[Ovmsdev] Attention: esp-idf upgrade still breaks configuration
    Thu Nov 29 08:24:56 HKT 2018
I tried to replicate the fault on both my desk and car modules. Neither could repeat the fault (using IDF version you requested). I guess in that case, no point trying the fix?
I am wondering if completely wiping flash, and re-installing from scratch, would work to recreate the problem?
Anyway, I will try again tonight on a couple of brand new modules, to see if we can see the problem there. Probably good to take a raw backup of the flash partition first.
> On 28 Nov 2018, at 5:35 AM, Michael Balzer <dexter at expeedo.de> wrote:
> @all: we need some help on this.
> Dmitry has asked us to verify an assumption about the source of the problem. Unfortunately, my module has decided to not show the bug anymore.
> Can anyone a) reproduce the bug and b) check Dmitry's code change? The code change is very simple:
> https://github.com/espressif/esp-idf/issues/2730#issuecomment-441928779 <https://github.com/espressif/esp-idf/issues/2730#issuecomment-441928779>
> …that's in file esp-idf/components/wear_levelling/WL_Flash.cpp line 183.
> Chances are the bug is more frequently present on V3.1 first batch modules.
> To test a build including the bug, do:
> OVMS# config backup /sd/cfgbackup.zip
> ~/…/esp-idf> git checkout 5afc1b0cbbcd5903744cd2948ee235b7016eeede
> ~/…/esp-idf> git merge --no-commit 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8
> ~/…/esp-idf> git submodule update --recursive
> ~/…/OVMS.V3> git checkout c3c908c00a09c4a841d1fec115be785c8f486270
> ~/…/OVMS.V3> make app-flash
> Then do some reboots of the module.
> If the bug shows up, usually the second reboot already will result in a lost configuration. You'll see some warnings in the boot process (mount failure), and the prompt will directly be "#" as no module password is in place.
> If that happens, rebuild after applying the change as described by Dmitry, restore your config (see below), check if the bug is gone. If it isn't, the change definitely doesn't work.
> If it's gone, as the bug can stop showing up, you need to revert Dmitry's change and check once again if the bug reappears. If it does, the change definitely works.
> If the bug doesn't reappear, you need to switch off the module for some hours, then redo the above steps.
> Note on restoring the config backup: as my later restore fix isn't included in that version, you may need to create the events directory manually:
> OVMS# vfs mkdir /store/events
> OVMS# config restore /sd/cfgbackup.zip <password>
> To return to normal build setup:
> ~/…/esp-idf> git checkout -f master
> ~/…/OVMS.V3> git checkout master
> Please report definitive results directly to Dmitry in the issue #2730.
> Thanks,
> Am 27.11.18 um 02:02 schrieb Mark Webb-Johnson:
>> I think unmount should be on the system.shutdown event. That would be after system.shuttingdown and the MyBoot.RestartPending/RestartReady control steps.
>> That means if a component really wants to write to config (or elsewhere on /store), it should do it during system.shuttingdown event (and optionally do the MyBoot.RestartPending(TAG) and MyBoot.RestartReady(TAG) thing, like simcom).
>> As you say, that doesn’t address the crash-during-shuttingdown issue, but can be done in a very component manner. No changes to MyBoot - all done in ovms_config. Or just hard-code the /store unmount before esp_restart().
>>> On 27 Nov 2018, at 12:47 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Dimitris question about unclean shutdowns let me check our reboot code, and we actually do not take care of unmounting the config store.
>>> While my crash observations do not look like crash/clean makes a difference to this bug, I still think we should do that.
>>> The simple solution would be to do this last, in Boot::boot_shutdown_done() just before the esp_restart(), but that does not take care of crashes during shutdown, which still are too frequent.
>>> How about unmounting /store ASAP after the shuttingdown event (i.e. normal shutdown handling)?
>>> Writing to the config would then have no effect during shutdown, but do we actually need (want) that to be possible?
>>> Am 25.11.18 um 03:12 schrieb Mark Webb-Johnson:
>>>> I second this. A fantastic effort, Michael.
>>>> The log you provided on the GitHub issue looks really helpful, and I see Dimitri has replied:
>>>> dmitry1945 <https://github.com/dmitry1945> commented 6 hours ago <https://github.com/espressif/esp-idf#issuecomment-441391665>
>>>> Thank you @dexterbg <https://github.com/dexterbg>, the place is clear.
