[Ovmsdev] DA26 breakout
Wed Apr 3 12:48:00 HKT 2019
If you have work to do on this DA26 expansion ports, this is pretty cool and well built:
https://www.aliexpress.com/item/26-Pin-D-SUB-DB26-3-Rows-Serial-Parallel-Port-Serial-Shellless-Male-And-Female-Connector/32886738786.html?spm=a2g0s.9042311.0.0.20924c4dg34EEU <https://www.aliexpress.com/item/26-Pin-D-SUB-DB26-3-Rows-Serial-Parallel-Port-Serial-Shellless-Male-And-Female-Connector/32886738786.html?spm=a2g0s.9042311.0.0.20924c4dg34EEU>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190403/a23b4ffa/attachment-0003.html>
Name: 26-Pin-D-SUB-DB26-3-Rows-Serial-Parallel-Port-Serial-Shellless-Male-And-Female-Connector.jp2
Type: image/jp2
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190403/a23b4ffa/attachment-0001.jp2>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190403/a23b4ffa/attachment-0004.html>
Type: image/tiff
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190403/a23b4ffa/attachment-0001.tiff>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20190403/a23b4ffa/attachment-0005.html>
