[Ovmsdev] SD CARD speed vs cp2102
Thu May 17 18:14:46 HKT 2018
Is it sufficient to provide secondary power at the USB port or does the 12V supply needs to be detached?
Am 17.05.2018 um 12:00 schrieb Mark Webb-Johnson:
> Other option I tried is to power from USB. But maybe not so easy in a Twizy?
> I should have new chips early next week. Arranging now.
> Regards, Mark
> On 17 May 2018, at 5:48 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Wow. Confirmed, speedup is at least factor 5.
>> And better yet, the fsync() overhead is reduced from ~50 ms to < 10 ms as well, the performance impact of SD logging is now fully acceptable for every day use.
>> All of my beta testers use SD cards to provide debug logs. Some also have been doing CAN logging, which helped debug some timing issues.
>> I'll need another 3.1 module anyway, but the testers will most likely want to continue using their modules. I'll forward your rework offer and the info on
>> how to solve this themselves if they're capable of doing micro-soldering.
>> Am 17.05.2018 um 10:40 schrieb Mark Webb-Johnson:
>>> It is a lot faster when working correctly. To me, it seems much more than 25%. Maybe four or five times faster?
>>> You can try:
>>> config set sdcard maxfreq.khz 20000
>>> then reboot and power from USB. Then try your speed test. Perhaps vfs cp from SD to SD to test?
>>>> On 17 May 2018, at 4:15 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> Thanks for the analysis and solution!
>>>> What kind of speedup is achievable by replacing the cp2102? Is it just linear 16 → 20 MHz = 25%?
>>>> Or does this also solve hidden retransmission issues?
>>>> balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> time ssh dexze85.local "vfs ls /sd/logs"
>>>> 541.7k 22-Apr-2018 22:34 can-180422
>>>> 449.0k 17-May-2018 09:56 log
>>>> 580.8k 01-May-2018 18:15 dm
>>>> 1.0M 30-Apr-2018 00:51 log.20180430-005121
>>>> 1.0M 30-Apr-2018 10:27 log.20180430-102732
>>>> 1.0M 30-Apr-2018 19:41 log.20180430-194146
>>>> 1.0M 01-May-2018 02:21 log.20180501-022128
>>>> 1.0M 01-May-2018 11:03 log.20180501-110318
>>>> 80 01-May-2018 14:09 can-180501
>>>> 1.0M 01-May-2018 17:56 log.20180501-175658
>>>> 1.1M 01-May-2018 18:17 dm2
>>>> 2.0M 01-May-2018 18:28 dm3
>>>> 1.3M 01-May-2018 20:21 dm4
>>>> 1.0M 02-May-2018 04:06 log.20180502-040605
>>>> 1.0M 02-May-2018 13:38 log.20180502-133816
>>>> 1.0M 03-May-2018 00:04 log.20180503-000415
>>>> 1.0M 03-May-2018 10:38 log.20180503-103815
>>>> 1.0M 03-May-2018 19:46 log.20180503-194654
>>>> 1.0M 04-May-2018 06:22 log.20180504-062242
>>>> 1.0M 04-May-2018 17:23 log.20180504-172311
>>>> 1.0M 05-May-2018 03:50 log.20180505-035002
>>>> 1.0M 05-May-2018 15:01 log.20180505-150115
>>>> 1.0M 06-May-2018 01:22 log.20180506-012241
>>>> 1.0M 06-May-2018 09:42 log.20180506-094249
>>>> 1.0M 06-May-2018 16:58 log.20180506-165842
>>>> 1.0M 07-May-2018 02:08 log.20180507-020820
>>>> 1.0M 07-May-2018 09:08 log.20180507-090846
>>>> 1.0M 07-May-2018 13:10 log.20180507-131042
>>>> 630.2k 23-Apr-2018 23:51 can-180423
>>>> 1.0M 07-May-2018 16:40 log.20180507-164032
>>>> 3.6M 24-Apr-2018 00:30 can-180424
>>>> 1.0M 24-Apr-2018 01:09 log.20180424-010932
>>>> 1.0M 24-Apr-2018 11:36 log.20180424-113642
>>>> 1.0M 24-Apr-2018 18:41 log.20180424-184124
>>>> 1.0M 25-Apr-2018 02:54 log.20180425-025415
>>>> 1.0M 25-Apr-2018 13:10 log.20180425-131000
>>>> 1.0M 25-Apr-2018 23:40 log.20180425-234048
