[Ovmsdev] Issue #99, Can't turn off SIMCOM power
    Thu May  3 09:25:26 HKT 2018
Steve,
Makes sense. I’ve added it to the Kconfig.
> On 3 May 2018, at 5:27 AM, Stephen Casner <casner at acm.org> wrote:
> As I commented on Issue #99, I created the problem with SIMCOM not
> powering off because I had excluded CONFIG_OVMS_COMP_MAX7317 from the
> config and the power to the SIMCOM is controlled through the MAX7317
> chip.
> Would it make sense in Kconfig for config OVMS_COMP_MODEM_SIMCOM
> to depend upon OVMS_COMP_MAX7317?
