[Ovmsdev] Support for Kia e-Niro
    Sun Apr  7 16:13:39 HKT 2019
Sorry for the delay, e-Niro support is now also included in the Android App.
Quick charging is detected on base of the "performance" charge mode.
Am 02.03.19 um 12:42 schrieb Mark Webb-Johnson:
> Geir,
> Sounds great.
> I have merged the images into the App, so they will get included in the next master build.
>> On 1 Mar 2019, at 9:26 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
>> Hi,
>> I’m working on support for the Kia e-Niro, so as a part of that I’ve added images for the e-Niro in the App.
>> Mark, it would be great if you could merge my pull request to the iOS-app 🙂
>> Also, maybe someone could add the images to the Android app too?
>> A first version for the OVMS module will be coming soon. I hope 😜
>> There was an issue with polling using Extended 16-bit PIDS. There were no support for flow control and multiple response frames, so I’ve added that, similar to 8-bit PIDS. I see that it is used in ThinkCity and Volt/Ampera. Did it work there without flow control?
>> Best regards,
>> Geir
