module into the OVMSv3, and OVMS
>>> crashed the instant the first it started polling. The device is a SyncUp
>>> Drive, which is a telematics and WiFi hotspot. Connecting the OBDII device
>>> with 12v power off, as expected, did nothing. Power it on, wait a few
>>> seconds to boot, and OVMS crashes immediately.
>>> New console log, attached. It shows the module booting normally (OBDII
>>> device not present), followed by the device being attached (indicated in
>>> the log), and the subsequent crash. I removed the device right after the
>>> boot started, so as to let the OVMS boot normally.
>>> So, clearly the obd2ecu task it is receiving frames on CAN3 just fine,
>>> but transmits back out on that same bus aren't working. Is this something
>>> I need to address within obd2ecu, or is it in the core code? I've not
>>> changed obd2ecu in quite some time.
>>> Greg
>>> Michael Balzer wrote:
>>> Fix commit is
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/8fef3f5fb6eec9fca26997e01d9c7d08080cdc06
>>> Greg, please test.
>>> New build with SPIRAM fix:
>>> Am 12.12.19 um 11:17 schrieb Michael Balzer:
>>> Last line of a2l was missing:
>>> #!/bin/bash
>>> elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>>> for adr in $* ; do
>>> if [[ "$adr" =~ "elf" ]] ; then
>>> elf="$adr"
>>> else
>>> cmd+=" -ex 'l *${adr/:*/}'"
>>> fi
>>> done
>>> cmd+=" -ex 'q'"
>>> echo "Using elf file: $elf"
>>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null
>>> Am 12.12.19 um 11:12 schrieb Michael Balzer:
>>> Mark,
>>> 1) maybe I missed posting my later version of a2l, which automatically
>>> strips the stack pointers from the ":" address syntax so you can copy&paste
>>> the USB output. Here it is:
>>> #!/bin/bash
>>> for adr in $* ; do
>>> elf="$adr"
>>> else
>>> fi
>>> done
>>> cmd+=" -ex 'q'"
>>> 2) You're right, the bug is tx_frame with null origin overwriting
>>> body.bus in the union. I didn't notice that when checking Marko's
>>> submission.
>>> tx_frame is a copy of the last frame given to the bus for transmission.
>>> The queue msg is gone when the TX done IRQ comes in, and Marko needed a
>>> copy of the frame the TX IRQ relates to. I asked him (see PR discussion),
>>> he checked and confirmed that all TX is done sequentially, so a single
>>> buffer is sufficient.
>>> Swapping the lines would work. The frame.origin also shouldn't be null,
>>> but the handler should tolerate that. …oops, tx_frame also doesn't get
>>> initialized in the canbus constructor, so there's also potentially garbage
>>> in tx_frame if due to some bug a TX IRQ is generated or processed without a
>>> previous tx.
>>> I'll do the fixes… and also rename tx_frame to m_tx_frame for
>>> consistency.
>>> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>>> Two issues:
>>> *1] A2L*
>>> My a2l is this:
>>> #!/bin/bash
>>> elf=3.2.007.ovms3.elf
>>> for adr in $* ; do
>>> elf="$adr"
>>> else
>>> cmd+=" -ex 'l *$adr'"
>>> fi
>>> done
>>> cmd+=" -ex 'q'"
>>> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is
>>> in "
>>> When I run it, I get:
>>> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>> Using elf file: 3.2.007.ovms3.elf
>>> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l
>>> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>>> And a manual run gives:
>>> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l
>>> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>>> Junk at end of line specification.
>>> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>>> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>>> (gdb) l *0x400d5e4c:0x3ffc5c40
>>> (gdb) l *0x7ffffffd:0x3ffc5c90
>>> (gdb) quit
>>> *2] Frame origin*
>>> Regarding the CAN_txcallback, I think you are correct. And both
>>> generators of that message set the frame correctly. So my initial thought
>>> was that it is either a memory corruption, or somewhere else sending a
>>> frame with garbage data.
