[Ovmsdev] Fwd: [ovms:2087] Consult on Renault twizy
Wed Sep 19 10:09:48 HKT 2018
@michael,
Could you help this user? I greped for the error text in OVMS v2, v3 and Android, source code, but can’t find it.
> Begin forwarded message:
> bricoauto has created the ticket 'Consult on Renault twizy':
> https://www.openvehicles.com/node/2087#comment-0
> State: new
> Priority: normal
> You can visit the following URL to update this ticket:
> https://www.openvehicles.com/node/2087#comment-form
> Ticket text:
> I have successfully installed the Ovms 3.1 module in my renault twizy, but I
> still do not know how to modify parameters. For example with the App, if I
> want to modify the speed limitation, it tells me the following error message:
> Can bus not in active mode
> I guess that writing or reading by can not be active, because I can not see
> the fault logs etc ...
> Could you help me with this?
> Regards!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/cbf86302/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/cbf86302/attachment-0001.png>