>>>> Hopefully Dimitri can find the issue from here. So many little bugs in wifi and bluetooth stacks causing us random issues - it would be helpful to be able to update to the latest IDF.
>>>> Thanks, and Regards,
>>>> Mark.
>>>>> On 25 Nov 2018, at 3:22 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>>> Michael -- Kudos for this Herculean effort -- Steve
>>>>> On Sat, 24 Nov 2018, Michael Balzer wrote:
>>>>>> Narrowing this down is a real PITA. The effect sometimes stops to occur, I then need to leave the module powered down for a while to get the effect back.
>>>>>> Sometimes 1 hour is sufficient, currently it's been off for 2 hours and still works. I had a test window yesterday evening, one this morning and one in the
>>>>>> afternoon. Temperature is most probably irrelevant, as the last power downs were outside in ~4-5 °C to rule this out.
>>>>>> So as a "passed" can always be a false positive I need to validate every passed step by switching back to a failing version and see if that still fails.
>>>>>> It seems I now have to wait until tomorrow for the next test window, but I have bisected down to this range of just 8 commits:
>>>>>> balzer at leela:~/esp/esp-idf> git rev-list 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8 ^9d2f7c60d9aef9860c61c2756318ada68c80fddf
>>>>>> f392727abf7d56490c2f33127a59bfac42c937e0
>>>>>> e834d6fffc23a6fcfc0d2e871c9235417a7fb48f
>>>>>> 35842d02abb5f574aaab466d46081a232fdd20a6
>>>>>> f05f3fbde87a9ce45c6818f71b49cd13888fd457
>>>>>> a6d6c58ecadb9759a0bacf35cd7332ac641e598d
>>>>>> 321b1e02052de95db60ddce87eecce5f9e04e9b8
>>>>>> 40486c872345584d34949b3ce83f9e956a7eea13
>>>>>> ...with 9d609af54c63e7f949a4fbc43d4f1c13b57f49d8 being the last identified bad commit, and 9d2f7c60d9aef9860c61c2756318ada68c80fddf being the last good.
>>>>>> If I should guess now, it's probably one of Dmitry's commits on the wear leveling code.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 23.11.18 um 17:20 schrieb Michael Balzer:
>>>>>>> It's not a timing issue, I've let it reboot about 30 times without any successful mount after the first failure.
>>>>>>> Going into bisecting now...
>>>>>>> Am 23.11.18 um 15:54 schrieb Mark Webb-Johnson:
>>>>>>>>> It may actually not be a corruption of the filesystem but some timing issue on the mount procedure. To test that we could disable the auto formatting on
>>>>>>>>> mount failures.
>>>>>>>> True.
>>>>>>>> A couple of Espressif guys have jumped on the issue, and I have provided some more information for them. I think key will be reproducing it.
>>>>>>>>> The issue may also be dependant on the hardware version, i.e. it could be caused by the bug that caused the SD speed issue on the first 3.1 batch.
>>>>>>>> That was definitely a hardware issue with the CP2102 chip. I don't think related to ESP in any way.
>>>>>>>> Regards, Mark.
>>>>>>>>> On 23 Nov 2018, at 10:34 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de><mailto:dexter at expeedo.de <mailto:dexter at expeedo.de>>> wrote:
>>>>>>>>> mount failures.
>>>>>>>>> I only have tried the idf update on my batch 1 module (my bench / development module). I think most of our edge testers also have that version.
>>>>>>>>> Regards,
>>>>>>>>> Michael
>>>>>>>>> Am 23.11.18 um 02:32 schrieb Mark Webb-Johnson:
>>>>>>>>>> I have raised the following github issue to Espressif:
>>>>>>>>>>    https://github.com/espressif/esp-idf/issues/2730 <https://github.com/espressif/esp-idf/issues/2730>
>>>>>>>>>>        Environment
>>>>>>>>>>      * Development Kit: none
>>>>>>>>>>      * Kit version (for WroverKit/PicoKit/DevKitC): none
>>>>>>>>>>      * Module or chip used: ESP32-WROVER 16MB
>>>>>>>>>>      * IDF version (run |git describe --tags| to find it): v3.2-beta1-208-g0d7f2d77c
>>>>>>>>>>      * Build System: make
>>>>>>>>>>      * Compiler version (run |xtensa-esp32-elf-gcc --version| to find it): (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 5.2.0
>>>>>>>>>>      * Operating System: macOS
>>>>>>>>>>      * Power Supply: USB
>>>>>>>>>>        Problem Description
>>>>>>>>>>    TLDR: Between May and July 2018 a change was made to esp idf master that is causing corruption on FAT filesystems mounted on SPI flash.
