[Ovmsdev] "New" car add
Tamás Kovács
kommykt at gmail.com
Wed Sep 12 12:22:02 HKT 2018
In component.mk and main/Kconfig has the same name.
Kconfig: config OVMS_VEHICLE_PEUGEOT
component.mk (in vehicle folder): CONFIG_OVMS_VEHICLE_PEUGEOT
Mark Webb-Johnson <mark at webb-johnson.net> ezt írta (időpont: 2018. szept.
12., Sze, 5:40):
> It seems your module is not compiled in / registered (if it doesn’t appear
> in vehicle list).
> Can you check your component.mk (the one in your vehicle directory, not
> the mail project one you attached). Make sure it matches the main/Kconfig
> name (with CONFIG at the start).
> On 12 Sep 2018, at 12:11 AM, Tamás Kovács <kommykt at gmail.com> wrote:
> - In attachment
> - compare on attachment picture
> - OvmsVehiclePeugeotInit::OvmsVehiclePeugeotInit()
> ESP_LOGI(TAG, "Registering Vehicle: PEUGEOT ION (9000)");
> MyVehicleFactory.RegisterVehicle<OvmsVehiclePeugeot>("PI","Peugeot iOn");
> - OvmsVehiclePeugeot::OvmsVehiclePeugeot()
> ESP_LOGI(TAG, "Start Peugeot vehicle module");
> mi_candata_timer = 0;
> mi_est_range = 0;
> mi_stale_charge = 0;
> mi_QC = 0;
> mi_QC_counter = 5;
> mi_last_good_SOC = 0;
> mi_last_good_range = 0;
> memset(m_vin,0,sizeof(m_vin));
> memset(mi_batttemps,0,sizeof(mi_batttemps));
> RegisterCanBus(1,CAN_MODE_ACTIVE,CAN_SPEED_500KBPS);
> // require GPS:
> MyEvents.SignalEvent("vehicle.require.gps", NULL);
> MyEvents.SignalEvent("vehicle.require.gpstime", NULL);
> - Type Name
> - DEMO Demonstration vehicle
> - FT5E Fiat 500e
> - KS Kia Soul EV
> - MI Mitsubishi iMiev
> - NL Nissan Leaf
> - NONE Empty vehicle
> - O2 OBDII
> - RT Renault Twizy
> - TGTC Think City
> - TR Tesla Roadster
> - TS Tesla Model S
> - VA Volt/Ampera
> - XX TRACK
> - ZEVA ZEVA BMS
> 11., K, 3:07):
>> Can you show the source code for your module (github repository?), or
>> just:
>> - Your component.mk
>> - The changes you have made to sdkconfig
>> - Your OvmsVehicle***Init::OvmsVehicle**Init() function
>> - Your OvmsVehicle***::OvmsVehicle***() function
>> - Output of ‘vehicle list’ command
>> On 11 Sep 2018, at 2:27 AM, Tamás Kovács <kommykt at gmail.com> wrote:
>> Hi, i have a Peugoet iOn, some week ago i buy a OVMS v3.1 kit. Works
>> well the basic functions for my car with Mitsubishi profile. I want to
>> create a own profile for my car for testing, my own code, but i
>> duplicate mitsubishi files in components folder, and all mitsubishi
>> change to peugeot (case sensitive), and vehicle code modified to PI,
>> and duplicate mitsibishi code in main/Kconfig and modify to peugeot,
>> but i can not see in the web interface after make flash. After add it
>> make show a question: add Peugeot to... i write Y, but nothing happen.
>> I use MacOS High Sierra, and atom for modify files.
>> <Screen Shot 2018-09-06 at 8.17.21.png><Screen Shot 2018-09-06 at
>> 8.17.35.png>_______________________________________________
> Üdvözlettel:
> Kovács Tamás
> <component.mk><Screen Shot 2018-09-11 at 6.04.29.png>
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180912/2c7ea16c/attachment.html>
