[Ovmsdev] Can buses stop after some time
Wed May 23 22:29:36 HKT 2018
I am also now seeing this.
Trying out the OBD2ECU HUD cables, I was having problems getting it to work. Those HUDs try to transmit at different baud rates, to probe for what is correct, and that is causing errors at our end. Once we get those errors, seemingly we can’t recover. A ‘can can3 start active 500000’ fixes the issue and the HUD connects.
It looks something like this:
OVMS# can can3 status
CAN:       can3
Mode:      Active
Speed:     500000
Interrupts:                   1
Rx pkt:                       0
Rx err:                     105
Rx ovrflw:                    0
Tx pkt:                       0
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Err flags: 0x8000
Or this:
CAN:       can3
Mode:      Active
Speed:     250000
Interrupts:                 146
Rx pkt:                       0
Rx err:                     128
Rx ovrflw:                    0
Tx pkt:                       0
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Err flags: 0x800b
E (713021) canlog: Error can3 intr=1 rxpkt=0 txpkt=0 errflags=0x8000 rxerr=1 txerr=0 rxovr=0 txovr=0 txdelay=0
E (713021) canlog: Error can3 intr=2 rxpkt=0 txpkt=0 errflags=0x8000 rxerr=2 txerr=0 rxovr=0 txovr=0 txdelay=0
E (713021) canlog: Error can3 intr=3 rxpkt=0 txpkt=0 errflags=0x8000 rxerr=4 txerr=0 rxovr=0 txovr=0 txdelay=0
CAN:       can3
Mode:      Active
Speed:     250000
Interrupts:                3757
Rx pkt:                       1
Rx err:                     128
Rx ovrflw:                    0
Tx pkt:                       1
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Err flags: 0x800b
CAN:       can3
Mode:      Active
Speed:     250000
Interrupts:                3775
Rx pkt:                      10
Rx err:                     128
Rx ovrflw:                    0
Tx pkt:                      10
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Err flags: 0x800b
And then the can bus dead (until ‘can start …’ to reset it).
Good news is that with those HUDs, it is very easy to recreate the fault condition. I’ll see what I can do to find out what is going on. My guess is we are not clearing the MCP2515 error condition correctly. I will try to find out what is going on...
> On 14 May 2018, at 6:17 PM, Tom Parker <tom at carrott.org> wrote:
> On 14/05/18 20:36, Stein Arne Sordal wrote:
>> I also tried to raise the stack size to 6144.
>> It seems like it got worse…Can buses (RX) stops working more often. TX is fine.
> I don't see an improvement either. I wrote the new firmware with updated sdkconfig at about 3pm yesterday and it rebooted and lost the state of charge metric at 8:45pm, the car woke up at midnight and started charging, providing data for the SOC metric, during the charge there were a couple of gaps in the telemetry, charging finished at 3:10am and the OVMS rebooted at 3:45. The OVMS then stopped sending telemetry completely at 7:20 am when the car was switched back on. I had a chance to plug a laptop in and the module was unresponsive on the serial port.
> I'm not sending the monotonic metric so it's only possible to see the first reboot after the car is switched off (when it forgets the SOC).
> I've built a version of the firmware with most things turned off (and found vehicle depends on webserver and webserver depends on OTA) I'll see how that goes tonight.
> Otherwise I'll get the datalogger out and/or try the sdcard logger again.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180523/7096e83a/attachment.htm>
