[Ovmsdev] New web setup
Mon May 14 00:42:35 HKT 2018
Here are my screenshots, in case someone wants to have a look without actually running the wizard.
https://drive.google.com/open?id=1MWnKPk78fZHOJfrXiCwe6-2EBltnI01T
Am 13.05.2018 um 18:25 schrieb Michael Balzer:
> I just did another setup run to also catch a firmware update screenshot.
> I got a stack overflow in the events task when starting the step 4 test (loading vehicle module and server v2). The crash persisted over reboot, so the setup
> wizard reverted to factory defaults (good to know that works).
> This may be because I'm testing on a 3.0 module, but I've just pushed a stack change to 8K just to be sure.
> Am 13.05.2018 um 17:54 schrieb Michael Balzer:
>> Pushed.
>> Strangely enough, during my tests I once had the same effect as you, but with the Cloudflare DNS.
>> I couldn't reproduce it though.
>> Please try again.
>> I also captured screenshots of the process for the user guide -- is that necessary? I took care to add a lot of info to the process itself.
>> Am 13.05.2018 um 16:44 schrieb Michael Balzer:
>>> With the Google/Cloudflare DNS you can finish the setup?
>>> I was hoping we could omit the DNS question now from the setup, as users likely don't know what that is.
>>> I'll add it to step 2 for now, but with a fixed & labeled selection.
>>> Am 13.05.2018 um 16:36 schrieb Michael Balzer:
>>>> My boot without a fixed DNS looks like yours with a fixed one:
>>>> I (5066) event: sta ip: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1
>>>> I (5066) netmanager: Interface priority is st1 (192.168.2.109/255.255.255.0 gateway 192.168.2.1)
>>>> I (5076) netmanager: Set DNS#0 192.168.2.1
>>>> I (5076) netmanager: Set DNS#1 192.168.2.1
>>>> I (5076) netmanager: Set DNS#2 0.0.0.0
>>>> I (5076) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
>>>> I (5076) esp32wifi: STA got IP with SSID: WLAN-214677, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.109, mask: 255.255.255.0, gw: 192.168.2.1
>>>> I (5076) time: Starting SNTP client
>>>> I (5076) ovms-server-v2: Status: Network is up, so attempt network connection
>>>> I (6286) ovms-server-v2: Connection is ovms.dexters-web.de:6867 Test1
>>>> I (6286) ovms-server-v2: Status: Connecting...
>>>> I (6516) ovms-server-v2: Connection successful
>>>> I (6516) ovms-server-v2: Status: Logging in...
>>>> Is your DNS in the router or behind? The IP and masking looks like it's on another net. If it's on another net, is it possible the first query after the
>>>> wifi connect is blocked or fails due to some firewall delay?
>>>> Regards,
>>>> Michael
>>>> Am 13.05.2018 um 16:07 schrieb Mark Webb-Johnson:
>>>>> Definitely something timing related. Even with auto wifi.mode=client, the wifi client comes up on boot, but v2 server can’t connect on first try (but
>>>>> second try works).
>>>>> This is what I get:
>>>>> I (7316) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>> I (7326) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64)
>>>>> I (7326) netmanager: Set DNS#0 10.10.40.64
>>>>> I (7326) netmanager: Set DNS#1 0.0.0.0
>>>>> I (7326) netmanager: Set DNS#2 0.0.0.0
>>>>> I (7326) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
>>>>> I (7326) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>> I (7326) time: Starting SNTP client
>>>>> I (7326) ovms-server-v2: Status: Network is up, so attempt network connection
>>>>> I (7336) webserver: Launching Web Server
>>>>> I (7376) ssh: Launching SSH Server
>>>>> I (7386) ovms-server-v2: Status: Network is up, so attempt network connection
>>>>> I (8396) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH
>>>>> I (8396) ovms-server-v2: Status: Connecting...
>>>>> I (10396) housekeeping: System considered stable (RAM: 8b=94792-95652 32b=23608)
>>>>> W (25696) ovms-server-v2: Connection failed
>>>>> E (25696) ovms-server-v2: Status: Error: Connection failed
>>>>> I (25696) ovms-server-v2: Status: Disconnected
>>>>> But, if I config set network dns ‘8.8.8.8 1.1.1.1’, I get:
>>>>> I (7087) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>> I (7097) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64)
>>>>> I (7097) netmanager: Set DNS#0 8.8.8.8
>>>>> I (7097) netmanager: Set DNS#1 1.1.1.1
>>>>> I (7107) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
>>>>> I (7107) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>> I (7107) time: Starting SNTP client
>>>>> I (7107) ovms-server-v2: Status: Network is up, so attempt network connection
>>>>> I (7117) webserver: Launching Web Server
>>>>> I (7137) ssh: Launching SSH Server
>>>>> I (7157) ovms-server-v2: Status: Network is up, so attempt network connection
>>>>> I (8387) ovms-server-v2: Connection is api.openvehicles.com:6867 <http://api.openvehicles.com:6867> DEVBENCH
>>>>> I (8387) ovms-server-v2: Status: Connecting...
