[Ovmsdev] BMS generalization (was: Custom metrics)
    Tamás Kovács
    kommykt at gmail.com
    Sat Nov 17 13:31:33 HKT 2018
Now i found the problem, i used this (
https://dexters-web.de/f/ovms-dev/ovms.zip) to create web interface for
battery monitor, and has one failure , this rows:
if (update["v.b.c.temp"] || update["v.b.c.temp.min"] ||
update["v.b.c.temp.max"])
it modified you in git to :
"if (update[\"v.b.c.voltage\"] != null\n"
"|| update[\"v.b.c.voltage.min\"] != null\n"
"|| update[\"v.b.c.voltage.max\"] != null)\n"
now i moved my code same as Tesla Model S
Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2018. nov. 17., Szo,
0:36):
> Mark, Tamás,
> I haven't had the time yet to take care of the stddev port, but I've just
> added the generalized web UI.
> Please see git log for details and send some screenshots.
> Am 11.11.18 um 16:47 schrieb Mark Webb-Johnson:
> OK. I spent some time on this today, and sent in a first draft (as a bunch
> of extensions to vehicle.{h, cpp}). I migrated the Tesla Model S code to
> use it, and support came down to just a few simple lines of code.
> For the moment, I dropped the idea of ‘readingsperrow’, as I think that is
> Tesla Model S specific, and not really necessary. Purely presentational.
> c++ std::bitset is fixed size, so that doesn’t work for us. The
> std::vector<bool> seems a workable alternative, but I am not really happy
> with using std::find as a way of looking to see if we have everything. It
> works as it is, but is not very optimal. It seems there should be a better
> way of doing that. I think it is a pretty key feature, given the broadcast
> nature of the buses, to help the vehicle module know when it has a set of
> data ready to commit to metrics, so will need to think about this some more.
> I also implemented min and max, for voltages and temperatures. They went
> in cleanly. Haven’t tackled stddev yet (or the watchers/alerts, overall
> aggregates, etc). There is a very basic ‘bms status’ command implemented.
> Let me know what you think of it.
> Regards, Mark
> On 11 Nov 2018, at 5:11 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> yes, .min & .max are the minimum and maximum readings seen since last
> battery monitor reset. The reset should be available as…
>    - OvmsVehicle::ResetCellStats();
>    - Command: "vehicle bms reset" …or just "bms reset" as we also have
>    other vehicle commands on the root level?
> On the Twizy I do an auto reset each time the vehicle is turned on and
> each time a charge starts, but that behaviour should be controllable by the
> vehicle / user.
> There's additionally the overall { .stddev, .avg } on voltages and
> temperatures of the pack. These and the cell level statistics can be
> calculated by the framework, so the vehicle simply needs to provide the
> readings. The framework needs to provide a way to reset the readings
> completion bitset, i.e.
>    - OvmsVehicle::RestartCellVoltages();
>    - OvmsVehicle::RestartCellTemperatures();
> …as sometimes readings get lost, and adding new to the previous readings
> may lead to an inconsistent view leading to wrong standard deviation.
> Speaking of standard deviation, the framework should also provide warnings
> and alerts flags. On the Twizy it does so by checking deviation thresholds,
> and there's a general stddev warn & alert threshold to detect overall
> condition and two alert thresholds on the cell level, one for normal stddev
> and one for stddev alert mode. Warning flags on the cell level are set when
> the cell deviation is above stddev. On the Twizy these thresholds are
> currently fixed to…
> // Battery cell/cmod deviation alert thresholds:
> #define BATT_DEV_TEMP_ALERT         3       // = 3 °C
> #define BATT_DEV_VOLT_ALERT         6       // = 30 mV
> // ...thresholds for overall stddev:
> #define BATT_STDDEV_TEMP_WATCH      2       // = 2 °C
> #define BATT_STDDEV_TEMP_ALERT      3       // = 3 °C
> #define BATT_STDDEV_VOLT_WATCH      3       // = 15 mV
> #define BATT_STDDEV_VOLT_ALERT      5       // = 25 mV
> …these are good defaults for the Twizy 43 Ah pouch cells, but may be too
> low for an 18650 pack, and will especially not fit cheap LFP type cells. So
> these should be configurable, i.e.
