[Ovmsdev] Notifications Framework (subtype and filtering)
Thu May 10 21:19:40 HKT 2018
Sent a new Pull Request.
Geir
> 10. mai 2018 kl. 14:54 skrev Geir Øyvind Vælidalo <geir at validalo.net>:
> Great 🙂  I’ll cancel my last pull request and I’ll use password pin instead of password pincode.
> Best regards,
> Geir
>> 10. mai 2018 kl. 14:16 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> Ok
>> On 10 May 2018, at 8:13 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> …or I can add the PIN to the vehicle config page, if this is a generally useful field.
>>> Am 10.05.2018 um 14:09 schrieb Mark Webb-Johnson:
>>>> It is getting to be a big system, with very little documentation.
>>>> The ‘password’ config parameter is a general store for passwords. It is writeable by the user, but not readable. Firmware modules can read it just fine.
>>>> I suggest we use:
>>>> OVMS# config set password pin 1234
>>>> Just use that for your pin at the moment, and we’ll work out how best to use it for commands like LOCK/UNLOCK/VALET/UNVALET/etc later.
>>>> I have just added a bool PinCheck to OvmsVehicle. You can call that with the provided PIN and it will check against config password/pin (also returning false if the password/pin is not defined in config).
>>>> Regards, Mark.
>>>>> On 10 May 2018, at 7:29 PM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>>>>> I agree, but until now there was no protection at all.
>>>>> I haven’t had too much time to spend on OVMS, so there are so many parts of OVMS I don’t know nothing about, like the password store 🙂
>>>>> Can I just advice the users to do this: config set password pincode 1234
>>>>> And then verifying the pin code in code by comparing it with MyConfig.GetParamValue("password","pincode»)?
>>>>> Is that the way it is meant to be used?
>>>>> If so I can change that very quickly.
>>>>> Best regards,
>>>>> Geir
>>>>>> 10. mai 2018 kl. 13:06 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>>>>>> I see the PIN code there.
>>>>>> Probably ok for the moment, but I’m thinking that in general it would be good to have that vehicle pin code stored in the password config store, protected and available to all vehicles. We don’t need multiple vehicle-specific PINs in the one module.
>>>>>> Then, if defined we should use it to verify PINs locally before sending to the car. Privileged commands (such as scripts) could send it directly. We could also implement some protection in those basic commands again brute-force attacks. These pins are a real weakness is vehicle security systems.
>>>>>> Regards, Mark.
>>>>>>> On 10 May 2018, at 5:08 PM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>>>>>>> This is great, Mark!
>>>>>>> I’ve sent a pull request with changes where I’ve cleaned up the notifcations on the Kia Soul.
>>>>>>> Best regards,
>>>>>>> Geir
>>>>>>>> 9. mai 2018 kl. 15:50 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>>>>>>>> The modifications below have been implemented. Works for me on the bench.
>>>>>>>> Individual vehicle modules can turn this off (it defaults to on) by setting m_autonotifications=false in their constructor. Implementations can also override the individual Notify…() functions to disable particular notifications, or customise the output. For example, a Tesla Model S module may want to override NotifyValetHood() and send the alert as ‘frunk’ rather than ‘hood’.
>>>>>>>> For those testing this with individual vehicle support, you should be able to see the following standardised vehicle alerts now:
>>>>>>>> charge.started (a charge session has started)
>>>>>>>> heating.started (the battery is being heated, as part of a charge session)
>>>>>>>> charge.stopped (a charge session has been interrupted)
>>>>>>>> charge.done (a charge session has completed normally)
>>>>>>>> valet.enabled (valet mode has been enabled)
>>>>>>>> valet.disabled (valet mode has been disabled)
>>>>>>>> valet.hood (the vehicle hood has been opened, while in valet mode)
>>>>>>>> valet.trunk (the vehicle trunk has been opened, while in valet mode)
>>>>>>>> alarm.sounding (the vehicle alarm is sounding)
>>>>>>>> alarm.stopped (the vehicle alarm has stopped)
>>>>>>>> batt.12v.alert (the 12v battery is at a critically low voltage level)
>>>>>>>> batt.12v.recovered (the 12v battery voltage level has recovered)
>>>>>>>> I’ll be updating the user guide documentation now, as there are quite a lot of configuration options for this now. Should finish by tomorrow.
>>>>>>>> I think we’re about ready for 3.1.006 now? I need to test Michael’s new initial config system, but that code is in place so should be good to go.
>>>>>>>> Perhaps people can commit what they have this week, and we will build a 3.1.006 OTA release at the weekend?
>>>>>>>> As always, comments/suggestions/improvements welcome.
>>>>>>>> Regards, Mark.
>>>>>>>>> It is time to implement vehicle notifications (charge started, charge completed, charge interrupted, etc) in the vehicle modules I am supporting. It seems that this can be done in the vehicle.{h,cpp} framework in a standard manner, and work across all vehicle types. However, I guess that will break any notifications already being produced by other vehicle types.
>>>>>>>>> My suggestion is:
>>>>>>>>> A config parameter ‘notifications’, with individual instances to turn on/off the notifications. Default is all enabled.
>>>>>>>>> OvmsVehicle::MetricModified picks up metric changes and issues the standard notifications (checking ‘notifications’ parameter appropriately).
