[Ovmsdev] esp-idf release 3.0 / master
Fri May 11 23:50:41 HKT 2018
"module memory" doesn't show the allocation under "no task".
Up to now there have been no issues resulting from the low 32 bit RAM, the module has been running all day long, with all com channels and on multiple test
drives & charges without a single crash or other problem. Looks really good.
I think I'll roll out the build on my server to get some field results.
Am 11.05.2018 um 17:13 schrieb Stephen Casner:
> There are two possibilities:
> 1) The size of the 32-bit heap region may have been reduced because
> there is more code stored in RAM (perhaps for flash manipulation).
> 2) If the extra 32-bit RAM has been allocated from the heap, then
> "module memory" would show it under "no task".
> -- Steve
> On Fri, 11 May 2018, Michael Balzer wrote:
>> Update:
>> Am 11.05.2018 um 09:52 schrieb Michael Balzer:
>>> According to the task monitor the new 32 bit allocations account to the NetMan task:
>> Nope, the 32 bit usage of the NetMan task is the same as before. So the additional usage is outside the scope of our memory tracking, so must be a system
>> component -- correct, Steve?