>    - vehicle bms.dev.temp.alert [°C]
>    - vehicle bms.dev.voltage.alert [V]
>    - vehicle bms.stddev.temp.watch [°C]
>    - vehicle bms.stddev.temp.alert [°C]
>    - vehicle bms.stddev.voltage.watch [V]
>    - vehicle bms.stddev.voltage.alert [V]
> I can generalize the Twizy code for all of this.
> The Twizy battery monitoring command set is:
> OVMS# xrt batt ?
> data-cell            Output cell record
> data-pack            Output pack record
> reset                Reset alerts & watches
> status               Status report
> tdev                 Show temperature deviations
> temp                 Show temperatures
> vdev                 Show voltage deviations
> volt                 Show voltages
> The "data" commands provide the server historical records output. The
> other commands originate from the V2 and have been designed to keep the
> output within the SMS msg size limit.
> "status" gives an operative overview of the standard and max deviation
> levels of cells with warning or alert status. "volt", "vdev", "temp" and
> "tdev" show all cells.
> The Twizy generates a battery alert notification from the "status" output
> whenever some cell alert flag is set.
> The Twizy server records also originate from the V2 limits, and can now
> better be changed to vectors. I've just finished a virtual dynamometer on
> the Twizy, sending a vector metric to the server is just a matter of…
> std::string msg = "RT-ENG-MotTrqDrv,0,86400,";
> msg.append(m_mon.m_mot_torque_drv->AsString());
> MyNotify.NotifyString("data", "xrt.pwr.mon", msg.c_str());
> Neat.
> The Twizy sends server records once per minute during drive/charge. The
> server update frequency should become tunable as well, as that would be a
> lot of additional data volume on large packs.
> The Twizy layout may be either…
>    - 14 cell groups in the pack
>    - 2 cell groups in each module
>    - 7 modules in the pack
>    - Each cell group has 1 voltage measurement (so, 14 individual voltage
>    measurements)
>    - Each module has 1 temperature measurements (so, 7 individual
>    temperature measurements)
>    - That means:
>       - OvmsVehicle::SetCellArrangementVoltage(14, 2,  7)
>       - OvmsVehicle::SetCellArrangementTemperature(7, 1, 7)
> …for the original battery, or for an LFP type replacement…
>    - 16 cell groups in the pack
>    - 16 cell groups in each module
>    - 1 module in the pack
>    - Each cell group has 1 voltage measurement (so, 16 individual voltage
>    measurements)
>    - Each module has 3 temperature measurements (so, 3 individual
>    - That means:
>       - OvmsVehicle::SetCellArrangementVoltage(16, 16,  8)
>       - OvmsVehicle::SetCellArrangementTemperature(3, 3, 3)
> Am 11.11.18 um 08:10 schrieb Mark Webb-Johnson:
> Looking at the discussion with Michael back in May, we came to some
> conclusions for this. I was happy back then with using ‘cell’ rather than
> ‘module’ as the naming, because (a) we are talking about cell/brick/module
> level here, not pack, and (b) it is shorter. It seems that the twizy has:
> xrt.b.cell.01.volt.act                   3.995V
> xrt.b.cell.01.volt.max                   4.12V
> xrt.b.cell.01.volt.maxdev                0.01V
> xrt.b.cell.01.volt.min                   3.795V
> xrt.b.cell.cnt                           14
> xrt.b.cmod.01.temp.act                   17°C
