[Ovmsdev] ESP-WROVER-B
Wed Dec 11 17:27:55 HKT 2019
Mark,
I'll do a new build this afternoon.
It's really nice we're getting more RAM on the fly.
Btw, we will need a separate build config once they also fix the PSRAM bug on the core. The workaround eats some performance (not too much, but
still).
Am 11.12.19 um 04:40 schrieb Mark Webb-Johnson:
> _*Short story:*_
> I suggest you set your development and production sdkconfig to:
> CONFIG_SPIRAM_TYPE_AUTO=y
> CONFIG_SPIRAM_TYPE_ESPPSRAM32=
> CONFIG_SPIRAM_SIZE=-1
> If you prefer menus, you can find that in 'make menuconfig': Compont config / ESP32-specific / SPI RAM config / Type of SPI RAM chip in use.
> Set it to Auto-detect.
> _*Long story:*_
> We previously used a hard-coded selection of "ESP-PSRAM32 or IS25WP032”, but that won’t work with the new ESP32-WROVER-B modules we are now
> using (as Espressif have discontinued the 4MB versions). Those new modules have 8MB PSRAM and are "ESP-PSRAM64 or LY68L6400”. The auto-detect
> setting seems to work well, and can detect and support the installed PSRAM automatically.
> With this new setting, we get:
> 4MB PSRAM module:
> I (895) psram: This chip is ESP32-D0WD
> I (896) spiram: Found 32MBit SPI RAM device
> 8MB PSRAM module:
> I (882) psram: This chip is ESP32-D0WD
> I (882) spiram: Found 64MBit SPI RAM device
> Without this auto-detect, OTA updating to our latest firmware will produce an endless loop:
> E (882) spiram: Expected 4096KiB chip but found 8192KiB chip. Bailing out..
> E (883) cpu_start: Failed to init external RAM!
> abort() was called at PC 0x400817fc on core 0
> Annoyingly, the bootloader code to detect a failure to load the OTA firmware doesn’t work, so it can’t fall back to factory.
> It can be recovered to factory using ESPTOOL:
> esptool.py --chip esp32 --port <path-to-serial-port> --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode
> dio --flash_freq 40m --flash_size detect 0xd000 ota_data_initial.bin 0x8000 partitions.bin
> I have built an edge release based on this, and will leave for 24 hours. If ok, I will then move that to EAP and to MAIN at the weekend. This
> will be 3.2.008. We need to get this out ASAP, as recipients of the new modules may do an OTA update and have issues (so far only 1, and he
> recovered using esptool).
> @Michael: I suggest you follow with your server. Let me know the path to your new update (from SPIRAM branch) and I will test on the
> ESP32-WROVER-B 8MB module I have here.
>> On 9 Dec 2019, at 9:42 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Our latest wifi-only modules are coming with ESP-WROVER-B module, and that includes 8MB PSRAM/SPIRAM (not 4MB, our standard so far). I have
>> had one report from the field that factory firmware 3.2.002 works fine, but 3.2.005 crashes on boot with an error:
>> (824) psram: This chip is ESP32-D0WD[[0m
>> (824) spiram: Expected 4096KiB chip but found 8192KiB chip. Bailing out..
>> I see we have this in our sdkconfig:
>> ( ) Auto-detect
>> (X) ESP-PSRAM32 or IS25WP032
>> ( ) ESP-PSRAM64 or LY68L6400
>> Not sure when that appeared, but I guess between 3.2.002 and 3.2.005.
>> The user experiencing this problem is knowledgeable (he managed to recover back to factory), so I am trying a 3.2.007 build with him, with
>> that setting set to auto-detect.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191211/cd3f531b/attachment.html>