>>>>>>>>> charge_mode=>charging: Notify charge started
>>>>>>>>> charge_mode=>topoff: Notify charge started
>>>>>>>>> charge_mode=>heating: Notify battery heating started
>>>>>>>>> charge_mode=>done: Notify charge completed
>>>>>>>>> charge_mode=>stopped: Notify charge interrupted
>>>>>>>>> valet_mode=>on: Notify valet mode enabled
>>>>>>>>> valet_mode=>off: Notify valet mode disabled
>>>>>>>>> alarm=>on: Notify alarm is sounding
>>>>>>>>> alarm=>off: Notify alarm is off
>>>>>>>>> All the above should be suppressed for the initial setting of each parameter. I will have to look into metrics to see how best that should be done; one neat way is to keep a modification count (rather than the current m_defined boolean).
>>>>>>>>> Does that make sense? Any objections/suggestions?
>>>>>>>>> Regards, Mark
>>>>>>>>> On 9 May 2018, at 9:33 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>>>>> I’ve extended the notifications framework to include the concept of notification subtypes. This is in addition to the existing notification base types.
>>>>>>>>> This allows us to automatically filter notifications based on the granular subtypes. The filtering is done at the framework level, so all notification listeners need to do is turn it on (when they register).
>>>>>>>>> I have identified the following standard subtypes, and updated quite a few modules to use them:
>>>>>>>>> charge.stopped
>>>>>>>>> charge.state
>>>>>>>>> batt.alert
>>>>>>>>> batt.12v (seems similar to batt.alert, but not yet decided)
>>>>>>>>> homelink
>>>>>>>>> debug.crash
>>>>>>>>> xks.aux
>>>>>>>>> xrt.battmon
>>>>>>>>> xrt.power
>>>>>>>>> xrt.gps
>>>>>>>>> xrt.trip
>>>>>>>>> xrt.sevcon
>>>>>>>>> xrt.logs
>>>>>>>>> xrt.reset
>>>>>>>>> I would really rather have all the alert types standardised (including things like trip logs, gps tracking, etc) and working across all vehicle types. But this at least is a starting point.
>>>>>>>>> An example of it working is:
>>>>>>>>> OVMS# notify raise text info test hello
>>>>>>>>> Raise text notification for info/test as hello
>>>>>>>>> I (25618) ovms-server-v2: Send MP-0 PIhello
>>>>>>>>> OVMS# config set notify test none
>>>>>>>>> Parameter has been set.
>>>>>>>>> OVMS# config set notify test ovmsv2
>>>>>>>>> I (71368) ovms-server-v2: Send MP-0 PIhello
>>>>>>>>> I am working on the vehicle module automated alerts we previously discussed, and this is a pre-requisite. New standardised subtypes will come with that (such as charge.start, charge.done, etc).
>>>>>>>>> Regards, Mark.
>>>>>>>>>> Begin forwarded message:
>>>>>>>>>> From: GitHub <noreply at github.com <mailto:noreply at github.com>>
>>>>>>>>>> Subject: [openvehicles/Open-Vehicle-Monitoring-System-3] 7516c9: test framework commands for testing can bus tx/rx
>>>>>>>>>> Date: 9 May 2018 at 9:18:53 AM HKT
>>>>>>>>>> To: mark at webb-johnson.net <mailto:mark at webb-johnson.net>
>>>>>>>>>> Reply-To: GitHub <noreply at github.com <mailto:noreply at github.com>>
>>>>>>>>>>  Branch: refs/heads/master
>>>>>>>>>>  Home:   https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3>
>>>>>>>>>>  Commit: 7516c9681055ec7986a94ccb8cfb29bda5f1bce8
>>>>>>>>>>      https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/7516c9681055ec7986a94ccb8cfb29bda5f1bce8 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/7516c9681055ec7986a94ccb8cfb29bda5f1bce8>
>>>>>>>>>>  Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>>>>>>>>  Date:   2018-05-09 (Wed, 09 May 2018)
>>>>>>>>>>  Changed paths:
>>>>>>>>>>    M vehicle/OVMS.V3/main/test_framework.cpp
>>>>>>>>>>  Log Message:
>>>>>>>>>>  Commit: 183d26dc107bb21cd956776228d0a24030b115db
>>>>>>>>>>      https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/183d26dc107bb21cd956776228d0a24030b115db <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/183d26dc107bb21cd956776228d0a24030b115db>
>>>>>>>>>>  Changed paths:
>>>>>>>>>>    M vehicle/OVMS.V3/components/ovms_server_v2/src/ovms_server_v2.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/ovms_server_v3/src/ovms_server_v3.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle/vehicle.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_kiasoulev/src/vehicle_kiasoulev.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/rt_battmon.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/rt_notify.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/rt_sevcon.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/rt_sevcon_faults.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/components/vehicle_renaulttwizy/src/vehicle_renaulttwizy.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/main/ovms_boot.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/main/ovms_notify.cpp
>>>>>>>>>>    M vehicle/OVMS.V3/main/ovms_notify.h
>>>>>>>>>>  Log Message:
>>>>>>>>>>  Notifications: Framework extensions to add support for subtypes on notifications, and automatic filtering by subtype and distribution mechanism
>>>>>>>>>> Compare: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/57d8f1b449d6...183d26dc107b <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/57d8f1b449d6...183d26dc107b>
>>>>>>>>>>      **NOTE:** <note:**> This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/ <https://developer.github.com/changes/2018-04-25-github-services-deprecation/>
>>>>>>>>>>      Functionality will be removed from GitHub.com <http://github.com/> on January 31st, 2019.
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180510/e4885d8d/attachment.htm>