> xrt.b.cmod.01.temp.max                   23°C
> xrt.b.cmod.01.temp.maxdev                1°C
> xrt.b.cmod.01.temp.min                   16°C
> xrt.b.cmod.cnt                           7
> xrt.b.pack.1.temp.alerts
> xrt.b.pack.1.temp.max                    23°C
> xrt.b.pack.1.temp.min                    16°C
> xrt.b.pack.1.temp.stddev.max             1°C
> xrt.b.pack.1.temp.watches
> xrt.b.pack.1.volt.alerts
> xrt.b.pack.1.volt.max                    57.6V
> xrt.b.pack.1.volt.min                    52.8V
> xrt.b.pack.1.volt.stddev.max             0.005V
> xrt.b.pack.1.volt.watches                1,2,4,5,6,7,11,12,14
> xrt.b.pack.cnt                           1
> xrt.b.soc.max                            100%
> xrt.b.soc.min                            69.78%
> Trying to come up with a standard representation for this (so everyone can
> use a shared library, and share output displays), that works across all
> vehicles... Assuming we have one-dimensional arrays for different types of
> measurement (for voltage, temperature, etc), measurements are taken at the
> group of cells level (with perhaps different groupings for different
> readings), and aggregations/limits being automatically calculated, I think
> this has:
>    1. v.b.c.voltage
>    Vector<float> metric type array of voltage measurements
>    2. v.b.c.temp
>    Vector<float> metric type array of temperature measurements
>    3. Aggregations / limits
>    We could have v.b.c.voltage.min, v.b.c.voltage.max,
>    v.b.c.voltage.maxdev, v.b.c.temp.min, v.b.c.temp.max, and v.b.c.temp.maxdev
>    if we wanted to store these. Presumably they could be automatically
>    calculated? I am guessing ‘min’ is the minimal value seen, and ‘max’ the
>    maximum?
>    4. Setting as a batch
>    The way I’ve implemented the Model S is to keep a bitmap of values
>    set. For example, say we have 32 cell voltage measurements. Every time we
>    set a voltage measurement, we set the appropriate bit. When the bitmap is
>    full, zero the bitmap, then set the metric in bulk (setting the entire
>    vector). That seems to work well for Model S at least. The
>    aggregations/limits would be calculated (and set) when the batch is ready.
>    I suggest something like:
>    - OvmsVehicle::SetCellVoltage(int index, float value);
>       - OvmsVehicle::SetCellTemperature(int index, float value);
>       5. Arrangement
>    My thinking is that the count of measurements available can be defined
>    when the module initialises. We can also simply count the size of the
>    vectors, to know that. The issue is the cell/brick/module/pack arrangement;
>    How many voltage or temperature measurements per module, how many modules
>    in the pack, etc. I think we need to tell the system (a) the number of
>    readings expected, (b) the number of readings per module, and (c) a hint to
>    say how many readings to show per row. I suggest something like:
>    - OvmsVehicle::SetCellArrangementVoltage(int readings, int
>       readingspermodule, int readingsperrow)
>       - OvmsVehicle::SetCellArrangementTemperature(int readings, int
>       6. Commands
>    Once the above is defined we can have a ‘vehicle bms status’ command
>    to show the status (like the Tesla Model S one shown here, albeit more
>    polished):
>  1 | 3.981 V | 3.981 V | 3.981 V | 29.5 C
