[Ovmsdev] Modem fails to connect
Fri May 18 15:43:26 HKT 2018
Greg,
not sure how you can insert an SD in the wrong orientation, they normally are mechanically protected against that, but it seems you did: the contacts need to
face the upper side of the case, towards the USB connector.
Am 18.05.2018 um 09:24 schrieb Greg D.:
> Hi Michael,
> Fair question.  Pretty sure I got it right.  The proto box was a lot trickier, but on both units I engaged the SD with the spring and pushed it into position
> where it clicked into place.  Another push and it unlatched and came out.  Certainly felt right.
> Presume the contacts side of the SD face the bottom of the case, away from the USB connector, right?  I didn't try it upside down.
> Greg
> Michael Balzer wrote:
>> Greg,
>> as that's the first time, are you sure you inserted the SD correctly? With a closed case you need a screw driver or similar to get it in. The slot has a
>> spring latch you can feel and hear.
>> Am 18.05.2018 um 01:56 schrieb Greg D.:
>>> Thanks, Michael, I'd missed that.  So, that explains the reboot status, but not why the SD card isn't seen.
>>> fdisk -l on my Linux system claims that the SD card is formatted FAT32, and it mounts / umounts just fine there.  The SD card is basically new / empty,
>>> other than a few directories auto-created when it was once inserted into a cell phone.  fsck.fat -v  is clean.  So, I'm puzzled what's preventing it from
>>> being seen.  A fresh build from this morning on my v3.0 proto module acts the same (minus the reboot).
>>> Greg
>>>> Greg,
>>>> 1. See https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/111 -- TL;DR: you should update to an "edge" build or build yourself.
>>>> 2. You need to format the SD card with FAT32, also users reported the MacOS FAT32 format would not be accepted by the module (I can't test that, all Linux
>>>> formatted cards work). There are some issues with the FAT implementation in esp-idf, i.e. with reading damaged partitions.
>>>> Regards,
>>>> Michael
>>>> Am 17.05.2018 um 22:49 schrieb Greg D.:
>>>>> Greg D. wrote:
>>>>>> I'll pick up the logging tomorrow, and provide that
>>>>> {sigh}
>>>>> I went to the car to grab a verbose log, and started poking around for the commands, etc.  Looked at the network status, and see that ppp has an IP
>>>>> address!  What?  Boot status showed:
>>>>>     OVMS# boot status
>>>>>     Last boot was 249 second(s) ago
>>>>>       This is reset #15 since last power cycle
>>>>>       Detected boot reason: FirmwareUpdate
>>>>>       Crash counters: 0 total, 0 early
>>>>>       CPU#0 boot reason was 12
>>>>>       CPU#1 boot reason was 12
>>>>>     OVMS#
>>>>>     OVMS# metric list m.version
>>>>>     m.version                                3.1.005/ota_1/main (build idf v3.1-dev-454-gdaef4b5c May  1 2018 21:38:50)
>>>>>     OVMS#
>>>>> ...which is bogus, since if it really upgraded the firmware it should be on .006.  Also, the OTA time is set to the default 2am, which is clearly not the
>>>>> current time in any relevant timezone.
>>>>> I had tried to insert an SD card for easier log portability, but for some reason it wasn't seen.  'sd status' says no SD card has been inserted, and sd
>>>>> mount fails.  There IS an active USB connection (being used for a serial console monitor), so our friendly cp2102 issue shouldn't be at play, and there is
>>>>> no firmware file present on the SD either, but the timing of the reboot is about right for when the SD was inserted.  It's a SanDisk 16gb Ultra Plus
>>>>> microsd...  No luck with it either on my 3.0 proto module, but it reads fine on my PC.  This is my first time trying to use a microSD card with the OVMS
>>>>> module, so I don't know what to expect.  Could be user error on my part?
>>>>> Did the act of jiggling the module and inserting the SD card cause a reboot, the reason for which was not logged (i.e. is the 'firmware upgrade' status
>>>>> leftover from the .004 -> .005 upgrade some weeks ago)?
>>>>>  {shrug}
>>>>> Anyway, bottom line are three issues:
>>>>>   1.  What caused my module to reboot with an apparently bogus "upgrade"?
>>>>>   2.  Why can't either of my modules see this SD card?
>>>>>   3.  I will need to wait for the loss of modem connectivity to reproduce, since the reboot "fixed" it...  Sorry.
>>>>> Greg
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180518/a51b9668/attachment.htm>
