[Ovmsdev] version 3.2.007: Crash on boot
Tamás Kovács
kommykt at gmail.com
Mon Dec 16 03:13:22 HKT 2019
My code crashed with same error as it described.
plus one error: in esp32can.cpp:448
The files can access my dropbox folder:
https://www.dropbox.com/sh/mowc7hc7zrzszmm/AACO4MAmM1yF3yoXsGoZO6R_a?dl=0
Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2019. dec. 13., P,
10:16):
> Greg, Mark,
> the new crash happened here:
> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l
> 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0
> 0x400da901:0x3ffc8810
> Using elf file:
> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
> 0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866).
> 861 {
> 862 if (tx)
> 863 {
> 864 if (frame->callback)
> 865 {
> 866 (*(frame->callback))(frame, success); // invoke
> frame-specific callback function
> 867 }
> 868 for (auto entry : m_txcallbacks) { // invoke generic tx
> callbacks
> 869 entry->m_callback(frame, success);
> 870 }
> 0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018).
> 1013 }
> 1014 else
> 1015 {
> 1016 LogFrame(CAN_LogFrame_TX_Fail, p_frame);
> 1017 }
> 1018 MyCan.ExecuteCallbacks(p_frame, true, success);
> 1019 }
> 1020
> 1021 /**
> 1022 * canbus::Write -- main TX API
> 0x400da901 is in CAN_rxtask(void*)
> (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730).
> 725 me->IncomingFrame(&msg.body.frame);
> 726 } while (loop);
> 727 break;
> 728 }
> 729 case CAN_txcallback:
> 730 msg.body.bus->TxCallback(&msg.body.frame, true);
> 731 break;
> 732 case CAN_txfailedcallback:
> 733 msg.body.bus->TxCallback(&msg.body.frame, false);
> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
> As the frame callback invocation is secured against null, it must have
> been a missing initialization of frame.callback. So I checked our source
> tree for uses of CAN_frame_t without memset or zero initialization and
> found one in obd2ecu::IncomingFrame() -- causing this crash I assume -- and
> two more in the can rx/tx shell commands.
> Fix is in commit
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/34302254567b15a8c0f9dfb730b5cf24703ac700
> …and build in https://ovms.dexters-web.de/firmware/ota/v3.1/edge/
> Greg, please test again.
> Am 13.12.19 um 07:09 schrieb Greg D.:
> Hi Michael,
> Ok, so I believe I loaded your Edge build, and the issue remains. To
> verify, this is the string reported by the web Status page:
> 3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec
> 12 2019 11:59:14)
> Following my earlier email, I left the configuration as-is, including
> launching the obd2ecu task, but with the attached OBDII module removed, and
> the crash was resolved. Rebooting the module had it come up running
> normally. I then plugged in the OBDII module into the OVMSv3, and OVMS
> crashed the instant the first it started polling. The device is a SyncUp
> Drive, which is a telematics and WiFi hotspot. Connecting the OBDII device
> with 12v power off, as expected, did nothing. Power it on, wait a few
> seconds to boot, and OVMS crashes immediately.
> New console log, attached. It shows the module booting normally (OBDII
> device not present), followed by the device being attached (indicated in
> the log), and the subsequent crash. I removed the device right after the
> boot started, so as to let the OVMS boot normally.
> So, clearly the obd2ecu task it is receiving frames on CAN3 just fine, but
> transmits back out on that same bus aren't working. Is this something I
> need to address within obd2ecu, or is it in the core code? I've not
> changed obd2ecu in quite some time.
> Greg
> Michael Balzer wrote:
> Fix commit is
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/8fef3f5fb6eec9fca26997e01d9c7d08080cdc06
> Greg, please test.
> New build with SPIRAM fix:
> Am 12.12.19 um 11:17 schrieb Michael Balzer:
> Last line of a2l was missing:
> #!/bin/bash
> elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
> for adr in $* ; do
> if [[ "$adr" =~ "elf" ]] ; then
> elf="$adr"
> else
> cmd+=" -ex 'l *${adr/:*/}'"
> fi
> done
> cmd+=" -ex 'q'"
> echo "Using elf file: $elf"
> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null
> Am 12.12.19 um 11:12 schrieb Michael Balzer:
> Mark,
> 1) maybe I missed posting my later version of a2l, which automatically
> strips the stack pointers from the ":" address syntax so you can copy&paste
> the USB output. Here it is:
> #!/bin/bash
> for adr in $* ; do
> elf="$adr"
> else
> fi
> done
> cmd+=" -ex 'q'"
> 2) You're right, the bug is tx_frame with null origin overwriting body.bus
> in the union. I didn't notice that when checking Marko's submission.
> tx_frame is a copy of the last frame given to the bus for transmission.
> The queue msg is gone when the TX done IRQ comes in, and Marko needed a
> copy of the frame the TX IRQ relates to. I asked him (see PR discussion),
> he checked and confirmed that all TX is done sequentially, so a single
> buffer is sufficient.
