[Ovmsdev] Custom metrics
Wed Nov 7 04:52:37 HKT 2018
Mark, Tamás,
I've prepared a more or less generalized array version of my Twizy battery chart (OvmsVehicleRenaultTwizy::WebBattMon) for you. Easier to collect the data from
actual arrays than separate metrics.
This ZIP…
https://dexters-web.de/f/ovms-dev/ovms.zip
…contains my local ovms web test/development folder. Unzip it into some local web server (needs to be run via http for javascript), then open the folder from a
browser. You should see an OVMS web UI lookalike.
Config → CellChart loads "cellchart.htm". The blue button generates and injects test data. Should look like this:
Assuming you'll add some min/max records as well I left that code including the reset button in there. If you can't provide that yet, you can simply set min &
max = act in the get_xxx_data functions. Other than that you should basically just need to change the metrics names.
To generate C/C++ syntax from the file, use the script bin/mksrc: "bin/mksrc cellchart.htm >cellchart.cpp". The chart init URL needs to be changed for the
production environment (see comment), and the test data generator can be removed. See OvmsVehicleRenaultTwizy::WebBattMon for reference.
Maybe I should add that stuff to the repository as well…
Am 06.11.18 um 15:56 schrieb Mark Webb-Johnson:
> Nice. I just implemented this for Model S using your new metric type.
> 96 individual brick voltages for each of the bricks, plus two temperatures for each of the 16 modules.
> Works well.
> On 1 Nov 2018, at 5:58 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Tamás,
>> I've been creating separate metrics for all cell values on the Twizy, but that only has 14 cells.
>> We discussed this before, a better approach is introducing a new metric class for arrays. I have just done that for you, please pull.
>> Usage example:
>> OvmsMetricVector<float>* vf = new OvmsMetricVector<float>("test.volts", SM_STALE_MIN, Volts);
>> vf->SetElemValue(3, 1.23);
>> vf->SetElemValue(17, 2.34);
>> float myvals[3] = { 5.5, 6.6, 7.7 };
>> vf->SetElemValues(10, 3, myvals);
>> With this data set, you get:
>> OVMS# met lis test
>> test.volts 0,0,0,1.23,0,0,0,0,0,0,5.5,6.6,7.7,0,0,0,0,2.34V
>> …and in the web framework:
>> metrics["test.volts"]
>> (18) [0, 0, 0, 1.23, 0, 0, 0, 0, 0, 0, 5.5, 6.6, 7.7, 0, 0, 0, 0, 2.34]
>> metrics["test.volts"][11]
>> 6.6
>> See template definition in ovms_metrics.h for more.
>> Am 31.10.18 um 20:08 schrieb Tamás Kovács:
>>> I have a Peugeot iOn, and i wan't to create own metrics for battery temp (66 piece) and voltage (88 (old) or 80(new) piece) for all cell (and show on web
>>> interface), and i don't understand how can i create it. Now my data in array-s from can messages 6E1-6E4.
>>> My git fork: https://github.com/KommyKT/Open-Vehicle-Monitoring-System-3/tree/peugeot
>>> vehicle_mitsubishi
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181106/1de36fab/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181106/1de36fab/attachment-0001.png>
