[Ovmsdev] Kia Soul strangeness
Geir Øyvind Vælidalo
geir at validalo.net
Sat Sep 29 17:15:04 HKT 2018
Sorry for the late reply. Busy days…
The radio comes on every five minutes in order to read the door lock status. The car has to be on to read the status, and that is currently the only way i could do that.
My newest version is not giving those «unrecognized command» messages, but there are some other issues I haven’t had time to debug yet.
Ideal range is something I’ve planned to look into.
I’ve also had some issues with the aux battery that have been worsened by the OVMS, so I really need to find ways to reduce the 12V power consumption, like polling less often on the CAN-buses while the car is not powered on.
Best regards,
Geir
> 28. sep. 2018 kl. 03:08 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> I have some support tickets raised for Kia Soul:
> https://www.openvehicles.com/node/2095 <https://www.openvehicles.com/node/2095>
> I have a 2018 Kia Soul EV.
> App Version: 3.12.4 (20180428)
> Vehicle: G8-Soul
> Server: 2.1.1-20121216
> Car Firmware: 3.1.010/ota_0/main
> The nav screen and / or radio comes on. I've only noticed this happening when the Level 2 charger is plugged in. This happens when the vehicle is locked as well.
> After a few minutes, the radio / NAV screen shuts off (like when it times out, before exiting the car). It will also shut off, as soon as the driver's door is opened.
> It also happens when the car is not plugged in.
> and:
> https://www.openvehicles.com/node/2094 <https://www.openvehicles.com/node/2094>
> Vehicle: G8-Soul
> When I lock, unlock, open / close doors, and I even noticed when the hazards lights are on. The app receives: "Unrecognized command", multiple times, sometimes 2-3, sometimes 10-15.
> Is there a way to disable this?
> and:
> https://www.openvehicles.com/node/2093 <https://www.openvehicles.com/node/2093>
> Im reciving "Unrecognised command" in may iOS app, every time I unlock/lock door, and many other staff.
> -when i unlock door
> -when I lock doors
> -when put on emergency signal
> -On OVMS i klik, that I want to use trunk knob on key set for opening
> -If I click on Lock in app ... and then enter PIN ... app crash
> - if I move "SLIDE TO CHARGE" nothing happened .... by the way, if car is charging, it say that... it should said "slide to stop charging" ( I think)
> - what means "ideal range" ? .... Estimated range is now 156km ... and Ideal Range is 45km ... what that means
> I still dont know how to add Soul Picture... in app I now using other car ...Ampera :(
> My Car KIA SOUL EV 30kW
> OVMS is version 3
> firmware is updated to newest one..
> Seems very strange. Any ideas? Any Kia Soul developers here can assist?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180929/0f6f9c4e/attachment.html>
