[Ovmsdev] Config backup & restore
Sun Oct 14 10:32:43 HKT 2018
I have:
# First, update the IDF
echo Updating ESP IDF...
cd $IDF_PATH
/usr/bin/git pull
/usr/bin/git submodule init
/usr/bin/git submodule update
echo
# Next, update the OVMS code
echo Updating OVMS code...
cd $OVMS_TREE
/usr/bin/git pull
echo
Which seems to work for me.
> On 14 Oct 2018, at 12:05 AM, Craig Leres <leres at xse.com> wrote:
> On 10/3/18 5:38 AM, Michael Balzer wrote:
>> I've added ZIP archive support. This is based on zlib and libzip, which are included as new submodules, so you'll need to do "git submodule update" after pulling the update.
> My update script already does that:
> #!/bin/sh
> set -x
> git fetch upstream
> git checkout master
> git merge upstream/master
> git push
> Which updates my fork but I could not build after due to the lack of zip.h. I found this:
> https://stackoverflow.com/a/38673595
> which suggests:
> git submodule init
> # or
> git submodule update --init
> The latter pulled in the new submodules and I then was able to build.
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181014/33cbbee6/attachment.htm>
