[Ovmsdev] version 3.2.007: Crash on boot
Fri Dec 13 17:15:50 HKT 2019
Greg, Mark,
the new crash happened here:
balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l 0x3ffcfda0:0x3ffc87a0 0x400da762:0x3ffc87d0 0x400da95b:0x3ffc87f0 0x400da901:0x3ffc8810
Using elf file: /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
0x400da762 is in can::ExecuteCallbacks(CAN_frame_t const*, bool, bool)
(/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:866).
861 {
862 if (tx)
863 {
864 if (frame->callback)
865 {
866 (*(frame->callback))(frame, success); // invoke frame-specific callback function
867 }
868 for (auto entry : m_txcallbacks) { // invoke generic tx callbacks
869 entry->m_callback(frame, success);
870 }
0x400da95b is in canbus::TxCallback(CAN_frame_t*, bool) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:1018).
1013 }
1014 else
1015 {
1016 LogFrame(CAN_LogFrame_TX_Fail, p_frame);
1017 }
1018 MyCan.ExecuteCallbacks(p_frame, true, success);
1019 }
1020
1021 /**
1022 * canbus::Write -- main TX API
0x400da901 is in CAN_rxtask(void*) (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/can.cpp:730).
725 me->IncomingFrame(&msg.body.frame);
726 } while (loop);
727 break;
728 }
729 case CAN_txcallback:
730 msg.body.bus->TxCallback(&msg.body.frame, true);
731 break;
732 case CAN_txfailedcallback:
733 msg.body.bus->TxCallback(&msg.body.frame, false);
734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
As the frame callback invocation is secured against null, it must have been a missing initialization of frame.callback. So I checked our source tree for uses of
CAN_frame_t without memset or zero initialization and found one in obd2ecu::IncomingFrame() -- causing this crash I assume -- and two more in the can rx/tx
shell commands.
Fix is in commit https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/34302254567b15a8c0f9dfb730b5cf24703ac700
…and build in https://ovms.dexters-web.de/firmware/ota/v3.1/edge/
Greg, please test again.
Am 13.12.19 um 07:09 schrieb Greg D.:
> Hi Michael,
> Ok, so I believe I loaded your Edge build, and the issue remains. To verify, this is the string reported by the web Status page:
> 3.2.007-102-g07440970/ota_1/main (build idf v3.3-beta3-774-g6652269e1 Dec 12 2019 11:59:14)
> Following my earlier email, I left the configuration as-is, including launching the obd2ecu task, but with the attached OBDII module removed, and the crash
> was resolved. Rebooting the module had it come up running normally. I then plugged in the OBDII module into the OVMSv3, and OVMS crashed the instant the
> first it started polling. The device is a SyncUp Drive, which is a telematics and WiFi hotspot. Connecting the OBDII device with 12v power off, as expected,
> did nothing. Power it on, wait a few seconds to boot, and OVMS crashes immediately.
> New console log, attached. It shows the module booting normally (OBDII device not present), followed by the device being attached (indicated in the log), and
> the subsequent crash. I removed the device right after the boot started, so as to let the OVMS boot normally.
> So, clearly the obd2ecu task it is receiving frames on CAN3 just fine, but transmits back out on that same bus aren't working. Is this something I need to
> address within obd2ecu, or is it in the core code? I've not changed obd2ecu in quite some time.
> Greg
> Michael Balzer wrote:
>> Fix commit is https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/8fef3f5fb6eec9fca26997e01d9c7d08080cdc06
>> Greg, please test.
>> New build with SPIRAM fix: https://ovms.dexters-web.de/firmware/ota/v3.1/edge/
>> Am 12.12.19 um 11:17 schrieb Michael Balzer:
>>> Last line of a2l was missing:
>>> #!/bin/bash
>>> elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
>>> for adr in $* ; do
>>> if [[ "$adr" =~ "elf" ]] ; then
>>> elf="$adr"
>>> else
>>> cmd+=" -ex 'l *${adr/:*/}'"
>>> fi
>>> done
>>> cmd+=" -ex 'q'"
>>> echo "Using elf file: $elf"
>>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null
>>> Am 12.12.19 um 11:12 schrieb Michael Balzer:
>>>> Mark,
>>>> 1) maybe I missed posting my later version of a2l, which automatically strips the stack pointers from the ":" address syntax so you can copy&paste the USB
>>>> output. Here it is:
>>>> #!/bin/bash
>>>> for adr in $* ; do
>>>> elf="$adr"
>>>> else
>>>> fi
>>>> done
>>>> cmd+=" -ex 'q'"
>>>> 2) You're right, the bug is tx_frame with null origin overwriting body.bus in the union. I didn't notice that when checking Marko's submission.