> Swapping the lines would work. The frame.origin also shouldn't be null,
> but the handler should tolerate that. …oops, tx_frame also doesn't get
> initialized in the canbus constructor, so there's also potentially garbage
> in tx_frame if due to some bug a TX IRQ is generated or processed without a
> previous tx.
> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
> Two issues:
> *1] A2L*
> My a2l is this:
> #!/bin/bash
> elf=3.2.007.ovms3.elf
> for adr in $* ; do
> elf="$adr"
> else
> cmd+=" -ex 'l *$adr'"
> fi
> done
> cmd+=" -ex 'q'"
> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is
> in "
> When I run it, I get:
> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
> Using elf file: 3.2.007.ovms3.elf
> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l
> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
> And a manual run gives:
> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l
> *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
> Junk at end of line specification.
> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
> (gdb) l *0x400d5e4c:0x3ffc5c40
> (gdb) l *0x7ffffffd:0x3ffc5c90
> (gdb) quit
> *2] Frame origin*
> Regarding the CAN_txcallback, I think you are correct. And both generators
> of that message set the frame correctly. So my initial thought was that it
> is either a memory corruption, or somewhere else sending a frame with
> garbage data.
> I do see this technique used in both the mcp2515 and esp32can drivers:
> msg.body.bus = me;
> msg.body.frame = me->tx_frame;
> I don’t normally just copy structures over like that. I memcpy() them, but
> I guess it must work. However, as our CAN_queue_msg_t is a union of
> CAN_frame_t (frame, with first member of the structure a canbus*) and
> 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus
> will get overwritten with whatever is in msg.body.frame.origin. I can’t see
> anywhere that tx_frame.origin is set - which is scary because that would
> mean it is always random junk.
> Maybe it works if tx_frame.origin is set to the bus before anything else,
> but not in Greg’s circumstances where something else arrives first. Perhaps
> related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I
> don’t really understand the tx_frame approach at all, and why the frame is
> just not passed on the queue.
> // CAN Frame
> // Note: Take care changing this structure, as it is a union with
> // CAN_log_message_t and position of 'origin' is fixed.
> struct CAN_frame_t
> canbus* origin; // Origin of the frame
> CanFrameCallback * callback; // Frame-specific callback. Is
> called when this frame is successfully sent (or sending failed)
> CAN_FIR_t FIR; // Frame information record
> uint32_t MsgID; // Message ID
> union
> uint8_t u8[8]; // Payload byte access
> uint32_t u32[2]; // Payload u32 access (Att: little
> endian!)
> uint64_t u64; // Payload u64 access (Att: little
> endian!)
> } data;
> esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus:
> NULL=origin
> // CAN message
> typedef struct
> CAN_queue_type_t type;
> union
> CAN_frame_t frame; // CAN_frame
> canbus* bus;
> } body;
> } CAN_queue_msg_t;
> This approach seems to date back to the swcan support merge (f94ae5a1b).
> Should we swap around, and set the msg.body.bus after msg.body.frame? Or
> am I missing something…
> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> good example why not to use addr2line: I think that result is wrong. a2l
> uses gdb which gives:
> tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
> Using elf file: tmp/3.2.007.ovms3.elf
> 0x400d5e4c is in CAN_rxtask(void*)
> (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
> 726 } while (loop);
> 727 break;
> 728 }
> 731 break;
> …and that actually makes sense and matches the register dump.
> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got
> a CAN_txcallback msg without a bus.
> Hardening the rxtask against null here would probably avoid the crash, but
> I don't see yet how that could be possible.
> Both esp32can and mcp2515 set the bus field to their object addresses,
> which cannot be null.
> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
> Can’t get a2l working at the moment. The addr2line gives:
> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
> That is:
> void canbus::LogInfo(CAN_log_type_t type, const char* text)
> MyCan.LogInfo(this, type, text); <—— HERE
> ELF is at:
> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> Greg uses your build, the crash point seems to be consistent, can you post
> the a2l on this?
> PS: Greg, would you mind switching to EAP to beta test future releases?
> Am 11.12.19 um 04:33 schrieb Greg D.:
> Hi folks,
> Well, the module updated to 3.2.007 last night. I just checked on it,
> and it appears that it didn't exactly survive. Crashed while running
> the autoconfig script. Log with two cycles attached.
> I tried renaming the /store/events directory to /store/was_events since
> it seems like Duktape was getting in the way, but that didn't resolve
> the crash. I manually enabled wifi so I could manage the module, and
> moved it back to 3.2.005 from the other partition. Seems stable again.
> The car is going into the Service Center tomorrow (the perennial issue
> with 1146 alerts), so I need to have the module stable so that I can
> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
> has a quick fix in the next few hours...
> Otherwise, any ideas for troubleshooting after I get the car back back
> (hopefully end of day)?
> Greg
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191215/3e9a8cd3/attachment-0001.html>
