[Ovmsdev] Leaf 2016 30Kwh flapping SOC
Tom Parker tom at carrott.org
Wed May 2 19:55:19 HKT 2018
On 02/05/18 01:08, ovms wrote:
> *case 0x50d**:*   //Changed this from 5bc. 50d is the instrument SOC
> uint16_t nl_gids = ((uint16_t) d[0] << 2) | ((d[1] & 0xc0) >> 6);
> if (nl_gids == 1023)
> break;
> uint16_t max_gids = MyConfig.GetParamValueInt("xnl", "maxGids",
> GEN_1_NEW_CAR_GIDS);
> float km_per_kwh = MyConfig.GetParamValueFloat("xnl", "kmPerKWh",
> GEN_1_KM_PER_KWH);
> float wh_per_gid = MyConfig.GetParamValueFloat("xnl", "whPerGid",
> GEN_1_WH_PER_GID);
> m_gids->SetValue(nl_gids);
> StandardMetrics.ms_v_bat_soc->SetValue(*nl_gids / 4*);  //Changed this
> so the value is divided by 4.
> SOC now shows exactly the same in the app as the instrument-panel
> does, and is not flapping. (I know the instrument-panel is different
> from the true SOC)
I wasn't able to reproduce this. On my car and in the CAN bus captures
I've got, there is no 0x50d frame on the EV bus. Now that I'm back in
the house, I see that 0x50d is present on the Car CAN bus, but I don't
have any data on what's there.
My notes indicate that 0x55b on the EV bus contains the state of charge,
and I've implemented this at
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/master...carrott:nissan-leaf-soc-instrument?expand=1
along with a configuration option to choose how to show the SOC.
However 0x55b doesn't work how I expected on my 2016 24kWh car, I see
xnl.v.bat.gids                           140
xnl.v.bat.soc.instrument                 56.3%
xnl.v.bat.soc.newcar                     49.8221%
but the instrument cluster displays 52%. Could it be displaying 56.3 - 5
= 51.3 rounded up to 52?
Should I be looking at 0x50d on the car bus to faithfully display what
the instrument cluster displays? I'll check tomorrow.
Assuming we get this working, should we default to using the instrument
cluster state of charge, or the "new car" state of charge? I'm guessing
we should go with the instrument cluster value, which is a change from
previous behavior on the leaf but is in keeping with Mark's
"re-implement the broken calculations by the car".
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180502/9bd46efa/attachment.htm>
