[Ovmsdev] Modem fails to connect
Fri May 18 14:23:15 HKT 2018
Greg,
as that's the first time, are you sure you inserted the SD correctly? With a closed case you need a screw driver or similar to get it in. The slot has a spring
latch you can feel and hear.
Am 18.05.2018 um 01:56 schrieb Greg D.:
> Thanks, Michael, I'd missed that. So, that explains the reboot status, but not why the SD card isn't seen.
> fdisk -l on my Linux system claims that the SD card is formatted FAT32, and it mounts / umounts just fine there. The SD card is basically new / empty, other
> than a few directories auto-created when it was once inserted into a cell phone. fsck.fat -v is clean. So, I'm puzzled what's preventing it from being
> seen. A fresh build from this morning on my v3.0 proto module acts the same (minus the reboot).
> Greg
> Michael Balzer wrote:
>> Greg,
>> 1. See https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/111 -- TL;DR: you should update to an "edge" build or build yourself.
>> 2. You need to format the SD card with FAT32, also users reported the MacOS FAT32 format would not be accepted by the module (I can't test that, all Linux
>> formatted cards work). There are some issues with the FAT implementation in esp-idf, i.e. with reading damaged partitions.
>> Am 17.05.2018 um 22:49 schrieb Greg D.:
>>> Greg D. wrote:
>>>> I'll pick up the logging tomorrow, and provide that
>>> {sigh}
>>> I went to the car to grab a verbose log, and started poking around for the commands, etc. Looked at the network status, and see that ppp has an IP
>>> address! What? Boot status showed:
>>> OVMS# boot status
>>> Last boot was 249 second(s) ago
>>> This is reset #15 since last power cycle
>>> Detected boot reason: FirmwareUpdate
>>> Crash counters: 0 total, 0 early
>>> CPU#0 boot reason was 12
>>> CPU#1 boot reason was 12
>>> OVMS#
>>> OVMS# metric list m.version
>>> m.version 3.1.005/ota_1/main (build idf v3.1-dev-454-gdaef4b5c May 1 2018 21:38:50)
>>> OVMS#
>>> ...which is bogus, since if it really upgraded the firmware it should be on .006. Also, the OTA time is set to the default 2am, which is clearly not the
>>> current time in any relevant timezone.
>>> I had tried to insert an SD card for easier log portability, but for some reason it wasn't seen. 'sd status' says no SD card has been inserted, and sd
>>> mount fails. There IS an active USB connection (being used for a serial console monitor), so our friendly cp2102 issue shouldn't be at play, and there is
>>> no firmware file present on the SD either, but the timing of the reboot is about right for when the SD was inserted. It's a SanDisk 16gb Ultra Plus
>>> microsd... No luck with it either on my 3.0 proto module, but it reads fine on my PC. This is my first time trying to use a microSD card with the OVMS
>>> module, so I don't know what to expect. Could be user error on my part?
>>> Did the act of jiggling the module and inserting the SD card cause a reboot, the reason for which was not logged (i.e. is the 'firmware upgrade' status
>>> leftover from the .004 -> .005 upgrade some weeks ago)?
>>> {shrug}
>>> Anyway, bottom line are three issues:
>>> 1. What caused my module to reboot with an apparently bogus "upgrade"?
>>> 2. Why can't either of my modules see this SD card?
>>> 3. I will need to wait for the loss of modem connectivity to reproduce, since the reboot "fixed" it... Sorry.
>>> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180518/806de91b/attachment.htm>
