Anko Hanse anko_hanse at hotmail.com
Mon Apr 1 16:22:10 HKT 2019
I do indeed think that it is unrelated to what you guys see as yours happens while the vehicle is parked while mine happens while the car is being driven.
Had another good look at the Nissan Leaf code and my incident might be introduced by myself.
I have been testing a code change around gathering of energy used/recd for the past weeks. Part of that is resetting those values when a trip starts, i.e. when the car is turned on.
My new code is identical to existing code in the Kia Soul and Mitsubishi in functions xxx_car_on(bool), so I really did not expect problems there.
But staring at it again today, I spotted that in that new code the v.e.on is only set once where previously it was set to on continuously during driving. As a result, it will go stale after a while and that might then trigger the theft warning.
I've adapted my new code, will be testing it for the next couple of days, and then will push it.  As stated, a similar issue might potentially be present in Kia Soul and Mitsubishi....
OKidoki,
Anko
-----Original Message-----
Sent: Monday, 1 April 2019 5:35 PM
To: OVMS Developers <ovmsdev at lists.openvehicles.com>
Subject: Re: [Ovmsdev] Locations and scripts
Anko,
Yours is an interesting additional datapoint, but I think the cause is unrelated.  In the cases I mentioned the cars were parked in our private garages.  As Mark suggested, for the Roadster the software may not be obtaining the GPS data in the most reliable manner.
On Mon, 1 Apr 2019, Anko Hanse wrote:
> I received one of those car theft messages as well, on March 24 at 17:10 New Zealand time.
> In my case the car (Nissan Leaf) was actually moving as my wife was driving somewhere while I was at home.
> A quick remote "metrics list" revealed that the "v.e.on" metric somehow remained false during the entire trip.
> Most other metrics seemed to be updating fine, including
> - gps location and speed
> - temperatures
> - v.b.voltage, v.b.current
> - v.b.soc
> - v.m.rpm
> Only saw this once, the next trip all was functioning as normal again. Did not have any logs running so had no way to further investigate.
> Just now made some screenshots of that metrics query from last week and added them to this post (hope that works). Could not figure out how to copy the full text from the messages tab in the Android App, it only seemed to copy the first half of the query result.
> From: Stephen Casner <casner at acm.org>
> Sent: Monday, 1 April 2019 4:12 AM
> Mark,
> This message reminds me to mention that both Timothy Rodgers and I have received false alarm car-theft notifications from OVMS.  Have you?  I presume these are caused by temporary inaccuracy in the GPS signal.
> On Sun, 31 Mar 2019, Mark Webb-Johnson wrote:
> > Except it does use the metric that says the car is on (for the car theft feature).
> > > On 31 Mar 2019, at 9:37 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> > > Location service just works off gps data. For cars using the gps in the simcom modules, that shouldn't rely on can at all.
> > > Regards, Mark
> > >> On 29 Mar 2019, at 3:56 PM, ovms <ovms at topphemmelig.no> wrote:
> > >> Hi
> > >> I would like to run scripts based on location. The scripts work fine, but the location service stops working.
> > >> I guess the location service requires CAN1 to be working?
> > >> Since CAN1 stops receiving after a short period of time, the location service also stops.
> > >> Is there a way to bypass this so the location service does not depend on CAN1 working?
> > >> Kind regards,
> > >> Stein Arne Sordal
