[Ovmsdev] Early Crash (v.006)
Wed May 23 15:36:20 HKT 2018
Greg,
I just had a look. That crash is simply due to an initialization order mistake in your constructor, has nothing to do with the CAN bus: you create the m_rxqueue
_after_ starting the OBD2ECU_task, which uses the m_rxqueue:
static void OBD2ECU_task(void *pvParameters)
obd2ecu *me = (obd2ecu*)pvParameters;
CAN_frame_t frame;
while(1)
if (xQueueReceive(me->*m_rxqueue*, &frame, (portTickType)portMAX_DELAY)==pdTRUE)
// Only handle incoming frames on our CAN bus
if (frame.origin == me->m_can) me->IncomingFrame(&frame);
obd2ecu::obd2ecu(const char* name, canbus* can)
: pcp(name)
m_can = can;
xTaskCreatePinnedToCore(OBD2ECU_task, "OVMS OBDII ECU", 6144, (void*)this, 5, &m_task, 1);
* m_rxqueue = xQueueCreate(20,sizeof(CAN_frame_t));*
So the task can reach the xQueueReceive() call before the queue is actually usable.
Am 23.05.2018 um 03:29 schrieb Greg D.:
> Hi Mark,
> Yeah, big shrug here too. It occurs infrequently, during what was a reboot anyway, and the system recovered itself, so this isn't a critical issue unless it
> keeps happening (i.e. a crash/reboot loop). I suppose it could also occur with a frame coming in from a HUD, though that CAN bus is on a different interface
> chip so if the cause is hardware dependent, it might not occur.
> Perhaps we need to not launch the higher level applications (e.g. OBD2ECU) until maybe the 5 second mark, when we know the system is initialized and otherwise
> pretty stable, but within that "Early" timeframe? Just a thought,
> Greg
> Mark Webb-Johnson wrote:
>> Greg,
>> Yes, the MyCan.RegisterListener(m_rxqueue) will register for all messages on all CAN buses.
>> I am trying to work out a neat way of adding filters to this (both hardware and software). Some easy standard way of filtering traffic in a standard way
>> (like the BFP filters in Unix variants do for ethernet traffic). That will give us a performance boost for things like odb2ecu, retools, etc.
>> But you already have a "if (frame.origin == me->m_can)”, so not sure how this could be affecting you?
>>> What precisely is "early" in the context of a boot crash? That would put a bound on the size and location of the timing window.
>> 10 seconds, I believe. You can see it with the message "I (10576) housekeeping: System considered stable (RAM: 8b=99060-99176 32b=20)” about 10 seconds into
>> the boot.
>>> On 23 May 2018, at 7:55 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Hi Michael,
>>> Correct, not a config issue. I had assumed it was a race condition (first time I've seen it), but didn't realize it involved my code. Yikes!
>>> This is the call-back into the OBD2ECU task when a CAN frame is received in the system. Apparently everyone looking for a CAN frame gets called when a
>>> frame is received from any bus, and each process needs to filter out the ones they own. So, somehow a CAN frame was seen to have been received before the
>>> system was fully initialized. Perhaps something dropped into the hardware buffer after the chip was turned on, but not before the O/S had gotten everything
>>> situated for handling it. I don't currently have anything connected to the OBDII CAN bus (CAN3) on my module, so this must have been a frame from the car
>>> itself on CAN 1. CAN 2 is not used in my car.
>>> Greg
>>> Michael Balzer wrote:
>>>> Greg,
>>>> the backtrace says the crash happened here:
>>>> 0x4008f6de is in vTaskEnterCritical (/Users/mark/esp/esp-idf/components/freertos/include/freertos/portmacro.h:283).
>>>> 278 * Warning: From the ISA docs: in some (unspecified) cases, the s32c1i instruction may return the
>>>> 279 * *bitwise inverse* of the old mem if the mem wasn't written. This doesn't seem to happen on the
>>>> 280 * ESP32 (portMUX assertions would fail).