>>>> 1.0M 26-Apr-2018 08:23 log.20180426-082309
>>>> 1.0M 26-Apr-2018 13:17 log.20180426-131718
>>>> 1.0M 26-Apr-2018 17:32 log.20180426-173218
>>>> 1.0M 26-Apr-2018 22:26 log.20180426-222645
>>>> 1.0M 27-Apr-2018 06:19 log.20180427-061932
>>>> 1.0M 27-Apr-2018 11:45 log.20180427-114534
>>>> 1.0M 27-Apr-2018 16:07 log.20180427-160751
>>>> 1.0M 28-Apr-2018 05:07 log.20180428-050703
>>>> 1.0M 28-Apr-2018 14:39 log.20180428-143956
>>>> 1.0M 29-Apr-2018 00:07 log.20180429-000755
>>>> 1.0M 29-Apr-2018 10:26 log.20180429-102600
>>>> 1.0M 29-Apr-2018 14:09 log.20180429-140942
>>>> 1.0M 07-May-2018 18:39 log.20180507-183951
>>>> 1.0M 07-May-2018 21:18 log.20180507-211821
>>>> 1.0M 08-May-2018 01:06 log.20180508-010616
>>>> 1.0M 08-May-2018 08:12 log.20180508-081232
>>>> 1.0M 08-May-2018 13:31 log.20180508-133133
>>>> 1.0M 08-May-2018 14:52 log.20180508-145232
>>>> 1.0M 08-May-2018 15:55 log.20180508-155530
>>>> 1.0M 08-May-2018 16:18 log.20180508-161814
>>>> 1.0M 08-May-2018 16:33 log.20180508-163344
>>>> 1.0M 08-May-2018 16:51 log.20180508-165156
>>>> 1.0M 08-May-2018 18:40 log.20180508-184035
>>>> 1.0M 09-May-2018 02:13 log.20180509-021338
>>>> 1.0M 09-May-2018 11:28 log.20180509-112803
>>>> 1.0M 09-May-2018 13:10 log.20180509-131042
>>>> 1.0M 09-May-2018 13:30 log.20180509-133049
>>>> 1.0M 09-May-2018 13:46 log.20180509-134607
>>>> 1.0M 09-May-2018 14:02 log.20180509-140208
>>>> 1.0M 09-May-2018 14:17 log.20180509-141725
>>>> 1.0M 09-May-2018 14:31 log.20180509-143108
>>>> 1.0M 09-May-2018 14:44 log.20180509-144407
>>>> 1.0M 09-May-2018 14:58 log.20180509-145806
>>>> 1.0M 09-May-2018 15:20 log.20180509-152009
>>>> 1.0M 09-May-2018 18:59 log.20180509-185904
>>>> 1.0M 10-May-2018 00:10 log.20180510-001018
>>>> 1.0M 10-May-2018 09:11 log.20180510-091155
>>>> 1.0M 10-May-2018 13:57 log.20180510-135727
>>>> 1.0M 10-May-2018 21:50 log.20180510-215045
>>>> 1.0M 11-May-2018 07:34 log.20180511-073403
>>>> 1.0M 11-May-2018 13:24 log.20180511-132440
>>>> 1.0M 11-May-2018 17:13 log.20180511-171332
>>>> 1.0M 11-May-2018 22:00 log.20180511-220047
>>>> 1.0M 12-May-2018 11:08 log.20180512-110827
>>>> 1.0M 12-May-2018 15:30 log.20180512-153022
>>>> 1.0M 12-May-2018 17:42 log.20180512-174248
>>>> 1.0M 12-May-2018 22:29 log.20180512-222949
>>>> 1.0M 13-May-2018 10:03 log.20180513-100341
>>>> 1.0M 13-May-2018 14:26 log.20180513-142603
>>>> 1.0M 13-May-2018 22:53 log.20180513-225343
>>>> 1.0M 14-May-2018 07:58 log.20180514-075805
>>>> 1.0M 14-May-2018 11:35 log.20180514-113524
>>>> 1.0M 14-May-2018 16:27 log.20180514-162753
>>>> 1.0M 15-May-2018 01:31 log.20180515-013153
>>>> 1.0M 15-May-2018 08:58 log.20180515-085847
>>>> 1.0M 15-May-2018 12:30 log.20180515-123053
>>>> 1.0M 15-May-2018 18:24 log.20180515-182435
>>>> 1.0M 16-May-2018 07:25 log.20180516-072553
>>>> 1.0M 16-May-2018 08:55 log.20180516-085501
>>>> 1.0M 16-May-2018 12:01 log.20180516-120115
>>>> 1.0M 16-May-2018 19:46 log.20180516-194613
>>>> 1.0M 17-May-2018 06:14 log.20180517-061451
>>>> *real 0m18.965s*
>>>> user 0m0.018s
>>>> sys 0m0.009s
>>>> Am 17.05.2018 um 04:22 schrieb Mark Webb-Johnson:
>>>>> Good grief. A year into this, and still writing about SD CARD issues with ESP32. If I could get into a room with the engineer who decided to share boot
>>>>> strapping pins with SDCARD pins, and to hard wire the SDIO controller to specific pins, I would literally try to slap some sense into him.