>>>> tx_frame is a copy of the last frame given to the bus for transmission. The queue msg is gone when the TX done IRQ comes in, and Marko needed a copy of the
>>>> frame the TX IRQ relates to. I asked him (see PR discussion), he checked and confirmed that all TX is done sequentially, so a single buffer is sufficient.
>>>> Swapping the lines would work. The frame.origin also shouldn't be null, but the handler should tolerate that. …oops, tx_frame also doesn't get initialized
>>>> in the canbus constructor, so there's also potentially garbage in tx_frame if due to some bug a TX IRQ is generated or processed without a previous tx.
>>>> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
>>>> Regards,
>>>> Michael
>>>> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>>>>> Two issues:
>>>>> _*1] A2L*_
>>>>> My a2l is this:
>>>>> #!/bin/bash
>>>>> elf=3.2.007.ovms3.elf
>>>>> for adr in $* ; do
>>>>> elf="$adr"
>>>>> else
>>>>> cmd+=" -ex 'l *$adr'"
>>>>> fi
>>>>> done
>>>>> cmd+=" -ex 'q'"
>>>>> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>>>>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
>>>>> When I run it, I get:
>>>>> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>> Using elf file: 3.2.007.ovms3.elf
>>>>> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>>>>> And a manual run gives:
>>>>> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>>>>> Junk at end of line specification.
>>>>> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>>>>> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>>>>> (gdb) l *0x400d5e4c:0x3ffc5c40
>>>>> (gdb) l *0x7ffffffd:0x3ffc5c90
>>>>> (gdb) quit
>>>>> _*2] Frame origin*_
>>>>> Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is
>>>>> either a memory corruption, or somewhere else sending a frame with garbage data.
>>>>> I do see this technique used in both the mcp2515 and esp32can drivers:
>>>>> msg.body.bus = me;
>>>>> msg.body.frame = me->tx_frame;
>>>>> I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t
>>>>> (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten
>>>>> with whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk.
>>>>> Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps
>>>>> related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just
>>>>> not passed on the queue.
>>>>> // CAN Frame
>>>>> // Note: Take care changing this structure, as it is a union with
>>>>> // CAN_log_message_t and position of 'origin' is fixed.
>>>>> struct CAN_frame_t
>>>>> canbus* origin; // Origin of the frame
>>>>> CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed)
>>>>> CAN_FIR_t FIR; // Frame information record
>>>>> uint32_t MsgID; // Message ID
>>>>> union
>>>>> uint8_t u8[8]; // Payload byte access
>>>>> uint32_t u32[2]; // Payload u32 access (Att: little endian!)
>>>>> uint64_t u64; // Payload u64 access (Att: little endian!)
>>>>> } data;
>>>>> esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin
>>>>> // CAN message
>>>>> typedef struct
>>>>> CAN_queue_type_t type;
>>>>> union
>>>>> CAN_frame_t frame; // CAN_frame
>>>>> canbus* bus;
>>>>> } body;
>>>>> } CAN_queue_msg_t;
>>>>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>>>>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something…
>>>>> Regards, Mark.
>>>>>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>> Mark,
>>>>>> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives:
>>>>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>>> Using elf file: tmp/3.2.007.ovms3.elf
>>>>>> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>>>>> 726 } while (loop);
>>>>>> 727 break;
>>>>>> 728 }
>>>>>> 731 break;
>>>>>> …and that actually makes sense and matches the register dump.
>>>>>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus.
>>>>>> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible.
>>>>>> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>>>>>>> Can’t get a2l working at the moment. The addr2line gives:
>>>>>>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>>>>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>>>>>>> That is:
>>>>>>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>>>>>> MyCan.LogInfo(this, type, text); <—— HERE
>>>>>>> ELF is at:
>>>>>>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
>>>>>>> Regards, Mark.
>>>>>>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>> Mark,
>>>>>>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>>>>>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>>>>>>>> Hi folks,
>>>>>>>>> Well, the module updated to 3.2.007 last night. I just checked on it,
>>>>>>>>> and it appears that it didn't exactly survive. Crashed while running
>>>>>>>>> the autoconfig script. Log with two cycles attached.
>>>>>>>>> I tried renaming the /store/events directory to /store/was_events since
>>>>>>>>> it seems like Duktape was getting in the way, but that didn't resolve
>>>>>>>>> the crash. I manually enabled wifi so I could manage the module, and
>>>>>>>>> moved it back to 3.2.005 from the other partition. Seems stable again.
>>>>>>>>> The car is going into the Service Center tomorrow (the perennial issue
>>>>>>>>> with 1146 alerts), so I need to have the module stable so that I can
>>>>>>>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>>>>>>>>> has a quick fix in the next few hours...
>>>>>>>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>>>>>>>> (hopefully end of day)?
>>>>>>>>> Greg
>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191213/ce07a9ea/attachment-0001.html>