>>>>>>>>>>    Our project uses a partitions.csv as follows:
>>>>>>>>>>    |# Name, Type, SubType, Offset, Size nvs, data, nvs, 0x9000, 0x4000 otadata, data, ota, 0xd000, 0x2000 phy_init, data, phy, 0xf000, 0x1000 factory,
>>>>>>>>>>    app, factory, 0x10000, 4M ota_0, app, ota_0, , 4M ota_1, app, ota_1, , 4M store, data, fat, , 1M |
>>>>>>>>>>    The 'store' partition is formatted as FAT, as follows:
>>>>>>>>>>    esp_vfs_fat_mount_config_t m_store_fat;
>>>>>>>>>>    wl_handle_t m_store_wlh;
>>>>>>>>>>    memset(&m_store_fat,0,sizeof(esp_vfs_fat_sdmmc_mount_config_t));
>>>>>>>>>>    m_store_fat.format_if_mount_failed = true;
>>>>>>>>>>    m_store_fat.max_files = 5;
>>>>>>>>>>    esp_vfs_fat_spiflash_mount("/store", "store", &m_store_fat, &m_store_wlh);
>>>>>>>>>>    We have previously used a clone of esp idf master, dated around May 22 2018, without issues. The partition is very reliable.
>>>>>>>>>>    However, on Jul 6 2018, we updated our clone to use the latest esp idf master at that time. Shortly afterwards, users started to report that their
>>>>>>>>>>    'store' filesystem contents were corrupted. We rolled back.
>>>>>>>>>>    We have now tried again (updating on Oct 20 2018 to v3.2-beta1-208-g0d7f2d77c) and immediately had the same issue. Random corruption of FAT filesystem
>>>>>>>>>>    in SPI flash.
>>>>>>>>>>          Expected Behavior
>>>>>>>>>>    No corruption of FAT filesystem.
>>>>>>>>>>          Actual Behavior
>>>>>>>>>>    Corruption of FAT filesystem.
>>>>>>>>>>          Steps to reproduce
>>>>>>>>>>     1. Create a partition in SPI flash, and mount FAT filesystem
>>>>>>>>>>     2. Read and write to files on FAT filesystem
>>>>>>>>>>     3. Reboot
>>>>>>>>>>     4. Observe random corruption and unmountable filesystem
>>>>>>>>>>          Code to reproduce this issue
>>>>>>>>>>        Debug Logs
>>>>>>>>>>    n/a
>>>>>>>>>>        Other items if possible
>>>>>>>>>>    Please advise if you need anything further.
>>>>>>>>>> I think the timeline is correct (the issue is in esp idf master some time between May and July 2018), but please let me know if you know differently (or
>>>>>>>>>> update the github issue with your comments).
>>>>>>>>>> Regards, Mark
>>>>>>>>>>> On 23 Nov 2018, at 6:19 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de><mailto:dexter at expeedo.de <mailto:dexter at expeedo.de>>> wrote:
>>>>>>>>>>> esp-idf and OVMS branches are back to the working version.
>>>>>>>>>>> In case you also lost your config:  I also just fixed a bug on restoring into an empty /store partition.
>>>>>>>>>>> Regards,
>>>>>>>>>>> Michael
>>>>>>>>>>> Am 22.11.18 um 22:34 schrieb Michael Balzer:
>>>>>>>>>>>> See https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/165 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/165>
>>>>>>>>>>>> I'll reset both master branches now.
>>>>>>>>>>>> If you're about to pull, please wait until I've reverted the branches.
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Michael
>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com> <mailto:OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>>
>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
>>>>>                                                        -- Steve_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181129/11d80ac7/attachment.htm>
