[Ovmsdev] version 3.2.007: Crash on boot
Thu Dec 12 08:20:24 HKT 2019
Two issues:
1] A2L
My a2l is this:
#!/bin/bash
elf=3.2.007.ovms3.elf
for adr in $* ; do
if [[ "$adr" =~ "elf" ]] ; then
elf="$adr"
else
cmd+=" -ex 'l *$adr'"
fi
done
cmd+=" -ex 'q'"
echo "Using elf file: $elf"
echo "xtensa-esp32-elf-gdb -batch $elf $cmd"
eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
When I run it, I get:
$ a2l 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
Using elf file: 3.2.007.ovms3.elf
xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex ‘q'
And a manual run gives:
$ xtensa-esp32-elf-gdb -batch 3.2.007.ovms3.elf -ex 'l *0x400d5e4c:0x3ffc5c40' -ex 'l *0x7ffffffd:0x3ffc5c90' -ex 'q'
Junk at end of line specification.
$ xtensa-esp32-elf-gdb 3.2.007.ovms3.elf
GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
(gdb) l *0x400d5e4c:0x3ffc5c40
(gdb) l *0x7ffffffd:0x3ffc5c90
(gdb) quit
2] Frame origin
Regarding the CAN_txcallback, I think you are correct. And both generators of that message set the frame correctly. So my initial thought was that it is either a memory corruption, or somewhere else sending a frame with garbage data.
I do see this technique used in both the mcp2515 and esp32can drivers:
msg.body.bus = me;
msg.body.frame = me->tx_frame;
I don’t normally just copy structures over like that. I memcpy() them, but I guess it must work. However, as our CAN_queue_msg_t is a union of CAN_frame_t (frame, with first member of the structure a canbus*) and 'canbus* bus’, that is a little worrying. It seems that the msg.body.bus will get overwritten with whatever is in msg.body.frame.origin. I can’t see anywhere that tx_frame.origin is set - which is scary because that would mean it is always random junk.
Maybe it works if tx_frame.origin is set to the bus before anything else, but not in Greg’s circumstances where something else arrives first. Perhaps related to obd2ecu? I only see tx_frame set in can.cpp canbus::Write. I don’t really understand the tx_frame approach at all, and why the frame is just not passed on the queue.
// CAN Frame
// Note: Take care changing this structure, as it is a union with
// CAN_log_message_t and position of 'origin' is fixed.
struct CAN_frame_t
canbus* origin; // Origin of the frame
CanFrameCallback * callback; // Frame-specific callback. Is called when this frame is successfully sent (or sending failed)
CAN_FIR_t FIR; // Frame information record
uint32_t MsgID; // Message ID
union
uint8_t u8[8]; // Payload byte access
uint32_t u32[2]; // Payload u32 access (Att: little endian!)
uint64_t u64; // Payload u64 access (Att: little endian!)
} data;
esp_err_t Write(canbus* bus=NULL, TickType_t maxqueuewait=0); // bus: NULL=origin
// CAN message
typedef struct
CAN_queue_type_t type;
union
CAN_frame_t frame; // CAN_frame
canbus* bus;
} body;
} CAN_queue_msg_t;
This approach seems to date back to the swcan support merge (f94ae5a1b).
Should we swap around, and set the msg.body.bus after msg.body.frame? Or am I missing something…
> On 12 Dec 2019, at 2:29 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> good example why not to use addr2line: I think that result is wrong. a2l uses gdb which gives:
> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3 <mailto:balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>> a2l tmp/3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
> Using elf file: tmp/3.2.007.ovms3.elf
> 0x400d5e4c is in CAN_rxtask(void*) (/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:730).
> 725 me->IncomingFrame(&msg.body.frame);
> 726 } while (loop);
> 727 break;
> 728 }
> 729 case CAN_txcallback:
> 730 msg.body.bus->TxCallback(&msg.body.frame, true);
> 731 break;
> 732 case CAN_txfailedcallback:
> 733 msg.body.bus->TxCallback(&msg.body.frame, false);
> 734 msg.body.bus->LogStatus(CAN_LogStatus_Error);
> …and that actually makes sense and matches the register dump.
> If I read the gdb disassembly correctly, A10 = msg.body.bus, so Greg's got a CAN_txcallback msg without a bus.
> Hardening the rxtask against null here would probably avoid the crash, but I don't see yet how that could be possible.
> Both esp32can and mcp2515 set the bus field to their object addresses, which cannot be null.
> Am 11.12.19 um 13:45 schrieb Mark Webb-Johnson:
>> Can’t get a2l working at the moment. The addr2line gives:
>> addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
>> /home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
>> That is:
>> void canbus::LogInfo(CAN_log_type_t type, const char* text)
>> MyCan.LogInfo(this, type, text); <—— HERE
>> ELF is at:
>> http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf>
>>> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
>>> PS: Greg, would you mind switching to EAP to beta test future releases?
>>> Am 11.12.19 um 04:33 schrieb Greg D.:
>>>> Hi folks,
>>>> Well, the module updated to 3.2.007 last night. I just checked on it,
>>>> and it appears that it didn't exactly survive. Crashed while running
>>>> the autoconfig script. Log with two cycles attached.
>>>> I tried renaming the /store/events directory to /store/was_events since
>>>> it seems like Duktape was getting in the way, but that didn't resolve
>>>> the crash. I manually enabled wifi so I could manage the module, and
>>>> moved it back to 3.2.005 from the other partition. Seems stable again.
>>>> The car is going into the Service Center tomorrow (the perennial issue
>>>> with 1146 alerts), so I need to have the module stable so that I can
>>>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>>>> has a quick fix in the next few hours...
>>>> Otherwise, any ideas for troubleshooting after I get the car back back
>>>> (hopefully end of day)?
>>>> Greg
>>>> OvmsDev mailing list
>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191212/e1df2dad/attachment-0001.html>