>>>> 281 */
>>>> 282 static inline void uxPortCompareSet(volatile uint32_t *addr, uint32_t compare, uint32_t *set) {
>>>> 283 __asm__ __volatile__ (
>>>> 284 "WSR %2,SCOMPARE1 \n"
>>>> 285 "S32C1I %0, %1, 0 \n"
>>>> 286 :"=r"(*set)
>>>> 287 :"r"(addr), "r"(compare), "0"(*set)
>>>> 0x4008eb10 is in xQueueGenericReceive (/Users/mark/esp/esp-idf/components/freertos/./queue.c:1455).
>>>> 1450 statements within the function itself. This is done in the interest
>>>> 1451 of execution time efficiency. */
>>>> 1452
>>>> 1453 for( ;; )
>>>> 1454 {
>>>> 1455 taskENTER_CRITICAL(&pxQueue->mux);
>>>> 1456 {
>>>> 1457 /* Is there data in the queue now? To be running the calling task
>>>> 1458 must be the highest priority task wanting to access the queue. */
>>>> 1459 if( pxQueue->uxMessagesWaiting > ( UBaseType_t ) 0 )
>>>> *0x4011f3fd is in OBD2ECU_task(void*) (/Users/mark/Documents/ovms/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/obd2ecu/src/obd2ecu.cpp:155).*
>>>> 150 obd2ecu *me = (obd2ecu*)pvParameters;
>>>> 151
>>>> 152 CAN_frame_t frame;
>>>> 153 while(1)
>>>> 154 {
>>>> *155 if (xQueueReceive(me->m_rxqueue, &frame, (portTickType)portMAX_DELAY)==pdTRUE)*
>>>> 156 {
>>>> 157 // Only handle incoming frames on our CAN bus
>>>> 158 if (frame.origin == me->m_can) me->IncomingFrame(&frame);
>>>> 159 }
>>>> So I assume that's the same bug I already reported in issue #103:
>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/103
>>>> …and as it now happened to you, I assume it's not configuration related. Can you verify my assumption?
>>>>> Looks like an init race condition, i.e. m_rxqueue used in undefined state.
>>>> Regards,
>>>> Michael
>>>> Am 22.05.2018 um 19:24 schrieb Greg D.:
>>>>> Just noticed this on my production 3.1 module. Was this an artifact of the
>>>>> upgrade from .005 to .006?
>>>>> Last boot was 140983 second(s) ago
>>>>> Time at boot: 2018-05-20 19:05:59 PDT
>>>>> This is reset #17 since last power cycle
>>>>> Detected boot reason: EarlyCrash (12/12)
>>>>> Crash counters: 1 total, 1 early
>>>>> Last crash: StoreProhibited exception on core 1
>>>>> Registers:
>>>>> PC : 0x4008f6de PS : 0x00060033 A0 : 0x8008eb13 A1 : 0x3ffd6150
>>>>> A2 : 0xfefeff4e A3 : 0x0000abab A4 : 0xb33fffff A5 : 0x00000001
>>>>> A6 : 0x00060020 A7 : 0x0000cdcd A8 : 0x0000abab A9 : 0x3ffd6150
>>>>> A10 : 0x00000003 A11 : 0x00060023 A12 : 0x00060020 A13 : 0x3ffb4188
>>>>> A14 : 0x000001e8 A15 : 0x00001800 SAR : 0x00000000 EXCCAUSE: 0x0000001d
>>>>> EXCVADDR: 0xfefeff4e LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
>>>>> Backtrace:
>>>>> 0x4008f6de 0x4008eb10 0x4011f3fd 0x40174f95 0x400e73be 0x400e4699 0x40085149
>>>>> 0x40128bc2 0x40128df7 0x401287b4 0x400ea22d 0x400eac7a 0x400ead09 0x400ead19
>>>>> 0x402207d6 0x400e9ece 0x400e9f79 0x400e45f5 0x400e4604 0x400f5c09 0x400f035d
>>>>> Version: 3.1.006/ota_0/main (build idf v3.1-dev-455-gf4905cdf May 20 2018 20:08:31)
>>>>> Running partition: ota_0
>>>>> Boot partition: ota_0
>>>>> Firmware: 3.1.006/ota_0/main (build idf v3.1-dev-455-gf4905cdf May 20 2018 20:08:31)
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180523/f4122ea7/attachment-0001.html>