>>>>> I (8617) ovms-server-v2: Connection successful
>>>>> I (8617) ovms-server-v2: Status: Logging in...
>>>>> I’m guessing this new ‘stored dns’ is the root of the problem, but really not sure what is going on. The delay is long enough to allow your test to timeout.
>>>>> Regards, Mark.
>>>>>> On 13 May 2018, at 2:18 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>> Am 12.05.2018 um 18:21 schrieb Mark Webb-Johnson:
>>>>>>>> Did you apply the sdkconfig changes regarding SO_REUSE? I had none such problems after fixing that in my sdkconfig -- I also fixed the defaults in some
>>>>>>>> commit a few days before.
>>>>>>>> CONFIG_LWIP_SO_REUSE=y
>>>>>>>> CONFIG_LWIP_SO_REUSE_RXTOALL=y
>>>>>>> Just double-checked, and yes they are there.
>>>>>>> It seems that after connecting to SSID, the attempt to run ‘Ota status’ is immediate, but the wifi client hasn’t settled down yet. I’ve looked in
>>>>>>> web_cfg_init, but having trouble working out how it works. In the 'if (step == "2.test.connect”)’, it just seems to try to MyOTA.GetStatus as soon as
>>>>>>> the ssid matches? But it doesn’t check that the wifi client is actually up (the reception of IP address may be a second or two after the SSID is
>>>>>>> connected, and anyway GetSSID() just returns the configured SSID, not the connected one). Or, maybe I’m missing something?
>>>>>> The state ticker does not check yet if it can abort a scheduled timeout. So it doesn't do the test as soon as GetSSID() returns the network.
>>>>>> The test is done fixed 20 seconds after StartAccessPointClientMode(). That is normally plenty of time for everything to settle. In my runs, the client
>>>>>> network was normally fully functional in ~10 seconds.
>>>>>> How long does your APClient switch take? You can try raising the 20 second timeout in line 226.
>>>>>> Regards,
>>>>>> Michael
>>>>>>> Regards, Mark
>>>>>>>> On 12 May 2018, at 11:14 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>> Am 12.05.2018 um 15:42 schrieb Mark Webb-Johnson:
>>>>>>>>> Works better, but still causing me issues. I had a couple of times where it took down the whole housekeeping task (with red alerts saying event
>>>>>>>>> delivery queue was full so ticker.1 messages couldn’t be delivered). I guess it is doing the wifi connectivity test in the main event task?
>>>>>>>> Yes, the most time consuming task in there is the OTA.GetStatus() fetching the server version info. But I didn't get any problems from that in all my
>>>>>>>> tests…
>>>>>>>>> The other problem is that the bringing up/down of the APCLIENT vs AP mode doesn’t seem to work properly, so I lose connection to the station. Also, my
>>>>>>>>> iPad keeps switching back to home wifi, every time the OVMS reconfigures the network. APCLIENT mode really sucks.
>>>>>>>> If these are missing, both the webserver and ssh cannot rebind after the switch from AP to APCLIENT.
>>>>>>>> The switching takes some seconds, but my tablets (all Androids) only switched back to my home network during tests with issues. The normal process is
>>>>>>>> fast enough to keep them on the AP.
>>>>>>>> Regards,
>>>>>>>> Michael
>>>>>>>>> I’ll have another look at the wifi driver. Maybe I can improve the API a bit (based on what we have). Perhaps configure a STAtion even in AP mode
>>>>>>>>> (which is what I did with my alternative approach before).
>>>>>>>>> Regards, Mark.
>>>>>>>>>> On 12 May 2018, at 12:52 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>>>> Added another fix.
>>>>>>>>>> Or more sort of a workaround: I just had an empty server status display on step 4 test after successful connect. I'm not sure how this can happen, I
>>>>>>>>>> guess it's due to five events being processed at once after the connect (server v2 blocks the mongoose task there) and some race condition in the
>>>>>>>>>> javascript code in that case.
