[Ovmsdev] v3.1.010 OTA
Wed Sep 12 11:44:15 HKT 2018
Robin,
It is generally ok to accept default. We try to make them sane.
Our OVMS bluetooth component depends on the main ESP32 bluetooth setting. So our entire bluetooth stuff gets turned off if bluetooth support in ESP32 is disabled - you won’t even see the option to enable it.
> On 11 Sep 2018, at 8:44 PM, Robin O'Leary <ovmsdev at caederus.org> wrote:
> On Fri, Aug 31, 2018 at 08:36:54AM +0800, Mark Webb-Johnson wrote:
>> I just released v3.1.010 OTA to ‘main’. Everyone gets it.
> After updating git to the latest 'master' and doing a build with the
> default config from vehicle/OVMS.V3/support/sdkconfig.default.hw31,
> I had to answer config questions for some new options that lack default
> values:
>> CONFIG_OVMS_HW_CONSOLE_QUEUE_SIZE=100
>> CONFIG_OVMS_HW_ASYNC_QUEUE_SIZE=100
>> CONFIG_OVMS_HW_EVENT_QUEUE_SIZE=20
>> CONFIG_OVMS_HW_NETMANAGER_QUEUE_SIZE=10
>> CONFIG_OVMS_HW_CAN_RX_QUEUE_SIZE=30
>> CONFIG_OVMS_HW_CAN_TX_QUEUE_SIZE=20
>> CONFIG_OVMS_VEHICLE_ZEVA=
>> CONFIG_OVMS_VEHICLE_CAN_RX_QUEUE_SIZE=40
> I was previously turning off bluetooth with the option
> < CONFIG_OVMS_COMP_BLUETOOTH=
> but that option has now disappeared; is that intentional?