>>>>> The China guys and I have been struggling for the past couple of months trying to work out why we can’t get as much speed out of the SD CARD as we wanted.
>>>>> If we raise the speed to the normal 20MHz, we randomly get errors (timeouts, checksums, etc). It looked like interference on the bus lines, but scoping
>>>>> those we can’t find any. Dropping the speed to 16MHz works around the issue, but SD CARD accesses are slow.
>>>>> Then, we worked out it wasn’t random. It was based on whether we were powering from USB or external 12V. On the bench it works fine. In the car the
>>>>> problem appears. Simply put, if the USB was plugged in the ‘interference’ disappeared. If USB was unplugged, it came back. USB + external 12V combination
>>>>> also didn’t suffer from the issue, so the problem is not coming from the 12v side. The issue often appeared on only the second test of SD CARD, not the
>>>>> first. We didn’t see this problem on either the v3.0 developer modules, or v3.1 prototypes.
>>>>> We looked at the capacitors and pull-up resistors on that side of the circuit, without success. Whatever we did made little difference (or randomly
>>>>> changed things for the better/worse). We thought maybe ground-line interference, but nope. We spent some time looking at C20, C22, C23 to see if the
>>>>> manufacturers had messed up the component values - they hadn’t.
>>>>> Anyway, to cut a long story short, we finally found the culprit. The CP2102 chip itself.
>>>>> We’d already had to change the power supply design early on in the project to cope with a bug in CP2102 not correctly handling USB host disconnect and not
>>>>> properly going into suspend mode (to reduce power consumption of cp2101 circuit when usb was disconnected) - our current design completely powers down the
>>>>> cp2102 chip when the USB cable is disconnected. Michael Stegen had previously warned me about clones of this chip
>>>>> (see https://wiki.sha2017.org/w/Projects:Badge and what they went through), and we had added the extra resistor already to cope with that eventuality.
>>>>> But, from what we can tell this is not a clone part issue. Here is what we found:
>>>>> 1. OVMS v3.0 and early v3.1 prototypes use CP2102 v1412+. For that chip, when the USB cable is disconnected, CSL-TXD is 3.3v.
>>>>> 2. OVMS v3.1 first production batch use a newer CP2102 v1708+. For that chip, when the USB cable is disconnected, CSL-TXD is pulled down to 0.78v.
>>>>> 3. We have replaced the cp2102 on a v3.1 first production module with v1412+, and SD CARD resumes normal operation (even with usb disconnected).
>>>>> 4. The version number seems to be a date code. YYWW (year, week), I guess.
>>>>> 5. We have absolutely no idea why this would be affecting the SD CARD performance or interference. Somehow, that CSL-TXD line is going through the ESP32
>>>>> chip and affecting the SDIO controller (perhaps related to the bootstrapping pins dual use). The interference we see is inside the ESP32, not on the
>>>>> lines going from ESP32 to the SDCARD (which is why we couldn’t see it on the scope).
>>>>> I tried shutting down the pins on the ESP32 for CSL-TXD and CSL-RXD, to see if I could work around the problem in firmware, but couldn’t get it to work.
>>>>> There is no way of knowing whether the USB is connected, and even if we did know, setting CSL-TXD and CSL-RXD pins to output mode, or float, doesn’t seem
>>>>> to make any difference.
>>>>> The good news is that we’ve at least identified the problem. We are (a) checking the revision of cp2102 chip in the upcoming production batch, and (b)
>>>>> changing QC procedures to set SD CARD bus speed to default (20MHz) and randomly test modules twice on 12V power. Latest production batch is now using
>>>>> v1742+, and that has been tested as working. Going forward, we can resolve this.
>>>>> As for the first production batch units, they are what they are. For normal SD CARD operation (copying files, flashing firmware, etc), it makes little
>>>>> difference. I guess most users don’t even have an SD CARD inserted. The speed limitation really only becomes an issue if you are trying to log lots of
>>>>> data to SD CARD (such as CAN bus dumps). If the USB is connected, you can 'config set sdcard maxfreq.khz 20000’ and it will work faster. The CP2102 chip
>>>>> can be changed, and I’ll do that for anyone that needs it. I’m asking China to send me some from the latest production batch that we know works.
>>>>> Replacement is relatively straightforward, but involves micro-soldering (the cp2102 is a surface mount chip, very small footprint, with lots of other
>>>>> components near it on the board).
>>>>> Regards, Mark.
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180517/6c5a8a03/attachment-0001.html>
