[Ovmsdev] Default values and fields...
Wed May 23 15:27:44 HKT 2018
Greg,
I haven't found a web site that offers a simple timezone string generator, your links also don't provide that.
I can include a list of standard zones for the main regions/capital cities into the web UI. Can you provide that?
Thanks,
Am 23.05.2018 um 01:36 schrieb Greg D.:
> Hi Steve, all,
> This totally highlights the problem. No offense intended to the developers (myself included), but we've not structured the product very well for "normal"
> folks who are somewhat technical, but have no inside knowledge of the product, prior versions, Linux, ESP-IDF, etc.
> How was I to know what to put in the Timezone field? Bear with me as I walk through my troubled mental process... And please take this as me trying to be
> helpful.
> // Begin Rant
> So, I've seen configuration screens a bazillion times asking for timezone. If there's not a pull-down, usually I would put in -7 for the US Pacific Daylight
> Time that I'm in right now, or -8 if on Standard Time, and make a mental note to change it next fall. Not a big deal; there are a dozen "clocks" here at the
> house that need semi-yearly care. What's one more? Sometimes the config would be -8 with a checkbox for enabling DST. More recent product config screens
> sometimes use cities, with Los Angeles being our "local" example. That's been the set, so glancing at (but not truly understanding the implications of) the
> fine print on the configuration screen, I simply put in my -7 and moved on. It's been that way for weeks, and I never noticed anything wrong until I saw the
> "GMT" reference on the Time at Boot status that I recently added. Should have been "PDT". Something's wrong. Playing the ever-so-observant beta tester, I
> dig in...
> So, back to the config screen I went. First, where was it? I was doing a firmware update, but it's not there, and there's no General config tab. Nothing
> labeled "Time". Finally found it under Vehicle. Really? I see my -7 still sitting there, so it wasn't lost. Finally I re-read the comment about a web link
> to "Example Timezone Strings", and think, huh, I guess there must be some other way to say "-7". I click on the link, and scan down the table. It says USA &
> Canada, Pacific Time, and PST8PDT. Odd, but ok. Copy & paste. Hit Save. Go back to the status page, and see PDT on the aforementioned boot status line.
> Also see the upgrade was done yesterday afternoon, and realize that was 2am GMT, so I guess it checks out. Annoying, but DONE.
> Now you tell me I'm /not done/, and that I really needed to click on the second link to the man page on glibc? And /understand/ it? Then research what the
> rules for DST computation are in my country, state, and so forth, to craft some sort of command lingo for the TZ engine?
> Reality check here. My HP 100LX palmtop, manufactured in */1992,/* does a better job at handling this. We've taken a simple task of entering a small, well
> known signed integer, and turned it into an exercise in POSIX programming and international politics. This for a parameter that has little, if any,
> consequence on the daily operation of the product as I currently use it.
> // End Rant
> With a grateful acknowledgment to Michael for his awesome work on the Webserver UI, I think we should take a pass through the configuration steps with an eye
> towards making this as turn-key as possible. I understand that he's made some significant changes to the UI since my module arrived (back on .003 code), so
> the improvements in initial config have not been reflected in what I am running now (since the config has already been set). As I noted in my previous email,
> I will blow my module back to factory defaults and start over, looking for places where we might improve things.
> I know that the V3 OVMS module is a VAST improvement over the prior versions, even without having experienced them myself. But to reach a broader audience,
> we need to continually look to improve the setup / configuration experience, especially as we add new and even more powerful features.
> Greg
> Stephen Casner wrote:
>> On Tue, 22 May 2018, Greg D. wrote:
>>> Oh, almost... My timezone was also wrong. It was set to -7 like I do
>>> everywhere else, instead of PST8PDT. Where did that come from? My only
>>> clue to this was that the new boot status display of time at last boot
>>> said GMT instead of PDT.
>> Because the ESP-IDF system does not have all the compiled-in timezone
>> code, we need to specify how to manage daylight saving time using the
>> long value for the TZ parameter. So not even PST8PDT is sufficient,
>> you need "PST8PDT,M3.2.0/2,M11.1.0".
>> -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180523/3b2361c3/attachment.htm>