>>> I do see this technique used in both the mcp2515 and esp32can drivers:
>>> msg.body.bus = me;
>>> msg.body.frame = me->tx_frame;
>>> I don’t normally just copy structures over like that. I memcpy() them,
>>> but I guess it must work. However, as our CAN_queue_msg_t is a union of
>>> CAN_frame_t (frame, with first member of the structure a canbus*) and
>>> 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus
>>> will get overwritten with whatever is in msg.body.frame.origin. I can’t see
>>> anywhere that tx_frame.origin is set - which is scary because that would
>>> mean it is always random junk.
>>> Maybe it works if tx_frame.origin is set to the bus before anything
>>> else, but not in Greg’s circumstances where something else arrives first.
>>> Perhaps related to obd2ecu? I only see tx_frame set in can.cpp
>>> canbus::Write. I don’t really understand the tx_frame approach at all, and
>>> why the frame is just not passed on the queue.
>>> // CAN Frame
>>> // Note: Take care changing this structure, as it is a union with
>>> // CAN_log_message_t and position of 'origin' is fixed.
>>> struct CAN_frame_t
>>> canbus* origin; // Origin of the frame
>>> CanFrameCallback * callback; // Frame-specific callback. Is
>>> called when this frame is successfully sent (or sending failed)
>>> CAN_FIR_t FIR; // Frame information record
>>> uint32_t MsgID; // Message ID
>>> union
>>> uint8_t u8[8]; // Payload byte access
>>> uint32_t u32[2]; // Payload u32 access (Att:
>>> little endian!)
>>> uint64_t u64; // Payload u64 access (Att:
>>> little endian!)
>>> } data;
>>> esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus:
>>> NULL=origin
>>> // CAN message
>>> typedef struct
>>> CAN_queue_type_t type;
>>> union
>>> CAN_frame_t frame; // CAN_frame
>>> canbus* bus;
>>> } body;
>>> } CAN_queue_msg_t;
>>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or
>>> am I missing something…
>>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark,
>>> good example why not to use addr2line: I think that result is wrong. a2l
>>> uses gdb which gives:
>>> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>> Using elf file: tmp/3.2.007.ovms3.elf
>>> 0x400d5e4c is in CAN_rxtask(void*)
>>> (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>> 726 } while (loop);
>>> 727 break;
>>> 728 }
>>> 731 break;
>>> …and that actually makes sense and matches the register dump.
>>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's
>>> got a CAN_txcallback msg without a bus.
>>> Hardening the rxtask against null here would probably avoid the crash,
>>> but I don't see yet how that could be possible.
>>> Both esp32can and mcp2515 set the bus field to their object addresses,
>>> which cannot be null.
>>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>>> Can’t get a2l working at the moment. The addr2line gives:
>>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40
>>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>>> That is:
>>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>> MyCan.LogInfo(this, type, text); <—— HERE
>>> ELF is at:
>>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark,
>>> Greg uses your build, the crash point seems to be consistent, can you
>>> post the a2l on this?
>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>> Hi folks,
>>> Well, the module updated to 3.2.007 last night. I just checked on it,
>>> and it appears that it didn't exactly survive. Crashed while running
>>> the autoconfig script. Log with two cycles attached.
>>> I tried renaming the /store/events directory to /store/was_events since
>>> it seems like Duktape was getting in the way, but that didn't resolve
>>> the crash. I manually enabled wifi so I could manage the module, and
>>> moved it back to 3.2.005 from the other partition. Seems stable again.
>>> The car is going into the Service Center tomorrow (the perennial issue
>>> with 1146 alerts), so I need to have the module stable so that I can
>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>>> has a quick fix in the next few hours...
>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>> (hopefully end of day)?
>>> Greg
>>> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> Üdvözlettel:
>> Kovács Tamás
> Üdvözlettel:
> Kovács Tamás
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191218/f43627ae/attachment-0001.html>