>    | 3.981 V | 3.981 V | 3.981 V | 30.3 C Max
>  2 | 3.981 V | 3.981 V | 3.982 V | 29.4 C
>    | 3.981 V | 3.981 V | 3.981 V | 29.8 C
>  3 | 3.982 V | 3.982 V | 3.981 V | 29.1 C
>    | 3.981 V | 3.981 V | 3.982 V | 29.7 C
>  4 | 3.982 V | 3.982 V | 3.982 V | 28.9 C Min
>    | 3.981 V | 3.982 V | 3.982 V | 29.7 C
>  5 | 3.982 V | 3.982 V | 3.982 V | 29.0 C
>    | 3.982 V | 3.981 V | 3.981 V | 29.6 C
>  6 | 3.982 V | 3.982 V | 3.982 V | 29.3 C
>    | 3.982 V | 3.982 V | 3.982 V | 29.6 C
>  7 | 3.981 V | 3.981 V | 3.981 V | 29.0 C
>    | 3.981 V | 3.981 V | 3.981 V | 29.6 C
>  8 | 3.982 V | 3.983 V | 3.982 V | 29.2 C
>    | 3.983 V | 3.982 V | 3.982 V | 29.9 C
>  9 | 3.982 V | 3.982 V | 3.981 V | 30.0 C
>    | 3.982 V | 3.981 V | 3.981 V | 29.7 C
> 10 | 3.979 V | 3.980 V | 3.979 V | 29.1 C
>    | 3.980 V | 3.979 V | 3.979 V | 29.8 C
> 11 | 3.980 V | 3.981 V | 3.981 V | 29.1 C
>    | 3.981 V | 3.981 V | 3.981 V | 29.4 C
> 12 | 3.981 V | 3.982 V | 3.981 V | 29.1 C
>    | 3.981 V | 3.981 V | 3.982 V | 29.3 C
> 13 | 3.982 V | 3.983 V | 3.982 V | 28.9 C
>    | 3.982 V | 3.982 V | 3.982 V | 29.4 C
> 14 | 3.981 V | 3.982 V | 3.982 V | 29.3 C
>    | 3.982 V | 3.982 V | 3.982 V | 29.5 C
> 15 | 3.981 V | 3.982 V | 3.981 V | 29.6 C
>    | 3.982 V | 3.981 V | 3.981 V | 29.9 C
> 16 | 3.982 V | 3.982 V | 3.982 V | 29.5 C
>    | 3.982 V | 3.981 V | 3.981 V | 29.8 C
>    Tmin: 28.9  Tmax: 30.3  Vmax: 3.983  Vmin: 3.979  Vmax-Vmin: 0.003
>  Vtot: 382.23
> Another variant of this display would be:
>  1 | 3.981 V | 3.981 V | 3.981 V | 3.981 V | 3.981 V | 3.981 V | 29.5 C. 30.3
> C Max |
>  2 | 3.981 V | 3.981 V | 3.982 V | 3.981 V | 3.981 V | 3.981 V | 29.4 C  29.8
> C     |
>  3 | 3.982 V | 3.982 V | 3.981 V | 3.981 V | 3.981 V | 3.982 V | 29.1 C  29.7
> C     |
>  4 | 3.982 V | 3.982 V | 3.982 V | 3.981 V | 3.982 V | 3.982 V | 28.9 C
> Min  29.7 C |
>  5 | 3.982 V | 3.982 V | 3.982 V | 3.982 V | 3.981 V | 3.981 V | 29.0 C  29.6
> C     |
> 16 | 3.982 V | 3.982 V | 3.982 V | 3.982 V | 3.981 V | 3.981 V | 29.5 C  29.8
> C.    |
>  Vtot: 382.23
> (The vehicle itself having the control via the SetCellArrangement methods)
> To provide a baseline usage case, the Tesla Model S has:
>    - 96 bricks in the pack
>    - 6 bricks in each module
>    - 16 modules in the pack
>    - Each brick has one voltage measurement (so, 96 individual voltage
>    measurements)
>    - Each module has two temperature measurements (so, 32 individual
>    - That means:
>       - OvmsVehicle::SetCellArrangementVoltage(96, 6, 3)
>       - OvmsVehicle::SetCellArrangementTemperature(32, 2, 1)
> Tesla Model X seems identical to Model S.
> I am still working on reverse engineering the Tesla Roadster, but it seems
> to have:
>    - 99 bricks in the pack
>    - 9 bricks in each module (aka sheet)
>    - 11 modules in the pack
>    - Each brick has one voltage measurement (so, 11*9 = 99 individual
>    voltage measurements)
>    - Each module has four temperature measurements (so, 11*4 = 44
>    individual temperature measurements)
>    - That means:
>       - OvmsVehicle::SetCellArrangementVoltage(99, 9, 9)
>       - OvmsVehicle::SetCellArrangementTemperature(44, 4, 4)
> For other cars that support cell-level measurements, do they fit this
> representation? If so, can we fill in the following for each car, to see
> how it fits in?
