[Ovmsdev] "New" car add
Tamás Kovács
kommykt at gmail.com
Sat Sep 15 12:11:12 HKT 2018
First i change to factory partition , nothing happen, and after run "make
app-flash", now show my "new car"
Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2018. szept.
15., Szo, 3:36):
> Yep. You are running from ota_1:
> [image: image1.jpeg]
> Please try changing to factory partition, which is what ‘make app-flash’
> writes to.
> Regards, Mark
> On 15 Sep 2018, at 12:31 AM, Tamás Kovács <kommykt at gmail.com> wrote:
> First i run
> - "make flash" at first time, the ovms "booted" up
> - and *not *shown in web interface,
> - "vehicle list" command
> - not shown peugeot
> - "make size-components|grep -e 'Archive' -e peugeot"
> - output same as yours
> - sdkconfig
> - same as yours
> - make monitor
> - not shown "v-peugeot: Registering Vehicle: PEUGEOT ION (9000)" row
> I don't understand what is a problem. Now i install debian 9 -on my laptop
> to test in the car, and write code, but same as if i compile on my Mac.
> I attach some picture, to show some state.
> 14., P, 3:19):
>> I compiled your code, and get:
>> I (287) v-twizy: Registering Vehicle: Renault Twizy (9000)
>> I (293) v-peugeot: Registering Vehicle: PEUGEOT ION (9000)
>> I (300) v-obdii: Registering Vehicle: OBDII (9000)
>> OVMS# vehicle list
>> Type Name
>> DEMO Demonstration vehicle
>> FT5E Fiat 500e
>> KS Kia Soul EV
>> MI Mitsubishi iMiev
>> NL Nissan Leaf
>> NONE Empty vehicle
>> O2 OBDII
>> PI Peugeot iOn
>> RT Renault Twizy
>> TGTC Think City
>> TR Tesla Roadster
>> TS Tesla Model S
>> VA Volt/Ampera
>> XX TRACK
>> ZEVA ZEVA BMS
>> The Peugeot iOn also appears in the web interface config vehicle list.
>> My sdkconfig has:
>> # Vehicle Support
>> CONFIG_OVMS_VEHICLE_NONE=y
>> CONFIG_OVMS_VEHICLE_OBDII=y
>> CONFIG_OVMS_VEHICLE_TRACK=y
>> CONFIG_OVMS_VEHICLE_DEMO=y
>> CONFIG_OVMS_VEHICLE_TESLAROADSTER=y
>> CONFIG_OVMS_VEHICLE_TESLAMODELS=y
>> CONFIG_OVMS_VEHICLE_NISSANLEAF=y
>> CONFIG_OVMS_VEHICLE_RENAULTTWIZY=y
>> CONFIG_OVMS_VEHICLE_KIASOULEV=y
>> CONFIG_OVMS_VEHICLE_VOLTAMPERA=y
>> CONFIG_OVMS_VEHICLE_THINKCITY=y
>> CONFIG_OVMS_VEHICLE_MITSUBISHI=y
>> CONFIG_OVMS_VEHICLE_PEUGEOT=y
>> CONFIG_OVMS_VEHICLE_ZEVA=y
>> CONFIG_OVMS_VEHICLE_FIAT500=y
>> CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40
>> Also:
>> $ make size-components|grep -e 'Archive' -e peugeot
>> Archive File DRAM .data & .bss IRAM Flash code & rodata
>> Total
>> libvehicle_peugeot.a 0 54 0 3655 531
>> 4240
>> Can you try to recreate that? Do you get the same? If not, what
>> differences?
>> On 14 Sep 2018, at 1:16 AM, Tamás Kovács <kommykt at gmail.com> wrote:
>> I use first time github, commit change, and push to my github reposytory:
>> gitHub
>> <https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/upsteam/peugeot>,
>> and after pull request (I should not have done it)
>> szept. 12., Sze, 6:46):
>>> Easiest way would be for you to commit changes, push to a github
>>> repository, then let us know where that is so that we can check. Very hard
>>> to help find where the issue is, without actually being able to see the
>>> code.
>>> When the module starts, it will show initialisation of modules - please
>>> check to ensure your module shows up there. If initialisation works, then
>>> check the vehicle list to be sure it is registered.
