[Ovmsdev] Leaf door control
Stein Arne Sordal ovms at topphemmelig.no
Fri May 25 16:32:05 HKT 2018
Tom Parker:
Any chance you can implement door control to the Leaf?
It´s working great with this changes (the door parts):
vehicle_nissanleaf.cpp:
switch (command)
    case ENABLE_CLIMATE_CONTROL:
      ESP_LOGI(TAG, "Enable Climate Control");
      data[0] = 0x4e;
      data[1] = 0x08;
      data[2] = 0x12;
      data[3] = 0x00;
      break;
    case DISABLE_CLIMATE_CONTROL:
      ESP_LOGI(TAG, "Disable Climate Control");
      data[0] = 0x56;
      data[1] = 0x00;
      data[2] = 0x01;
      data[3] = 0x00;
      break;
    case START_CHARGING:
      ESP_LOGI(TAG, "Start Charging");
      data[0] = 0x66;
      data[1] = 0x08;
      data[2] = 0x12;
      data[3] = 0x00;
      break;
    case UNLOCK_DOORS:
      ESP_LOGI(TAG, "Unlook Doors");
      data[0] = 0x11;
      data[1] = 0x00;
      data[2] = 0x00;
      data[3] = 0x00;
      break;
    case LOCK_DOORS:
      ESP_LOGI(TAG, "Look Doors");
      data[0] = 0x60;
      data[1] = 0x80;
      data[2] = 0x00;
      data[3] = 0x00;
      break;
    default:
OvmsVehicle::vehicle_command_t OvmsVehicleNissanLeaf::CommandClimateControl(bool climatecontrolon)
  ESP_LOGI(TAG, "CommandClimateControl");
  return RemoteCommandHandler(climatecontrolon ? ENABLE_CLIMATE_CONTROL : DISABLE_CLIMATE_CONTROL);
OvmsVehicle::vehicle_command_t OvmsVehicleNissanLeaf::CommandLock(const char* pin)
    return RemoteCommandHandler(LOCK_DOORS);
OvmsVehicle::vehicle_command_t OvmsVehicleNissanLeaf::CommandUnlock(const char* pin)
    return RemoteCommandHandler(UNLOCK_DOORS);
vehicle_nissanleaf.h:
typedef enum
  ENABLE_CLIMATE_CONTROL,
  DISABLE_CLIMATE_CONTROL,
  START_CHARGING,
  UNLOCK_DOORS,
  LOCK_DOORS
  } RemoteCommand;
public:
    void IncomingFrameCan1(CAN_frame_t* p_frame);
    void IncomingFrameCan2(CAN_frame_t* p_frame);
    vehicle_command_t CommandHomelink(int button);
    vehicle_command_t CommandClimateControl(bool enable);
    virtual vehicle_command_t CommandLock(const char* pin);
    virtual vehicle_command_t CommandUnlock(const char* pin);
    void RemoteCommandTimer();
Kind regards,
Stein Arne Sordal
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180525/c16f9afd/attachment.htm>