>    - XX cell groups in the pack
>    - XX cell groups in each module
>    - XX modules in the pack
>    - Each cell group has one voltage measurement (so, XX individual
>    - Each module has four temperature measurements (so, XX individual
>    - That means:
>       - OvmsVehicle::SetCellArrangementVoltage(N, Y,  Z)
>       - OvmsVehicle::SetCellArrangementTemperature(N, Y, Z)
> If they don’t fit, what changes are needed to make it work?
> On 11 Nov 2018, at 12:16 AM, Mark Webb-Johnson <mark at webb-johnson.net>
> wrote:
> I originally thought ‘brick’, or ‘module’ rather than ‘cell’, but happy
> with either. These are readings for groups of cells, rather than whole pack.
> Tesla Model S is 16 modules. 6 voltage readings, and 2 temperatures, per
> module.
> What is Kia Soul arrangement?
> Regards, Mark
> On 10 Nov 2018, at 11:26 PM, Henrik Scheel <henrik.scheel at spjeldager.dk>
> wrote:
> Hi Mark.
> Good idea with a generic array type metric, and standard metrics for
> common EV features!
> Just a quick note:
> The Kia Soul EV vehicle module will be able to utilize these
> metric-arrays. However, on the Soul, the voltages are for each physical
> pair of cells connected in parallel, and the temperatures are for 6 battery
> modules, and for the battery cooling air inlet.
> So, for the Kia Soul EV, the name “v.b.cell.temp” would be misleading, as
> each measured module temperature is representing the state for 16 pairs of
> cells.
> Aside from that, I am all for mapping the values in these new standardized
> metric types. Currently, the temperature average is calculated and mapped
> to a metric, and the 96 cell voltages are unmapped for Kia Soul EV.
> Best regards,
> Henrik
> Venlig hilsen / best regards
> Henrik R. Scheel
> Spjeldager Consult ApS
> Spjeldager 9
> DK-2630 Taastrup
> CVR: 34491399
> T: +45 2720 9828
> http://www.spjeldager.dk/
> Den 10. nov. 2018 kl. 15.34 skrev ovmsdev-request at lists.openvehicles.com:
> Send OvmsDev mailing list submissions to
>   ovmsdev at lists.openvehicles.com
> To subscribe or unsubscribe via the World Wide Web, visit
>   http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>   ovmsdev-owner at lists.openvehicles.com
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. Re: Custom metrics (Mark Webb-Johnson)
> Message: 1
> Date: Sat, 10 Nov 2018 22:34:46 +0800
> From: Mark Webb-Johnson <mark at webb-johnson.net> <mark at webb-johnson.net>
> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
> Subject: Re: [Ovmsdev] Custom metrics
> Message-ID: <1E30255B-5CC6-4EC4-BA9F-9CA41D156B11 at webb-johnson.net>
> Content-Type: text/plain; charset="utf-8"
> I?ve added UnregisterCommand() methods to ovms_command.{h, cpp}. I?ve also
> updated the vehicle_teslamodels code to UnregisterCommand in the
> destructor. I think that is cleaner. The unregistering of CAN buses already
> seems to be working properly, config parameters should persist (even
> without vehicle module loaded). I am still considering the situation with
> metrics (but tend to think that they should disappear when the vehicle
> module is unloaded).
> I?ve also changed the vehicle_teslamodels code to use single voltage and
> temperate metric arrays (I think my previous dual voltage temperature
> arrangement was incorrect). I think these can now become standard metrics
> (one for battery voltage, and another for temperature). How about
> v.b.cell.voltage and v.b.cell.temp? The interpretation of those vectors
> (how many modules primarily - with the calculation of voltages and
> temperatures per module being dependent on the realtime size of each array)
> will still be vehicle dependent, and I guess the vehicle module can provide
> hints to our standard component for this. Perhaps we can just implement it
> in vehicle.{h, cpp}? I think this standard module can deal with:
> An interface for specific vehicle module to specify the number of modules,
> number of voltage measurements, and number of temperature measurements
> available.
