[Ovmsdev] ESP32 CAN controller hardware bug / interrupt issue
Wed Dec 11 19:53:57 HKT 2019
A quick update:
On my car module, CAN overflows are now down to 0.004 per mille, SIMCOM UART overflows down to effectively 0.
The new file logging delayed fsync scheme had a major impact (as expected), and interestingly the regular DukTape garbage collection caused
another drop.
So it's OK now, but we need to be careful about both SD file I/O and high / granular memory usage.
Am 21.11.19 um 14:31 schrieb Michael Balzer:
> For those who didn't follow the issue: I did some single step experimentation to determine the actual behaviour of the controller.
> I found out how to recover after an overrun, and I found a hardware bug that causes the controller FIFO to get into an unrecoverable state
> when the message counter reaches 64. My results have just been confirmed by Espressif.
> The new implementation has been in edge for 9 days now, and no frame corruptions have occurred since.
> Overflow rate still has been pretty high (~3-4 per mille). I now build with the TCP/IP task pinned to core 1, which has lowered the rate to
> ~0.5 per mille, but also leads to an unbalanced load distribution. Not sure yet if that's the best solution. I've checked if moving all CAN
> processing back to core 1 would help, but that turned out to be worse. I suspect either SPI or SD I/O to require long/often critical section
> locks on core 1, but haven't checked their code yet.
> Am 07.11.19 um 18:19 schrieb Michael Balzer:
>> No luck with all variations. I've switched back to the byte counting workaround.
>> Am 07.11.19 um 10:31 schrieb Michael Balzer:
>>> The new implementation doesn't seem to work very well. It seems this approach loses a lot of CAN frames. I don't have the means to test how
>>> many, but I see the effect in my vehicle events & status.
>>> The Espressif info given by Darian in the issue was either inaccurate or misses some important detail. There's another (non Espressif)
>>> developer on the issue trying to get the idf driver to correctly handle the issue, he hasn't had any luck as well up to now.
>>> I'll try another interpretation of the scheme outlined by Darian. If that doesn't work I'll revert to my first workaround until we get
>>> answers or template code from Espressif.
>>> Am 03.11.19 um 19:46 schrieb Michael Balzer:
>>>> I've pushed the new implementation based on the Espressif info and some more experimentation.
>>>> I've also enabled the IRAM flag for the GPIO and SPI_noDMA handlers, as all handlers here already were in IRAM.
>>>> I've been testing this over the weekend, had no issues and slightly reduced can1 frame drops.
>>>> Mark, maybe you can do some additional high load CAN tests in your lab.
>>>> Regards,
>>>> Michael
>>>> Am 01.11.19 um 12:35 schrieb Michael Balzer:
>>>>> An unusual fast reply from Espressif. They basically declared it to be a feature…
>>>>> https://github.com/espressif/esp-idf/issues/4276#issuecomment-548753085
>>>>> Regards,
>>>>> Michael
>>>>> Am 01.11.19 um 10:34 schrieb Michael Balzer:
>>>>>> I've submitted an issue to Espressif on this:
>>>>>> It would be nice if I could reproduce the effect using some standard hardware.
>>>>>> I've ordered some of those combined ESP32 + OLED units, but don't have any CAN transceivers I could hook up to them.
>>>>>> Maybe the info I've provided is sufficient for Espressif to investigate.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 31.10.19 um 22:24 schrieb Michael Balzer:
>>>>>>> Second finding & commit:
>>>>>>> TL;DR:
>>>>>>>   * ESP32 CAN controller is broken, delivers trashed & duplicated RX frames
>>>>>>>   * we need to optimize interrupt latency
>>>>>>> Users have been reporting occasional false BMS readings on the Twizy for more than a year.
>>>>>>> The error always trashed the reading of voltage #10 and/or temperature #8, so I initially
>>>>>>> thought that must be a variant of the SPIRAM/cache bug.
>>>>>>> But the SPIRAM fix didn't help, and the bug still occured with all BMS data in internal
>>>>>>> RAM. The issue correlated with high load situations and the SIMCOM UART issue. On testing the
>>>>>>> latest changes by Marko, my car module began showing that issue regularly, so I could take a
>>>>>>> closer look. It turned out the wrong data came from the CAN bus. Checking with a CAN logger
>>>>>>> didn't show any wrong data on the bus.
>>>>>>> So I scanned our CAN driver for potential issues, found & solved some (even a serious
>>>>>>> race condition) but that didn't fix it. I then added debug dumps of all frames read, dug
>>>>>>> into the SJA1000 spec sheet and found this:
>>>>>>> The SJA1000 RX FIFO has a capacity of 64 bytes. It's supposed to work as a ring buffer,
>>>>>>> with frames wrapping around as necessary. If no space is left in the FIFO for a new frame
>>>>>>> coming in, that frame should be discarded completely, not counted, just the overflow
>>>>>>> indicator should be set & the according interrupt be generated.
>>>>>>> Reality differs. The frame causing the overflow is added to the FIFO partially. It's also
>>>>>>> counted both in the RMC register and indicated by RBS as a valid frame when retrieving
>>>>>>> the FIFO contents. The read buffer delivers the partial frame + some trashed bytes up
>>>>>>> to the nominal frame length.
