[Ovmsdev] 3.2.008
Sun Dec 15 20:34:27 HKT 2019
My concern for this is that once we do it ALL developers have to also run that version of toolchain. Can we wait for Espressif to formally release this (as that seems to be happening soon)?
> On 13 Dec 2019, at 8:32 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I also recommend merging the SPIRAM fix into master now and building the factory release on that base as well (see my post Re: [Ovmsdev] Time for 3.2.006?).
> I've been releasing all builds on my server including the fix since June, so there is no need for further tests.
> Am 13.12.19 um 09:35 schrieb Michael Balzer:
>> Mark,
>> having a look at Greg's new report now, which differs from the first. Please wait for my results.
>> Am 13.12.19 um 06:05 schrieb Mark Webb-Johnson:
>>> Michael,
>>> It all looks good.
>>> I have tagged this as 3.2.008, and sent it to EAP. Plan is to send to MAIN this weekend.
>>> The rush is to avoid another of the new 8MB PSRAM users updating OTA and messed up their module. Any objections?
>>>> On 12 Dec 2019, at 6:12 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> 2) You're right, the bug is tx_frame with null origin overwriting body.bus in the union. I didn't notice that when checking Marko's submission.
>>>> tx_frame is a copy of the last frame given to the bus for transmission. The queue msg is gone when the TX done IRQ comes in, and Marko needed a copy of the frame the TX IRQ relates to. I asked him (see PR discussion), he checked and confirmed that all TX is done sequentially, so a single buffer is sufficient.
>>>> Swapping the lines would work. The frame.origin also shouldn't be null, but the handler should tolerate that. …oops, tx_frame also doesn't get initialized in the canbus constructor, so there's also potentially garbage in tx_frame if due to some bug a TX IRQ is generated or processed without a previous tx.
>>>> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
>>>> Regards,
>>>> Michael
>>>> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>>>>> Two issues:
>>>>> 1] A2L
>>>>> My a2l is this:
>>>>> #!/bin/bash
>>>>> elf=3.2.007.ovms3.elf
>>>>> for adr in $* ; do
>>>>> if [[ "$adr" =~ "elf" ]] ; then
>>>>> elf="$adr"
>>>>> else
>>>>> cmd+=" -ex 'l *$adr'"
>>>>> fi
>>>>> done
>>>>> cmd+=" -ex 'q'"
>>>>> echo "Using elf file: $elf"
>>>>> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>>>>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
>>>>> When I run it, I get:
>>>>> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>> Using elf file: 3.2.007.ovms3.elf
>>>>> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>>>>> And a manual run gives:
>>>>> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>>>>> Junk at end of line specification.
>>>>> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>>>>> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>>>>> (gdb) l *0x400d5e4c:0x3ffc5c40
>>>>> (gdb) l *0x7ffffffd:0x3ffc5c90
>>>>> (gdb) quit
>>>>> 2] Frame origin
>>>>> Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is either a memory corruption, or somewhere else sending a frame with garbage data.
>>>>> I do see this technique used in both the mcp2515 and esp32can drivers:
>>>>> msg.body.bus = me;
>>>>> msg.body.frame = me->tx_frame;
>>>>> I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten with whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk.
>>>>> Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just not passed on the queue.
>>>>> // CAN Frame
>>>>> // Note: Take care changing this structure, as it is a union with
>>>>> // CAN_log_message_t and position of 'origin' is fixed.
>>>>> struct CAN_frame_t
>>>>> canbus* origin; // Origin of the frame
>>>>> CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed)
>>>>> CAN_FIR_t FIR; // Frame information record
>>>>> uint32_t MsgID; // Message ID
>>>>> union
>>>>> uint8_t u8[8]; // Payload byte access
>>>>> uint32_t u32[2]; // Payload u32 access (Att: little endian!)
>>>>> uint64_t u64; // Payload u64 access (Att: little endian!)
>>>>> } data;
>>>>> esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin
>>>>> // CAN message
>>>>> typedef struct
>>>>> CAN_queue_type_t type;
>>>>> union
>>>>> CAN_frame_t frame; // CAN_frame
>>>>> canbus* bus;
>>>>> } body;
>>>>> } CAN_queue_msg_t;
>>>>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>>>>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something…
>>>>> Regards, Mark.
>>>>>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>> Mark,
>>>>>> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives:
>>>>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3 <mailto:balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>>> Using elf file: tmp/3.2.007.ovms3.elf
>>>>>> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>>>>> 725 me->IncomingFrame(&msg.body.frame);
>>>>>> 726 } while (loop);
>>>>>> 727 break;
>>>>>> 728 }
>>>>>> 729 case CAN_txcallback:
>>>>>> 730 msg.body.bus->TxCallback(&msg.body.frame, true);
>>>>>> 731 break;
>>>>>> 732 case CAN_txfailedcallback:
>>>>>> 733 msg.body.bus->TxCallback(&msg.body.frame, false);
>>>>>> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
>>>>>> …and that actually makes sense and matches the register dump.
>>>>>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus.
>>>>>> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible.
>>>>>> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>>>>>>> Can’t get a2l working at the moment. The addr2line gives:
>>>>>>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>>>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>>>>>>> That is:
>>>>>>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>>>>>> MyCan.LogInfo(this, type, text); <—— HERE
>>>>>>> ELF is at:
>>>>>>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf>
>>>>>>> Regards, Mark.
>>>>>>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>> Mark,
>>>>>>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>>>>>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>>>>>>>> Hi folks,
>>>>>>>>> Well, the module updated to 3.2.007 last night. I just checked on it,
>>>>>>>>> and it appears that it didn't exactly survive. Crashed while running
>>>>>>>>> the autoconfig script. Log with two cycles attached.
>>>>>>>>> I tried renaming the /store/events directory to /store/was_events since
>>>>>>>>> it seems like Duktape was getting in the way, but that didn't resolve
>>>>>>>>> the crash. I manually enabled wifi so I could manage the module, and
>>>>>>>>> moved it back to 3.2.005 from the other partition. Seems stable again.
>>>>>>>>> The car is going into the Service Center tomorrow (the perennial issue
>>>>>>>>> with 1146 alerts), so I need to have the module stable so that I can
>>>>>>>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>>>>>>>>> has a quick fix in the next few hours...
>>>>>>>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>>>>>>>> (hopefully end of day)?
>>>>>>>>> Greg
>>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191215/f6331562/attachment-0001.html>
