[Ovmsdev] version 3.2.007: Crash on boot
Thu Dec 12 18:17:35 HKT 2019
Last line of a2l was missing:
#!/bin/bash
elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
for adr in $* ; do
if [[ "$adr" =~ "elf" ]] ; then
elf="$adr"
else
cmd+=" -ex 'l *${adr/:*/}'"
fi
done
cmd+=" -ex 'q'"
echo "Using elf file: $elf"
eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null
Am 12.12.19 um 11:12 schrieb Michael Balzer:
> Mark,
> 1) maybe I missed posting my later version of a2l, which automatically strips the stack pointers from the ":" address syntax so you can copy&paste the USB
> output. Here it is:
> #!/bin/bash
> for adr in $* ; do
> elf="$adr"
> else
> fi
> done
> cmd+=" -ex 'q'"
> 2) You're right, the bug is tx_frame with null origin overwriting body.bus in the union. I didn't notice that when checking Marko's submission.
> tx_frame is a copy of the last frame given to the bus for transmission. The queue msg is gone when the TX done IRQ comes in, and Marko needed a copy of the
> frame the TX IRQ relates to. I asked him (see PR discussion), he checked and confirmed that all TX is done sequentially, so a single buffer is sufficient.
> Swapping the lines would work. The frame.origin also shouldn't be null, but the handler should tolerate that. …oops, tx_frame also doesn't get initialized in
> the canbus constructor, so there's also potentially garbage in tx_frame if due to some bug a TX IRQ is generated or processed without a previous tx.
> I'll do the fixes… and also rename tx_frame to m_tx_frame for consistency.
> Am 12.12.19 um 01:20 schrieb Mark Webb-Johnson:
>> Two issues:
>> _*1] A2L*_
>> My a2l is this:
>> #!/bin/bash
>> elf=3.2.007.ovms3.elf
>> for adr in $* ; do
>> elf="$adr"
>> else
>> cmd+=" -ex 'l *$adr'"
>> fi
>> done
>> cmd+=" -ex 'q'"
>> echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
>> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
>> When I run it, I get:
>> $ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>> Using elf file: 3.2.007.ovms3.elf
>> xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
>> And a manual run gives:
>> $ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
>> Junk at end of line specification.
>> $ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
>> GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>> (gdb) l *0x400d5e4c:0x3ffc5c40
>> (gdb) l *0x7ffffffd:0x3ffc5c90
>> (gdb) quit
>> _*2] Frame origin*_
>> Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is
>> either a memory corruption, or somewhere else sending a frame with garbage data.
>> I do see this technique used in both the mcp2515 and esp32can drivers:
>> msg.body.bus = me;
>> msg.body.frame = me->tx_frame;
>> I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t
>> (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten with
>> whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk.
>> Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps related
>> to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just not passed on
>> the queue.
>> // CAN Frame
>> // Note: Take care changing this structure, as it is a union with
>> // CAN_log_message_t and position of 'origin' is fixed.
>> struct CAN_frame_t
>> canbus* origin; // Origin of the frame
>> CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed)
>> CAN_FIR_t FIR; // Frame information record
>> uint32_t MsgID; // Message ID
>> union
>> uint8_t u8[8]; // Payload byte access
>> uint32_t u32[2]; // Payload u32 access (Att: little endian!)
>> uint64_t u64; // Payload u64 access (Att: little endian!)
>> } data;
>> esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin
>> // CAN message
>> typedef struct
>> CAN_queue_type_t type;
>> union
>> CAN_frame_t frame; // CAN_frame
>> canbus* bus;
>> } body;
>> } CAN_queue_msg_t;
>> This approach seems to date back to the swcan support merge (f94ae5a1b).
>> Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something…
>>> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives:
>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>> Using elf file: tmp/3.2.007.ovms3.elf
>>> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
>>> 725 me->IncomingFrame(&msg.body.frame);
>>> 726 } while (loop);
>>> 727 break;
>>> 728 }
>>> 729 case CAN_txcallback:
>>> 730 msg.body.bus->TxCallback(&msg.body.frame, true);
>>> 731 break;
>>> 732 case CAN_txfailedcallback:
>>> 733 msg.body.bus->TxCallback(&msg.body.frame, false);
>>> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
>>> …and that actually makes sense and matches the register dump.
>>> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus.
>>> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible.
>>> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null.
>>> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>>>> Can’t get a2l working at the moment. The addr2line gives:
>>>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>>>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>>>> That is:
>>>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>>>> MyCan.LogInfo(this, type, text); <—— HERE
>>>> ELF is at:
>>>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf
>>>> Regards, Mark.
>>>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> Mark,
>>>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
>>>>> Regards,
>>>>> Michael
>>>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>>>>> Hi folks,
>>>>>> Well, the module updated to 3.2.007 last night. I just checked on it,
>>>>>> and it appears that it didn't exactly survive. Crashed while running
>>>>>> the autoconfig script. Log with two cycles attached.
>>>>>> I tried renaming the /store/events directory to /store/was_events since
>>>>>> it seems like Duktape was getting in the way, but that didn't resolve
>>>>>> the crash. I manually enabled wifi so I could manage the module, and
>>>>>> moved it back to 3.2.005 from the other partition. Seems stable again.
>>>>>> The car is going into the Service Center tomorrow (the perennial issue
>>>>>> with 1146 alerts), so I need to have the module stable so that I can
>>>>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>>>>>> has a quick fix in the next few hours...
>>>>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>>>>> (hopefully end of day)?
>>>>>> Greg
>>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191212/7f4c89af/attachment-0001.html>
