[Ovmsdev] Prototyping expansion board
    Fri Apr 19 15:17:09 HKT 2019
As the Mitsubishi code also reads battery current/power level from CAN, it would be trivial to add the same logic there.
Am 19.04.19 um 06:52 schrieb Tamás Kovács:
> The Trio (Mitsubishi I-Miev and clones) does not activate the brake light on recuperation on 2105 and older models, if this is work is very impressive.
> Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> ezt írta (időpont: 2019. ápr. 18., Cs, 23:08):
>     Mark,
>     that looks very good. Not sure about general demand, but I think we should have this to enable simple custom hardware I/O extensions.
>     For the Twizy, I was thinking about adding logic to control the brake light from the module. The Twizy does not activate the brake light on recuperation,
>     as that's normally (untuned) not very strong. But a tuned Twizy allows one pedal driving, so needs this.
>     Looking at our case I also think one custom extension board should fit on top of the modem.
>     Regards,
>     Michael
>     Am 18.04.19 um 02:36 schrieb Mark Webb-Johnson:
>>     It seems the attachments were messed up, so attaching again…
>>     Regards, Mark.
>>>     On 17 Apr 2019, at 10:07 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>         Design layout. Looks good to me, but open to suggestions...
>>>         We can make in sets of three PCBs, to keep prices down.
>>>         Regards, Mark
>>>     On 8 Apr 2019, at 12:05 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>     A kit of 5 PCBs + SIP edge connectors + mounting hardware, unsoldered, would be about US$15 + shipping. About US$3/board set. With shipping I don’t
>>>>     think this is worth doing with less than 3 or 5 boards per kit.
>>>>     Would this be useful?
>>>>     Regards, Mark.
>>>>>     On 7 Apr 2019, at 9:08 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>     This is the closest we have today:
>>>>>     <image1.jpeg>
>>>>>     That is a bare modem board, with just the sip connectors. The prototype above is a K-line transceiver.
>>>>>     I think it would be trivial, and cheap, to make up what you show. Perhaps just solder ready pads at 0.1” pitch, then the side sip connectors wired to
>>>>>     the first row of pads at each edge. Perhaps 5 PCBs in a kit, with sip edge connectors, unsoldered, in a simple plastic bag.
>>>>>     Does that sound like something useful? If so, I can ask the China guys for some idea of pricing. If it is just the unsoldered pcbs + parts, I don’t
>>>>>     think it will be expensive.
>>>>>     Regards, Mark
>>>>>     On 7 Apr 2019, at 4:38 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>     Mark,
>>>>>>     do you know of some kind of prototyping board available that fits to our piggy back expansion layout?
>>>>>>     Something like this: https://www.robotshop.com/de/de/cytron-arduino-proto-schild.html
>>>>>>     Regards,
>>>>>>     Michael
>>>>>>     Am 03.04.19 um 06:48 schrieb Mark Webb-Johnson:
>>>>>>>     If you have work to do on this DA26 expansion ports, this is pretty cool and well built:
>>>>>>>         https://www.aliexpress.com/item/26-Pin-D-SUB-DB26-3-Rows-Serial-Parallel-Port-Serial-Shellless-Male-And-Female-Connector/32886738786.html?spm=a2g0s.9042311.0.0.20924c4dg34EEU
>>>>>>>     _______________________________________________
>>>>>>>     OvmsDev mailing list
>>>>>>>     OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>     Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>     Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190419/b69afe50/attachment.htm>
