[Ovmsdev] Add version strings to the boot partitions on the firmware page
Fri Nov 23 09:11:18 HKT 2018
Yep, that is it. Also in espressif github issue tracker:
https://github.com/espressif/esp-idf/issues/2136 <https://github.com/espressif/esp-idf/issues/2136>
> On 15 Nov 2018, at 1:34 AM, Craig Leres <leres at xse.com> wrote:
> On 11/14/18 4:09 AM, Mark Webb-Johnson wrote:
>> There seems to be a compilation warning:
>>    $ make -j 4
>>    Build version is 3.1.011-21-g5d46d82
>>    CXX build/main/ovms_version.o
>>    In file included from main/ovms_version.cpp:34:0:
>>    esp/esp-idf/components/bootloader_support/include/esp_image_format.h:44:3:
>>    warning: 'esp_image_spi_freq_t' defined but not used [-Wunused-variable]
>>      } esp_image_spi_freq_t;
>> I merged it, to allow further testing on ‘edge’ boxes, but it would be good if that could be cleaned up.
> Sorry, when I hit this I fixed what looked like an obvious typo but didn't notice it was in esp-idf. Here's the pull request:
>    https://github.com/openvehicles/esp-idf/pull/3/files
> 		Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181123/fd574bd1/attachment.htm>