>>> On 12 Sep 2018, at 12:22 PM, Tamás Kovács <kommykt at gmail.com> wrote:
>>> In component.mk and main/Kconfig has the same name.
>>> Kconfig: config OVMS_VEHICLE_PEUGEOT
>>> component.mk (in vehicle folder): CONFIG_OVMS_VEHICLE_PEUGEOT
>>> szept. 12., Sze, 5:40):
>>>> It seems your module is not compiled in / registered (if it doesn’t
>>>> appear in vehicle list).
>>>> Can you check your component.mk (the one in your vehicle directory,
>>>> not the mail project one you attached). Make sure it matches the
>>>> main/Kconfig name (with CONFIG at the start).
>>>> Regards, Mark.
>>>> On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt at gmail.com> wrote:
>>>> - In attachment
>>>> - compare on attachment picture
>>>> - OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit()
>>>> ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)");
>>>> MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot
>>>> iOn");
>>>> - OvmsVehiclePeugeot::OvmsVehiclePeugeot()
>>>> ESP_LOGI(TAG, "Start Peugeot vehicle module");
>>>> mi_candata_timer = 0;
>>>> mi_est_range = 0;
>>>> mi_stale_charge = 0;
>>>> mi_QC = 0;
>>>> mi_QC_counter = 5;
>>>> mi_last_good_SOC = 0;
>>>> mi_last_good_range = 0;
>>>> memset(m_vin,0,sizeof(m_vin));
>>>> memset(mi_batttemps,0,sizeof(mi_batttemps));
>>>> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
>>>> // require GPS:
>>>> MyEvents.SignalEvent("vehicle.require.gps", NULL);
>>>> MyEvents.SignalEvent("vehicle.require.gpstime", NULL);
>>>> - Type Name
>>>> - DEMO Demonstration vehicle
>>>> - FT5E Fiat 500e
>>>> - KS Kia Soul EV
>>>> - MI Mitsubishi iMiev
>>>> - NL Nissan Leaf
>>>> - NONE Empty vehicle
>>>> - O2 OBDII
>>>> - RT Renault Twizy
>>>> - TGTC Think City
>>>> - TR Tesla Roadster
>>>> - TS Tesla Model S
>>>> - VA Volt/Ampera
>>>> - XX TRACK
>>>> - ZEVA ZEVA BMS
>>>> szept. 11., K, 3:07):
>>>>> Can you show the source code for your module (github repository?), or
>>>>> just:
>>>>> - Your component.mk
>>>>> - The changes you have made to sdkconfig
>>>>> - Your OvmsVehicle***Init::OvmsVehicle**Init() function
>>>>> - Your OvmsVehicle***::OvmsVehicle***() function
>>>>> - Output of ‘vehicle list’ command
>>>>> Regards, Mark.
>>>>> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt at gmail.com> wrote:
>>>>> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works
>>>>> well the basic functions for my car with Mitsubishi profile. I want to
>>>>> create a own profile for my car for testing, my own code, but i
>>>>> duplicate mitsubishi files in components folder, and all mitsubishi
>>>>> change to peugeot (case sensitive), and vehicle code modified to PI,
>>>>> and duplicate mitsibishi code in main/Kconfig and modify to peugeot,
>>>>> but i can not see in the web interface after make flash. After add it
>>>>> make show a question: add Peugeot to... i write Y, but nothing happen.
>>>>> I use MacOS High Sierra, and atom for modify files.
>>>>> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at
>>>>> 8.17.35.png>_______________________________________________
>>>>> OvmsDev mailing list
>>>> Üdvözlettel:
>>>> Kovács Tamás
>>>> <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>
>>> Üdvözlettel:
>>> Kovács Tamás
>> Üdvözlettel:
>> Kovács Tamás
> Üdvözlettel:
> Kovács Tamás
> <IMG_2030.jpg>
> <IMG_2026.jpg>
> <IMG_2029.jpg>
> <IMG_2031.jpg>
> <make_monitor.pdf>
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180915/0396341f/attachment-0001.html>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180915/0396341f/attachment-0002.jpeg>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180915/0396341f/attachment-0003.jpeg>
