[Ovmsdev] version 3.2.007: Crash on boot
Wed Dec 11 20:45:17 HKT 2019
Can’t get a2l working at the moment. The addr2line gives:
addr2line -e 3.2.007.ovms3.elf 0x400d5e4c:0x3ffc5c40 0x7ffffffd:0x3ffc5c90
/home/openvehicles/build/Open-Vehicle-Monitoring-System-3.1/vehicle/OVMS.V3/components/can/src/can.cpp:551
That is:
void canbus::LogInfo(CAN_log_type_t type, const char* text)
MyCan.LogInfo(this, type, text); <—— HERE
ELF is at:
http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf <http://api.openvehicles.com/firmware/ota/v3.2/main/3.2.007.ovms3.elf>
> On 11 Dec 2019, at 5:20 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> Greg uses your build, the crash point seems to be consistent, can you post the a2l on this?
> PS: Greg, would you mind switching to EAP to beta test future releases?
> Am 11.12.19 um 04:33 schrieb Greg D.:
>> Hi folks,
>> Well, the module updated to 3.2.007 last night. I just checked on it,
>> and it appears that it didn't exactly survive. Crashed while running
>> the autoconfig script. Log with two cycles attached.
>> I tried renaming the /store/events directory to /store/was_events since
>> it seems like Duktape was getting in the way, but that didn't resolve
>> the crash. I manually enabled wifi so I could manage the module, and
>> moved it back to 3.2.005 from the other partition. Seems stable again.
>> The car is going into the Service Center tomorrow (the perennial issue
>> with 1146 alerts), so I need to have the module stable so that I can
>> keep an eye on it. Going to leave it on 3.2.005 for now, unless someone
>> has a quick fix in the next few hours...
>> Otherwise, any ideas for troubleshooting after I get the car back back
>> (hopefully end of day)?
>> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191211/97d6d6d7/attachment.html>
