    Stephen Casner
    casner at acm.org
    Thu Aug 22 04:31:42 HKT 2019
Greg,
Mine has been quiet for the past couple of months without increasing
the alarm distance beyond the default 500 meters.
On Wed, 21 Aug 2019, Greg D. wrote:
> A quick follow-up to this thread...
> I've noticed that since this past spring that the number of false alerts regarding the
> flatbedding of my Roadster have taken a sharp spike upward. Neither my car's normal
> parking spot in the garage, nor the location of my house / garage have changed. The
> difference in frequency did not appear to coincide with a firmware update, so I'm at a
> bit of a loss to explain it.
> Has anyone else noticed this?
> Did the Government make a change to the GPS satellite fleet?
> Not an issue, really, but definitely something odd going on.
> Greg
> Stephen Casner wrote:
> Greg,
> Attached are graphs of your data.  gregd.all.png shows all of the
> data, and gregd.peak.png is the highest distance deviation of 369
> meters, which is less than the default 500 meter threshold.
> It looks like there is a diurnal pattern to the data with increased
> deviations around midnight local time (the X axis times are UTC).
> It also looks like your home elevation must be about 380 meters since
> the altitude variable drops down to negative that amount frequently,
> which would occur when that value is taken as zero (there is a special
> case in the code to treat some values as zero).
> I tried overlaying my data and yours, but there seems to be no
> correlation between the peaks in my data and the peaks in yours.
> Interestingly, my data does not show a similar diurnal pattern.
> On Tue, 4 Jun 2019, Greg D. wrote:
> 200mb of logs sent to Steve for analysis....
> Greg
> Thanks.  For me, today's log was much quieter.  The maximum excursion
> was 115 meters and it was roughly coincident with loss of lock.
> On Fri, 31 May 2019, Greg D wrote:
> Ok.  I'll let it run for a few days and see what happens. Not planning to drive the ca
> r until next week.
> Greg
> On May 31, 2019 2:11:31 PM PDT, Stephen Casner <casner at acm.org> wrote:
> On Fri, 31 May 2019, Greg D. wrote:
> Tried this, and am not getting anything written to the file system
> (vfs
> ls /sd shows zero bytes in gps.crtd).  Did I miss some sort of setup
> step?
> Nothing gets written (or at least the file size as reported is not
> updated) until the recording is stopped with "can log off".
