[Ovmsdev] Can buses stop after some time
Sat May 12 23:06:20 HKT 2018
I already changed the charge alerts to inline calls, but of course the stack footprint is a bit higher with notifications.
Am 12.05.2018 um 15:03 schrieb Mark Webb-Johnson:
> I think this is the new charge alerts in vehicle.{h, cpp}. They call the command ‘STAT’, which may consume a lot of stack (executing commands does).
> I suggest you change vehicle stack size to 6144. That is the default now in sdkconfig.default.hw31 that I just pushed. You will need to make menuconfig and
> find it in the vehicle support section of open vehicles component. Diff sdkconfig support/sdkconfig.default.hw31 to see the changes.
>> On 11 May 2018, at 10:15 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Can you:
>> diff sdkconfig support/sdkconfig.default.hw31
>> and make sure the same? Maybe stack sizes are different?
>> Or maybe something in your vehicle type is using up a lot of stack. Try ‘module tasks’ to see.
>>> On 11 May 2018, at 9:42 PM, Robin O'Leary <ovmsdev at caederus.org <mailto:ovmsdev at caederus.org>> wrote:
>>> On Fri, May 11, 2018 at 08:08:10PM +0800, Mark Webb-Johnson wrote:
>>>> I think —tags is missing?
>>>> I normally ‘git fetch origin —tags as the first step.
>>> Ah, thanks, that fixed the the version label.
>>> My build still crashes though, this time with another stack overflow:
>>> OVMS# ***ERROR*** A stack overflow in task OVMS Vehicle has been detected.
>>> abort() was called at PC 0x40092f00 on core 1
>>> Backtrace: 0x40092cec:0x3ffdcaf0 0x40092ee7:0x3ffdcb10 0x40092f00:0x3ffdcb30 0x4008f33c:0x3ffdcb50 0x40090f90:0x3ffdcb70 0x40090f46:0xa5a5a5a5
>>> Rebooting...
>>> 0x40092cec invoke_abort + 24 in section .iram0.text
>>> 0x40092ee7 abort + 39 in section .iram0.text
>>> 0x40092f00 vApplicationStackOverflowHook + 20 in section .iram0.text
>>> 0x4008f33c vTaskSwitchContext + 200 in section .iram0.text
>>> 0x40090f90 _frxt_dispatch in section .iram0.text
>>> 0x40090f46 _frxt_int_exit + 70 in section .iram0.text
>>> btw, something helpfully mapped the character sequence "[dash][dash]tags"
>>> in your message to "[en-dash]tags"; if you cut-and-paste that directly
>>> to a command line, you get a rather confusing error:
>>> $ git fetch origin —tags
>>> fatal: Couldn't find remote ref —tags
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180512/ba08813d/attachment.htm>