>>>>>>> In the BMS frame sequence it would normally trash bytes 7 & 8 on the sixth frame of length
>>>>>>> 8 in a sequence. A standard frame needs a 3 byte header + the data bytes in the FIFO, so
>>>>>>> 6 frames would add up to 66 bytes => 64 + 2 trash. The first trash byte normally is "08",
>>>>>>> the second "84" or "2a" or sometimes "ab", possibly some internal SJA1000 data.
>>>>>>> Better yet, if you rely on the indicators of the SJA1000 when reading the FIFO, the
>>>>>>> SJA1000 will repeat the first frame within the FIFO after the invalid frame. Mostly
>>>>>>> once or twice, and sometimes 7 times or more:
>>>>>>> inv_msg: framecnt=13, invindex=6
>>>>>>> inv_msg: 55 01 00 00 07 98 50 54 54 20 00 6e | 4..?........U.....PTT .n
>>>>>>> inv_msg: 24 04 00 00 11 40 10 22 37 55 00 37 | 4..?........$.... at ."7U.7
>>>>>>> inv_msg: 25 04 00 00 0a 1b 44 ff fe 4e 01 26 | 4..?........%.....D..N.&
>>>>>>> inv_msg: 54 05 00 00 37 37 37 37 37 37 37 00 | 4..?........T...7777777.
>>>>>>> inv_msg: 56 05 00 00 31 63 14 31 53 14 31 4a | 4..?........V...1c.1S.1J
>>>>>>> inv_msg: 57 05 00 00 31 43 14 31 53 15 *08 2a* | 4..?........W...1C.1S..*
>>>>>>>                                        ^^^^^ trashed bytes
>>>>>>> … followed by 7 repetitions of the first frame:
>>>>>>> If you had occasional strange false readings leading to strange effects, this
>>>>>>> may be the explanation. Note: the SJA1000 FIFO bug may need specific circumstance
>>>>>>> to occur in addition to the overflow, maybe the overflow happening on a specific
>>>>>>> byte position in the FIFO -- I haven't tried to determine that.
>>>>>>> I've tried clearing the overflow ASAP, looping on the IR indicator and looping
>>>>>>> on the RMC, the fault is always the same. The workaround I've now done is adding
>>>>>>> up the message lengths read during a FIFO run and discard all frames exceeding
>>>>>>> the 64 byte border. Not pretty, but functional.
>>>>>>> That keeps the trashed frames from being forwarded to the OVMS application level.
>>>>>>> As with the SIMCOM UART, these overflows wouldn't happen if the interrupt handler
>>>>>>> would react fast enough. It seems we've got a general interrupt latency issue.
>>>>>>> And just as with the SIMCOM I saw a reduction of overflows when allocating the
>>>>>>> CAN IRQ on core #0, another one with raising the IRQ level to 3, so that's
>>>>>>> also part of my commit.
>>>>>>> The esp-idf CAN driver apparently has the same issue even in the latest release,
>>>>>>> I'll contact the author about this or post another issue to Espressif.
>>>>>>> So our interrupt allocation is now:
>>>>>>> Task           Run#  Lvl  ISR#  Usage                    Source
>>>>>>> -              0     1    0     RTC Core                 ETS_RTC_CORE_INTR_SOURCE
>>>>>>> esp_timer      0     1    0     RTOS esp_timer           ETS_TIMER2_INTR_SOURCE
>>>>>>> ipc0           0     1    0     RTOS Scheduler Core0     ETS_FROM_CPU_INTR0_SOURCE
>>>>>>> ipc1           1     1    1     RTOS Scheduler Core1     ETS_FROM_CPU_INTR1_SOURCE
>>>>>>> main           0     1    0     RTOS Watchdog            ETS_TG0_WDT_LEVEL_INTR_SOURCE
>>>>>>> OVMS Events    1     1    1     Peripherals (GPIO ISR)   ETS_GPIO_INTR_SOURCE
>>>>>>> OVMS Events    1     1    1     MAX7317 (spi_nodma)      ETS_SPI3_INTR_SOURCE
>>>>>>> *esp32can init  0     3    0     ESP32 CAN                ETS_CAN_INTR_SOURCE**
>>>>>>> **OVMS SIMCOM    0     2    0     SIMCOM UART              ETS_UART1_INTR_SOURCE*
>>>>>>> OVMS Events    1     1    1     USB console (UART)       ETS_UART0_INTR_SOURCE
>>>>>>> OVMS Events    1     1    1     SD card                  ETS_SDIO_HOST_INTR_SOURCE
>>>>>>> I think we need to find the source of the interrupt latency and/or find some
>>>>>>> better scheme to distribute the tasks & interrupts over the cores.
>>>>>>> I still don't know why core #1 already got an issue with just our 6 interrupts.
>>>>>>> This may be related to the SPIRAM fix adding overhead, but I've seen the FIFO
>>>>>>> overflows before applying the fix, and the CAN issue also has been present for
>>>>>>> over a year.
>>>>>>> My working hypothesis is some task/driver disabling interrupts for too often
>>>>>>> / too long, or non-IRAM ISRs getting delayed for too often / too long. And it
>>>>>>> seems this is an issue especially on core #1.
>>>>>>> Please verify & comment.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> PS: a little side mystery: the netmanager task starts with priority 5, then
>>>>>>> gets raised to 22 (probably a mutex priority inheritance), but never gets
>>>>>>> lowered back to 5 afterwards. A FreeRTOS bug?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191211/2c954950/attachment-0001.html>
