[Ovmsdev] Modem fails to connect
Thu May 17 08:25:44 HKT 2018
Need to see a ‘log level verbose’ output from the modem, for a minute or so. Also ‘simcom status’ output twice (again, a minute or so apart) so we can see what is changing.
The modem and mux layers are up, but it looks like the PPP connection cannot be established. You sure you have sufficient balance on the Hologram account? Not just a ‘live’ SIM, but enough balance to be able to establish a data circuit (if you are on a pay-as-you-go plan). Also, please triple-check the APN/user/pass setting and make sure it is ‘hologram’.
> On 17 May 2018, at 1:02 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> I just noticed that my modem has stopped connecting to the 3G network. WiFi is fine, and it autoconnects when I get home. But on the road, no modem...
> Is there any debugging info that I can supply to figure out what happened? I checked the Hologram account, and it says the status is "Live" (i.e. not blocked for lack of funds or such). Last active 5 days ago, but the simcom status shows it's hearing the cell tower just fine. I'm on the .005 main software, v3.1 production hardware.
> Greg
> OVMS# simcom status
> SIMCOM
> Network Registration: RegisteredRoaming
> State: NetMode
> Ticker: 452141
> User Data: 0
> Mux
> Status: up
> Open Channels: 4
> Framing Errors: 0
> Last RX frame: 11 sec(s) ago
> RX frames: 61468
> TX frames: 49855
> PPP
> Not Connected
> Last Error: User Interrupt
> GPS
> Status: disabled
> Time: disabled
> NMEA: GPS/GLONASS Not Connected
> OVMS# network status
> Interface#3: pp3 (ifup=1 linkup=0)
> IPv4: 0.0.0.0/255.255.255.255 gateway 0.0.0.0
> Interface#2: ap2 (ifup=1 linkup=1)
> IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
> Interface#1: st1 (ifup=1 linkup=1)
> IPv4: 10.30.1.105/255.255.255.0 gateway 10.30.1.1
> Interface#0: lo0 (ifup=1 linkup=1)
> IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
> DNS: 9.9.9.9 8.8.8.8
> Default Interface: st1 (10.30.1.105/255.255.255.0 gateway 10.30.1.1)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180517/7a68c812/attachment-0001.html>