> Internal storage of cell voltages and temperatures.
> Tracking of when all voltages and temperatures have been set, and these
> should be written to metrics (as a transaction).
> Standardised command to display on terminal (like ?xts bms?).
> Web interface extensions (including the charting you have, a textual
> display, etc).
> I can handle all of the above, except the web interface. What do you
> think? Can these be standardised? Certainly for Tesla Roadster and Tesla
> Model S they appear to be able to be unified under one standard framework.
> On 8 Nov 2018, at 6:49 AM, Michael Balzer <dexter at expeedo.de>
> Mark,
> 1) yes, we're approaching a generic form now. The chart currently displays
> actual, min & max values from the arrays, and derives the overall average
> value. It automatically adapts to the number of voltages and temperatures
> stored in the arrays.
> It still lacks:
> a) Displaying max deviations, current standard deviation and max standard
> deviation recorded.
> b) Displaying cell/module warn & alert status. These are currently set
> metrics on the Twizy, could better be generalized as arrays as well, i.e.
> 0=normal, 1=warn, 2=alert.
> c) SOH / capacity and internal resistance should be generally available
> per cell as well (no data on these yet on the Twizy).
> And as this will visually overload the chart it will need some buttons to
> show/hide the parts.
> A general vehicle base support for these metrics could automatically keep
> min & max values, calculate deviations and derive warn/alert status from
> these. So basically a vehicle adapter only needs to provide voltages and
> temperatures (+ SOH and internal resistance as available). The reset
> command then can also normally just be a generalized version.
> 2) I should add some basic documentation on this to the developer manual
> (lacking time). For the RE tools I've got an API to inject arbitrary data
> into the websocket stream on my todo list, so live updates can be
> transported without polling.
> 4) Interesting idea, similar to a reverse proxy. As the channel will be
> very slow we will need to reduce the websocket update frequency, make it
> configurable or maybe auto-adapt to the current speed. Also, the proxy
> should cache static assets to speed up first time connects.
> The v2 protocol using RC4 encryption is a bad base for this. What's the
> current encryption on v3/MQTT?
> Am 07.11.18 um 01:50 schrieb Mark Webb-Johnson:
> Some questions/comments:
> I guess this is fairly generic. Voltages and temperatures, with possibly a
> different number of readings for each. Model S has two temperatures, but I
> guess we can just treat those as interleaved. Could it be put into a
> reusable component? Or could we have standard metrics for this now (battery
> module voltages and temperatures)? Maybe a single component that does all
> this (functions to set individual voltages and temperatures, define the
> layout for display, include web interface for chart and table, etc)?
> I really need to look at integration of extensions to the web interface.
> See how that is done. For my work on DBC and RE tools, it seems easiest to
> just create a web interface (rather than messing around with command line).
> Regarding the registration of commands and metrics, I am not sure if that
> is done correctly at the moment. In particular in the case a vehicle module
> is loaded, unloaded, then loaded again. It seems that RegisterCommand
> doesn?t do it right, and the metric object creation needs a guard to make
> sure the metric doesn?t already exist. I will try to tidy this up in Model
> S code, as a reference, before moving on to Roadster.
> I really haven?t used the web interface much, as it is not available over
> cellular. I was wondering if it could be encapsulated somehow within the
> v2/v3 protocol, and made available via the server? Something like
> https://api.openvehicles.com:8080/VEHICLEID
> <https://api.openvehicles.com:8080/VEHICLEID>
> <https://api.openvehicles.com:8080/VEHICLEID> tunnelled through (with
> authentication at the server level using the normal web server user
> account). Similarly for SSH access. These are both simple tcp/ip
> connections, so presumably could be injected into mongoose as fake
> connections. One possible approach would be SOCKS, and there is some
> reference code for LWIP <https://github.com/russdill/lwip/commit/dfeba616>
> <https://github.com/russdill/lwip/commit/dfeba616>. Another is TUN/TAP,
> again with reference code for LWIP
> <https://github.com/russdill/lwip/commit/47ca42f8>
> <https://github.com/russdill/lwip/commit/47ca42f8>. And then there is the
> standard PPP (although that would technically then be PPP within tcp/ip
> over PPP within async within GSM, which is a bit freaky).