>>>>>>>>>> The three event based status displays now again also do periodic updates every 5 seconds, so if this happens, the status gets updated again after 5
>>>>>>>>>> seconds.
>>>>>>>>>> Regards,
>>>>>>>>>> Michael
>>>>>>>>>> Am 11.05.2018 um 18:19 schrieb Michael Balzer:
>>>>>>>>>>> OK. I really should wait for config.mounted before reading from MyConfig.
>>>>>>>>>>> Fix is pushed, please try.
>>>>>>>>>>> Am 11.05.2018 um 17:49 schrieb Mark Webb-Johnson:
>>>>>>>>>>>> I tried a restart. Here is what I get:
>>>>>>>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main
>>>>>>>>>>>> Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
>>>>>>>>>>>> I (1465) webserver: Launching Web Server
>>>>>>>>>>>> I (1465) ssh: Launching SSH Server
>>>>>>>>>>>> I (4185) wifi: ap channel adjust o:1,1 n:6,2
>>>>>>>>>>>> I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1
>>>>>>>>>>>> I (4945) wifi: state: init -> auth (b0)
>>>>>>>>>>>> I (4945) wifi: state: auth -> assoc (0)
>>>>>>>>>>>> I (4955) wifi: state: assoc -> run (10)
>>>>>>>>>>>> I (5055) wifi: connected with HIGHWAYS, channel 6
>>>>>>>>>>>> I (5375) sdcard: SD CARD has been inserted
>>>>>>>>>>>> I (5465) sdcard: mount done
>>>>>>>>>>>> I (6025) wpa: PTK has been installed, it may be an attack, ignor it.
>>>>>>>>>>>> I (6025) wpa: GTK has been installed, it may be an attack, ignor it.
>>>>>>>>>>>> I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6
>>>>>>>>>>>> I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20
>>>>>>>>>>>> I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4
>>>>>>>>>>>> I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>>>>>>>>> I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64)
>>>>>>>>>>>> I (9455) netmanager: Set DNS#0 10.10.40.64
>>>>>>>>>>>> I (9455) netmanager: Set DNS#1 0.0.0.0
>>>>>>>>>>>> I (9455) netmanager: Set DNS#2 0.0.0.0
>>>>>>>>>>>> I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
>>>>>>>>>>>> I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
>>>>>>>>>>>> I (9455) time: Starting SNTP client
>>>>>>>>>>>> I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608)
>>>>>>>>>>>> I (13565) webserver: HTTP GET /
>>>>>>>>>>>> I (13575) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (14825) webserver: HTTP GET /
>>>>>>>>>>>> I (15135) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (15375) simcom: State timeout, transition to 13
>>>>>>>>>>>> I (15375) simcom: State: Enter PoweredOff state
>>>>>>>>>>>> I (15375) gsm-mux: Stop MUX
>>>>>>>>>>>> I (16695) webserver: HTTP GET /
>>>>>>>>>>>> I (16705) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (16735) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>> I (16905) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>> I (16905) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>> I (17345) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (28045) webserver: HTTP POST /cfg/init
>>>>>>>>>>>> I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574
>>>>>>>>>>>> I (28085) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (28085) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (28085) webserver: HTTP GET /menu
>>>>>>>>>>>> I (40025) webserver: HTTP GET /
>>>>>>>>>>>> I (40035) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (40035) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (40045) webserver: HTTP GET /
>>>>>>>>>>>> I (40075) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>> I (40085) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>> I (40185) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>> I (40355) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (40355) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> OVMS> enable
>>>>>>>>>>>> Password:
>>>>>>>>>>>> Secure mode
>>>>>>>>>>>> I (50425) webserver: HTTP GET /
>>>>>>>>>>>> I (50425) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (50425) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (50465) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>> I (50475) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>> I (50555) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>> I (50675) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (50675) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> OVMS# ota status
>>>>>>>>>>>> Running partition: ota_0
>>>>>>>>>>>> Boot partition: ota_0
>>>>>>>>>>>> Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05)
>>>>>>>>>>>> Server Available: 3.1.005
>>>>>>>>>>>> OTA release providing minor improvements and fixes.
