[Ovmsdev] Mongoose update (git submodule update)
    Fri May 25 10:01:42 HKT 2018
Michael,
This seems a very neat solution, at a fundamental level, to the problem. I just worry if there are other parts of mongoose (other than buffers) that are going to hit this multi-threaded issue. I think, for safety, we need to make sure as much as possible is done inside the mongoose task.
Please let us know if it solves the problem you are seeing.
> On 24 May 2018, at 11:30 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Re: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/120
> I've pushed an update to our mongoose clone that should solve the spurious crashes in mbuf_insert().
> After the next git pull, you will also need to do a git submodule update.
> Please test for your setups and report if the crash still occurs or any new issues come up.
