[Ovmsdev] Custom metrics
    Tamás Kovács
    kommykt at gmail.com
    Sun Nov  4 15:45:20 HKT 2018
Now working the button on the web interface. Now i understand how works, i
use Kia Soul for basics, a bit easier then Twizzy.
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2018. nov. 3., Szo,
20:44):
> Thanks for the support the cells.
> Now cell volts and temps are shown on web interface.
> Now my problem is not understand the Reset button working mechanism, i
> wan't to understand the Renault Twizzy code, but a bit complex, if i load
> Twizzy , and press the button, next show  a text, but is my loaded it
> shown: Unrecognised command.
> And i can not get any notification to my phone, use iOs app, and
> openvehicles v2 server, app working.
> Michael Balzer <dexter at expeedo.de> ezt írta (időpont: 2018. nov. 1., Cs,
> 10:58):
>> Tamás,
>> I've been creating separate metrics for all cell values on the Twizy, but
>> that only has 14 cells.
>> We discussed this before, a better approach is introducing a new metric
>> class for arrays. I have just done that for you, please pull.
>> Usage example:
>> OvmsMetricVector<float>* vf = new OvmsMetricVector<float>("test.volts",
>> SM_STALE_MIN, Volts);
>> vf->SetElemValue(3, 1.23);
>> vf->SetElemValue(17, 2.34);
>> float myvals[3] = { 5.5, 6.6, 7.7 };
>> vf->SetElemValues(10, 3, myvals);
>> With this data set, you get:
>> OVMS# met lis test
>> test.volts
>> 0,0,0,1.23,0,0,0,0,0,0,5.5,6.6,7.7,0,0,0,0,2.34V
>> …and in the web framework:
>> metrics["test.volts"]
>> (18) [0, 0, 0, 1.23, 0, 0, 0, 0, 0, 0, 5.5, 6.6, 7.7, 0, 0, 0, 0, 2.34]
>> metrics["test.volts"][11]
>> 6.6
>> See template definition in ovms_metrics.h for more.
>> Am 31.10.18 um 20:08 schrieb Tamás Kovács:
>> I have a Peugeot iOn, and i wan't to create own metrics for battery temp
>> (66 piece) and voltage (88 (old) or 80(new) piece) for all cell (and show
>> on web interface), and i don't understand how can i create it. Now my data
>> in array-s from can messages 6E1-6E4.
>> My git fork:
>> https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/peugeot
>> vehicle_mitsubishi
> Üdvözlettel:
> Kovács Tamás
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181104/d518fdcd/attachment.htm>