>>>>>>>>>>>> - Vehicle: 12V battery monitoring
>>>>>>>>>>>> vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference
>>>>>>>>>>>> - OTA: automatic daily firmware updates (wifi only)
>>>>>>>>>>>> auto [ota] = yes Enable/disable
>>>>>>>>>>>> ota [auto.hour] = 2 Hour for daily check
>>>>>>>>>>>> - Logging: persistent configuration, file cycling, web config UI:
>>>>>>>>>>>> log [file.enable] = no Enable/disable file logging
>>>>>>>>>>>> log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling
>>>>>>>>>>>> log [file.path] = "" Log path, if on /sd watches sd.mounted
>>>>>>>>>>>> log [level] Default level
>>>>>>>>>>>> log [level.<tag>] Component levels
>>>>>>>>>>>> - Reverse Engineering Tools enhancements
>>>>>>>>>>>> - Tesla Roadster CAC support
>>>>>>>>>>>> - Miscellaneous bug fixes and enhancements
>>>>>>>>>>>> I (61705) webserver: HTTP GET /
>>>>>>>>>>>> I (61715) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (61715) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (61745) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>> I (61755) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>> I (61845) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>> I (61965) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (61965) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (72035) webserver: HTTP GET /
>>>>>>>>>>>> I (72045) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (72045) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> I (72085) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>> I (72095) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>> I (72175) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>> I (73485) webserver: HTTP GET /cfg/init
>>>>>>>>>>>> I (73495) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>> OVMS# config list auto
>>>>>>>>>>>> auto (readable writeable)
>>>>>>>>>>>> wifi.mode: apclient
>>>>>>>>>>>> wifi.ssid.ap: DEVBENCH
>>>>>>>>>>>> wifi.ssid.client: HIGHWAYS
>>>>>>>>>>>> OVMS# config list module
>>>>>>>>>>>> module (readable writeable)
>>>>>>>>>>>> init: 2.test.connect
>>>>>>>>>>>> Regards, Mark
>>>>>>>>>>>>> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>>>>>>>>>> Do you have the earlier log, especially of the CfgInit ticker messages?
>>>>>>>>>>>>> Is the auto config correct and matching the "HIGHWAY" network?
>>>>>>>>>>>>> Please try a reboot. The ticker should take on step "2.test.connect" and proceed.
>>>>>>>>>>>>> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson:
>>>>>>>>>>>>>> Trying the new web setup, but not getting very far…
>>>>>>>>>>>>>> I (503580) webserver: HTTP GET /
>>>>>>>>>>>>>> I (503590) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (503590) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (503610) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (503610) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (503730) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (503880) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (503880) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (513960) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (513960) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (514000) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (514000) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (514090) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (514220) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (514220) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (524280) webserver: HTTP GET /
>>>>>>>>>>>>>> I (524290) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (524290) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (524320) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (524340) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (524420) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (524590) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (524590) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (534620) webserver: HTTP GET /
>>>>>>>>>>>>>> I (534630) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (534630) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (534660) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (534660) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (534760) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (534890) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (534890) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (544940) webserver: HTTP GET /
>>>>>>>>>>>>>> I (544950) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (544950) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (544980) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (544990) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (545080) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (545250) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (545250) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> OVMS# wifi status
>>>>>>>>>>>>>> WiFi
>>>>>>>>>>>>>> Power: on
>>>>>>>>>>>>>> Mode: Access-Point + Client mode
>>>>>>>>>>>>>> STA SSID: HIGHWAYS
>>>>>>>>>>>>>> IP: 10.10.41.203/255.255.248.0
>>>>>>>>>>>>>> GW: 10.10.40.64
>>>>>>>>>>>>>> AP SSID: DEVBENCH
>>>>>>>>>>>>>> MAC: 30:ae:a4:43:92:c5
>>>>>>>>>>>>>> IP: 192.168.4.1
>>>>>>>>>>>>>> AP Stations: 1
>>>>>>>>>>>>>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2
>>>>>>>>>>>>>> OVMS# ota status
>>>>>>>>>>>>>> I (1141850) webserver: HTTP GET /
>>>>>>>>>>>>>> I (1141860) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (1141860) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> I (1141890) webserver: HTTP GET /apple-touch-icon.png
>>>>>>>>>>>>>> I (1141890) webserver: HTTP GET /assets/style.css
>>>>>>>>>>>>>> I (1141990) webserver: HTTP GET /assets/script.js
>>>>>>>>>>>>>> I (1142120) webserver: HTTP GET /cfg/init
>>>>>>>>>>>>>> I (1142120) webserver: CfgInit enter 2.test.connect
>>>>>>>>>>>>>> Can’t get out of that 2.test.connect.
>>>>>>>>>>>>>> Any ideas?
>>>>>>>>>>>>>> Regards, Mark.
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>>>>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>>>>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>>>>>>>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180513/b3db3117/attachment-0001.html>
