[Ovmsdev] "New" car add
Wed Sep 12 11:40:03 HKT 2018
It seems your module is not compiled in / registered (if it doesn’t appear in vehicle list).
Can you check your component.mk (the one in your vehicle directory, not the mail project one you attached). Make sure it matches the main/Kconfig name (with CONFIG at the start).
> On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt at gmail.com> wrote:
> In attachment
> compare on attachment picture
> OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit()
>   ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)");
>   MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot iOn");
> OvmsVehiclePeugeot::OvmsVehiclePeugeot()
>   ESP_LOGI(TAG, "Start Peugeot  vehicle module");
>   mi_candata_timer = 0;
>   mi_est_range = 0;
>   mi_stale_charge = 0;
>   mi_QC = 0;
>   mi_QC_counter = 5;
>   mi_last_good_SOC = 0;
>   mi_last_good_range = 0;
>   memset(m_vin,0,sizeof(m_vin));
>   memset(mi_batttemps,0,sizeof(mi_batttemps));
>   RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>   // require GPS:
>   MyEvents.SignalEvent("vehicle.require.gps", NULL);
>   MyEvents.SignalEvent("vehicle.require.gpstime", NULL);
> Type Name
> DEMO Demonstration vehicle
> FT5E Fiat 500e
> KS   Kia Soul EV
> MI   Mitsubishi iMiev
> NL   Nissan Leaf
> NONE Empty vehicle
> O2   OBDII
> RT   Renault Twizy
> TGTC Think City
> TR   Tesla Roadster
> TS   Tesla Model S
> VA   Volt/Ampera
> XX   TRACK
> ZEVA ZEVA BMS
> Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> ezt írta (időpont: 2018. szept. 11., K, 3:07):
> Can you show the source code for your module (github repository?), or just:
> Your component.mk <http://component.mk/>
> The changes you have made to sdkconfig
> Your OvmsVehicle***Init::OvmsVehicle**Init() function
> Your OvmsVehicle***::OvmsVehicle***() function
> Output of ‘vehicle list’ command
>> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt at gmail.com <mailto:kommykt at gmail.com>> wrote:
>> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works
>> well the basic functions for my car with Mitsubishi profile. I want to
>> create a own profile for my car for testing, my own code, but i
>> duplicate mitsubishi files in components folder, and all mitsubishi
>> change to peugeot (case sensitive), and vehicle code modified to PI,
>> and duplicate mitsibishi code in main/Kconfig and modify to peugeot,
>> but i can not see in the web interface after make flash. After add it
>> make show a question: add Peugeot to... i write Y, but nothing happen.
>> I use MacOS High Sierra, and atom for modify files.
>> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at 8.17.35.png>_______________________________________________
> Üdvözlettel:
> Kovács Tamás
> <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180912/330a63e1/attachment.htm>