> On 7 Nov 2018, at 4:52 AM, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de> <dexter at expeedo.de>> wrote:
> Mark, Tam?s,
> I've prepared a more or less generalized array version of my Twizy battery
> chart (OvmsVehicleRenaultTwizy::WebBattMon) for you. Easier to collect the
> data from actual arrays than separate metrics.
> This ZIP?
> <https://dexters-web.de/f/ovms-dev/ovms.zip>
> ?contains my local ovms web test/development folder. Unzip it into some
> local web server (needs to be run via http for javascript), then open the
> folder from a browser. You should see an OVMS web UI lookalike.
> Config ? CellChart loads "cellchart.htm". The blue button generates and
> injects test data. Should look like this:
> <eoibkbnkbpofdlab.png>
> Assuming you'll add some min/max records as well I left that code
> including the reset button in there. If you can't provide that yet, you can
> simply set min & max = act in the get_xxx_data functions. Other than that
> you should basically just need to change the metrics names.
> To generate C/C++ syntax from the file, use the script bin/mksrc:
> "bin/mksrc cellchart.htm >cellchart.cpp". The chart init URL needs to be
> changed for the production environment (see comment), and the test data
> generator can be removed. See OvmsVehicleRenaultTwizy::WebBattMon for
> reference.
> Maybe I should add that stuff to the repository as well?
> Am 06.11.18 um 15:56 schrieb Mark Webb-Johnson:
> Nice. I just implemented this for Model S using your new metric type.
> 96 individual brick voltages for each of the bricks, plus two temperatures
> for each of the 16 modules.
> Works well.
> On 1 Nov 2018, at 5:58 PM, Michael Balzer <dexter at expeedo.de
> Tam?s,
> I've been creating separate metrics for all cell values on the Twizy, but
> that only has 14 cells.
> We discussed this before, a better approach is introducing a new metric
> class for arrays. I have just done that for you, please pull.
> Usage example:
> OvmsMetricVector<float>* vf = new OvmsMetricVector<float>("test.volts",
> SM_STALE_MIN, Volts);
> vf->SetElemValue(3, 1.23);
> vf->SetElemValue(17, 2.34);
> float myvals[3] = { 5.5, 6.6, 7.7 };
> vf->SetElemValues(10, 3, myvals);
> With this data set, you get:
> OVMS# met lis test
> test.volts
>                               0,0,0,1.23,0,0,0,0,0,0,5.5,6.6,7.7,0,0,0,0,2.34V
> ?and in the web framework:
> metrics["test.volts"]
> (18) [0, 0, 0, 1.23, 0, 0, 0, 0, 0, 0, 5.5, 6.6, 7.7, 0, 0, 0, 0, 2.34]
> metrics["test.volts"][11]
> 6.6
> See template definition in ovms_metrics.h for more.
> Am 31.10.18 um 20:08 schrieb Tam?s Kov?cs:
> I have a Peugeot iOn, and i wan't to create own metrics for battery temp
> (66 piece) and voltage (88 (old) or 80(new) piece) for all cell (and show
> on web interface), and i don't understand how can i create it. Now my data
> in array-s from can messages 6E1-6E4.
> My git fork:
> https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/peugeot
> <https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/peugeot>
> vehicle_mitsubishi
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> <OvmsDev at lists.openvehicles.com>
> <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181110/b17e54e7/attachment.html>
> Subject: Digest Footer
> End of OvmsDev Digest, Vol 82, Issue 10
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181117/0ca77d41/attachment.htm>
