[Ovmsdev] Web configuration
Tue May 15 02:21:42 HKT 2018
Steve,
in the beginning I wanted to keep the single config pages concentrated on single config areas, but I also think the wifi and status pages should offer a
function to switch the mode/net on the fly. Scanning for networks is also on my list. I'm waiting for the wifi rework for this, as I hope we can then offer a
smooth reconfiguration and nondisruptive scan.
Regarding the default AP "OVMS", that's intentionally not a selection option normally unless you define that network (in which case you also can override the
default password). The autostart page will add it to the select if it's the current AP network, so it doesn't get lost if in use. But it should not be a normal
end user option to easily return to the insecure initial AP config.
Am 14.05.2018 um 01:10 schrieb Stephen Casner:
> A couple of comments about the Wifi configuration via the web UI --
> Not having run the setup wizard and having used only client mode
> previously, I had no AP configured.  I configured an AP on the Wifi
> config page.  As I expected, that had no immediate effect, so I
> rebooted the module to make that take effect.  Then I saw the SSID
> OVMS appear.  I needed to go to the autostart config page to select my
> new AP SSID as the one to be started, and then reboot again to start
> it.
> I can imagine situations where I want to temporarily switch Wifi modes
> and/or define a new AP or client SSID and switch right away, but not
> have those settings become my autostart settings.  Shouldn't there be
> controls on the Wifi config page to set the Wifi mode like those on
> the autostart config page?
> Also, in the scenario above I was a bit surprised to see the OVMS SSID
> since the Wifi config page did not list it as an AP.  Shouldn't it be
> included there?
