Mon Apr 1 09:38:48 HKT 2019
I don’t see this on the Model S vehicle.
I suspect the issue is not handling GPS lock indicator correctly in the vehicle modules. For the roadster, we use ID#100, B1=0x85 (GPS direction and altitude), B2==1 to control this, but that was always a ‘best guess’ without much data to back it up.
> On 31 Mar 2019, at 11:12 PM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> This message reminds me to mention that both Timothy Rodgers and I
> have received false alarm car-theft notifications from OVMS.  Have
> you?  I presume these are caused by temporary inaccuracy in the GPS
> signal.
> On Sun, 31 Mar 2019, Mark Webb-Johnson wrote:
>> Except it does use the metric that says the car is on (for the car theft feature).
>>> On 31 Mar 2019, at 9:37 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Location service just works off gps data. For cars using the gps in the simcom modules, that shouldn't rely on can at all.
>>> Regards, Mark
>>>> On 29 Mar 2019, at 3:56 PM, ovms <ovms at topphemmelig.no> wrote:
>>>> Hi
>>>> I would like to run scripts based on location. The scripts work fine, but the location service stops working.
>>>> I guess the location service requires CAN1 to be working?
>>>> Since CAN1 stops receiving after a short period of time, the location service also stops.
>>>> Is there a way to bypass this so the location service does not depend on CAN1 working?
>>>> Kind regards,
>>>> Stein Arne Sordal
